Need To Clean Out Gas Tank After Having Rice Put In It...
When I Bought This Truck, They Informed Me That Someone Had Put Rice In The Gas Tank. It Has Not Been Started At All Since Then. How Should...
Brian Harkness
25 IMAGES
Will Not Stay Running?
The Only Way I Can Get It To Run Is To Hold The Gas To The Floor While I Crank It And It Will Only Run Briefly. Any Ideas?
dw423
Digital HVAC System Not Powering Up At All?
I Had A Battery Completely Drain Down To Nothing Due To Lack Of Use With This Car. It Was Dead For About A Month From What I Can Guess. I...
Jrhoopman
What Is The Correct Torque For The Drive Belt Pullies?
I Have A Ford Falcon Au Series 3. I've Recently Replaced The Drive But Want To Torque All The Bolts On The Pullies Correctly But I Can...
Jimmy Boi
FORD FALCON
Just Picked It Up From Someone. They Said It Was Running Rough When Parked But Running. Cleaned The Plugs, Rotor And Distributor. They...
jim.ramage57
MAZDA B2600
Spark Plug Wires Diagram Needed?
I Mixed Up My Spark Plug Wires. No Idea What Goes Where, What Should I Do?
Mckzie26
Shutting Off?
My Car Runs Fine Until It Warms Up. Once It’s Been Run For A While It Idles Weird And Eventually If I Don’t Keep Giving It Gas It’ll...
gomezjeanessa
Shutting Off
My Camaro Runs Fine Until It Warms Up. Once It’s Been Ran For A While It Idles Weird And Eventually If I Don’t Keep Giving It Gas It’...
gomezjeanessa
Did I Already Mess Up My Battery?
I Was Riding An E-bike With My Car Battery Ratchet Strapped To My Frame On The Way Home From Swapping Out My Battery From Autozone, My...
Kadie
BMW 325I
The Illumination Lights On My Instrument Cluster/panel...
The Vehicle Listed Above Is A C1500, 2wd, 5.7l V8: All Of The Caution And Warning And The Turn Signal Indicator Lights On The Panel Work...
Oldsmaru44x2
GMC SUBURBAN
Stalled While Driving And Will Not Start Back Up?
It Shut Off While I Was Driving Down The Road Like It Ran Out Of Gas, Put Gas In And It Want Start Back Up. Poured Gas In Intake And It...
Jenn88
Taillights Not Working?
I Noticed The Taillights Are Not Illuminated On Both Sides (brake Lights Do Work) Is It Unusual To Have Both Bulbs Burn Out At The Same...
Carcouldcareless
Vibration In Steering Wheel?
I Have Not Been In My Car For 2 Days. I Go To Get Into It This Morning And Before Putting The Key Into The Ignition I Noticed My Steering...
Xandyb
Dash Cluster Not Working?
The Gauges Not Working Very Much. They Will Cut Off And Back On. May Show 2 Miles In 300
cecildewey
A/C Condenser Fan Not Turning On When A/C Is On?
This Question Is On The Car Listed Above. When The Ac Is Turned On, The Condenser Fan Does Not Turn On. The A/c Compressor, Condenser And...
RacerXX
OLDSMOBILE CIERA
Abbreviation For Back Windshield Wiper?
Is There A Fuse For The Back Windshield Wiper And What Is The Abbreviation For It?
Jav Robl
Intermittent Starting Problem?
My Car Takes An Average Of About 5 Attempts Before The Starter Kicks In And Starts Cranking And Once It Starts Cranking About Half The Time...
Nunezboy97
A/C Blowing Hot Air?
Trying To Bring My Truck Listed Above Super Cab Xlt 4x4 Back To Life. The A/c Blower Works And Seems To Cycle, But Only Blows Hot Air. It...
Billy Mack 48
Ob2 Won't Connect To Port To Test
Truck Started Misfire In Intersection And Shut Off Won't Start
thomas.darsie
Fuel Pump?
I'm Trying To Diagnose My Fuel Pump If It's Faulty, My Question Is? If I Have My Fuel Filter Disconnected And I Turn Over My Engine...
chrisrak
Faulty Climate Control?
2016 Dodge Grand Caravan. The Air And Heat Stopped Blowing Out Of All Vents Except The Defroster Or The Floor Or The Rear Passenger...
Michael D Jennings
Transmission Swap?
Will A Manual Transmission From A 99 Dodge Dakota Replace An Automatic Transmission In A 99 Dodge Durango?
Marcher80
DODGE DURANGO
How To Properly Set The Timing?
Trying To Set Timing, I'm Not Sure If I'm Doing It Right, When I Line Up The Marks The Truck Will Turn Over But Will Not Start....
Alliecat66
Procedure For Changing Motor Mounts Under The Car?
I've Watched A Lot Of Videos And Still Can't Get A Straight Answer. In Changing The 2 Upper Motor Mounts But I Have The Lower One...
Robert Clark2
Shut Off And Will Not Start After Slamming On Brakes?
I Slammed On The Brakes To Avoid An Accident And Noticed No Power, So I Pulled Over And Car Was Not Running And Now It Won't Start.
Cortez Edwards
KIA OPTIMA
699
700
701
