Won’t Start Unless It’s Started By The Starter?
My Car Won’t Start Unless It’s Started By The Starter Itself & It Keeps Popping Up The Battery Light, Security Light On The Dash. I’...
kalynmusic777
Give Us Some Gas The Car Would Just Shut Off?
The Last Week Or So My Car Hasn’t Start Up And Then When I Do Get It Running, I Would Give It A Little Gas And Then It Would Sound Like...
Meloman7
Wont Start Trying To Reset The CPU?
I Have Replaced: Cats, Fuse Box, Map Sensor Mas Sensor All Oxygen Sensors, Fuel Pump, I Am Now Trying To Reset The Cpu But When...
Coach Harvey
CHEVROLET EXPRESS
Car Keeps Stalling Codes: P1298, And P0700
Hi Everyone, I Have A Honda Accord Lx 1999. The Car Hard To Start And Keeps Shut Off After A Minute Or So, And When I Put Load The Car...
Akord
Starter Went Out And I Left Off The Alternator Wire...
Got New Alternator Put On And The Wire Back On The Starter Now I Am In Limp Mode And Code U0101 Will Not Clear Out
Billy Bidwell
Neutral Safety Switch Connector
Friend Has A 2004 Chevy Malibu Ls 3.5l 4t40e Transmission. She Just Replaced The Neutral Safety Switch And The Connector. Its A 12 Pin...
foster352
My Check Engine Light Turned Into P0171, P0174, P0420...
So My Check Engine Light Has Been On For A Minute Now, It Was Originally Only A P0171, But That Turned Into P0171, P0174, P0420 And A...
Perse.grey
Disable Automatic Door Locks?
I Want To Disable Automatic Door Locks-the Vehicle System Settings Does Not Give An Option To Turn Auto Locks Off-the Internet Days You Can...
Glenda Duncan
2024
The Vehicle Could Not Drive On Limp Mode Fault Code:...
The Vehicle Started This Problem After Body Repair From Panel-beater. I Diagnose This Vehicle And Detect P0a80-hv Battery Need Replacement...
Mallyboy
TOYOTA CAMRY HYBRID
SKIPPING AFTER NEW TIRES?
Bought This Car Where The Tires Had Close To 20% Tread Left. Car Drove Excellent With Zero Issues, No Codes Under Engine, Transfer Or...
divides
BMW X1
No Spark I Install New Distributor?
I Install New Distributor, New Spark Plugs Wires. Engine Will Crank But No Start No Spark From Spark Plug Wire. What Is The Firing Order On...
joe1953
1979
FORD F-100
Aftermarket Intake
I Have A 2004 5.3 And I Installed A Acesefi Aftermarket Intake And I’m Not Sure If I Need To Do Anything About My Map Sensor Since My Old...
Daltontrotter
Glove Box Removal/ Door Actuator
I Can't Get The Glove Box Off. Removed 5 Screws And Popped Open But The Door Hinges Are Attached By Two Pins That Fit Into The Main Dash...
Johntaylor444
BUICK LUCERNE
New Diagnostic Tool For Networks
It Is A Network Logger And Emulator That Can Capture The Data From Multiple Networks And Lets You Overlay It With Other Data To Determine...
Steve W.
Transmission Solenoids High Resistance Number
I Have A 2004 Saturn Redline Awd, 3.5l/mj8 Transmission. I Was Using A Scan Tool, Looking At My Transmission Parameters And It Showed...
Skater28
SATURN VUE
Where Is The Bcm?
Where Is The Bcm On A 2012 Acura Mdx And What Does It Look Like?
silenthilldale
ACURA MDX
Car Dies While Driving Replaced Our Fuse Box Relays?
We Have Replaced Our Fuse Box Relays And Fuses And Wiring And Fuel Pump. Car Dies While Driving Sometimes I Can Put It In N And Restart...
ZyanyaRaven
BUICK LUCERNE
Need Help Getting The Last Middle Bolt?
Im Pulling The Oil Pan An Replacing It An I Can't Get The Last Middle Bolt Pn The Right Side Of The Oil Pan It's Blocked By The...
Hoffmanjem1
OLDSMOBILE CIERA
Blend Door Heater Blows Cold Air?
Heater Blows Cold Air. Both Hoses Are Hot, So There Is Coolant Flow.
Bmcmurtrey
BUICK LA CROSSE
Brake Bleed A Little Confused As To The Procedure?
Using A Scanner To Automated The Abs I'm A Little Confused As To The Procedure. First It Says Pump Pedal Repeatedly. Release Pedal The...
Freerider78
BUICK LESABRE
Crankshaft Position Sensor Shows A P0339 Code?
Obd2 Shows A P0339 Code, Which I See Is The Crankshaft Position Sensor. Some Things I'm Finding Online Show You Can Replace That Sensor...
twebb101
Turn Signal And Hazard Lights Does Not Work At All But...
Turn Signals And Hazard Lights Doesn't Work At All When I Turn It On The Signal It Makes A Tick Tick Noise Just Two Times And Nothing...
TMCx4
SATURN L200
2012 Acura MDX Turn Signals Not Working?
2012 Acura Mdx Turn Signals And Rear Wiper Stopped Working. The Hazards Work Though. It Has A Aftermarket Remote Start That If You Lock The...
silenthilldale
ACURA MDX
Engine Coolant Sensor Vs Sender
I Had Problem With Cooling Fans Not Coming On, Even After Engine Reached Overheat Temps. I Replaced Coolant Temperature Sensor And Fans...
Tboat13
DODGE STRATUS
Wont Turn Over Possible Short And Bad Battery?
Had Possible Short And Bad Battery. Changed Battery And I Think I Have Shorted Wire Or Bad Pcm. Anyone Have Diagram So I Can Test Wires For...
evninsun
5
6
7
20251
