Wont Turn Over Possible Short And Bad Battery?
Had Possible Short And Bad Battery. Changed Battery And I Think I Have Shorted Wire Or Bad Pcm. Anyone Have Diagram So I Can Test Wires For...
evninsun
Random Multiple Misfire Replaced Upper And Lower...
I Replaced My Upper And Lower Intake Manifold Gaskets, Spark Plugs And Wires. While Repairing The Car The Plastic Nipple That Vacuum...
Frederick Hume
Transmission Solenoid Pack Replacement
Put A New Transmission Solenoid Pack On And Put It Back Together When I Was Done My Van Would Not Start Or Would Not Even Turn Over Or Crank...
Fatt1986
Fatt1986
Fatt1986
Fatt1986
Fatt1986
Fatt1986
Transmission Solenoid Pack Replacement Would Not Even...
Fatt1986
Little White Smoke
It Just Finish Rainning And I Went To The Store I Stop To Get Gas And I Notice A Little Bit Of White Smoke Comming Out The Exhaust Pipe
carm2614
BMW 335
Truck Died And Won't Start Unless You Mash The Gas
Ok So My Truck Started Making A Ticking Noise Right Before I Had To Make A Long Trip For My Daughters Surgery. We Made It And Started Headed...
Danielle2018
Transmission Flex Plate/Transmission Heater Leak?
Had Transmission Replaced 3 Months Ago At 85,000 Miles. Cost Was Over $5k For Transmission With 3 Year Warranty. Truck Started Making A High...
dvdplmm11
RAM 1500
Paddle Shifter Help I Downshift Around 2000 RPM?
I Have Had A Muffler Delete On My Car For About Seven Months Now So When I Downshift, You Can Hear The Burbles Or The Pops So I Used The...
ChristianMonro
2023
Coolant Leak
Got Home To Find That My Upper Radiator Hose Had Burst. Replaced Hose. Couldn't Get The Heater To Blow Hot. Popped Open Radiator To Find...
Estoogood
HYUNDAI TIBURON
Where Is The Oil Pressure Sensor Located On The 2022...
I Was The Victim Of A Hit And Run Accident. My Chevrolet Was Hit On The Passenger Side And My Car Was Wedged Up On An Intersection Island....
MarkNo65
2022
CHEVROLET SPARK
Remote Lock Unlock?
My Keyfob Does Not Work Replaced The Batteries Multiple Times And Cannot Program To The Truck. I Am At A Loss Have Had It To Multiple...
bobbyrylands
Bcm?
-steering Wheel Warning On Dashboard (fluid Is Good, Steering Wheel Not Heavy, No Noise) -remot Not Locking/not Unlocking -signals Not...
Chakib
MAZDA 5
Catalytic Converter Install?
Hello Any Information On An Install Of A Set Of Catalytic Converters For 2011 Jeep Grand Cherokee Laredo V6?
dougparks111
JEEP GRAND CHEROKEE LAREDO
Exhuast Valves: Rough White Powdery Deposits
2009 Ford F-150 Xlt 4x4 Modular V-8 / 5.4l (330 Cu In) 3v 165k Miles So, Have The Cylinder Heads Removed For Camshaft Bearing...
Larrycv7
TCM Or Not
I Have An 04 Mazda 3 Hatchback With A 2.3l Motor With Automatic Transmission. Can You Tell Me If This Has A Tcm? I Read That The Sedan...
mdeida8025
Needing Cam And Crankshaft Sensor Testing And Relearn...
I First Had Camshaft Sensor Bank Codes So I Had Replaced The Intake And The Exhaust Camshaft Sensors And Ran Good For A Day Or So Then I Get...
4AFix
It Only Cranks But Wont Start?
Took The Battery Out Then Put It Back In Now It Only Cranks But Wont Turn Over
Rhonda381
TOYOTA CAMRY SOLARA
Smoking From Valve Cover Area?
I Have A 94 Jeep Cherokee That Blew A Radiator Hose, And Was Overheating. It Was Parked, Identified The Split Hose, Replaced And Assumed...
Taybag
How To Connect After Market Horn Button?
I Have Found My Fuse On My Car Under The Left Side Of The Dash. I Have 4 Wires Coming Out Of It. Two Orangeish Yellow, One Green And One...
Austinjr
Electrical Issues After Changing The Battery?
Hi I Have A 2014 Hyundai Veloster Base Model (non-turbo), Last Week I Started To Feel That The Battery Are Dying Till 2 Days Ago The...
tiesto870
HYUNDAI VELOSTER
6
7
8
20251
