Potential Electrical Issue?
Hi, My Hyundai I40 Estate 2014 Has An Issue With Both The Boot And Fuel Cap Sporadically Not Unlocking When Pressing The Boot Release, Key...
Shaww
HYUNDAI I30
Need A Diagram For All The Hoses Under The Hood?
I Need A Diagram For All The Hoses Under The Hood?
Cynthia Ramage
MERCURY MONTEGO
Intermittent Stalling, Erratic Idling?
Hi. Just Wanted To Ask If You've Encountered This Problem With The Car Listed Above A32 With The 3.0l Vq30de V6 Engine. -...
Ed Sanchez2
NISSAN CEFIRO
Intermittent Crank/no-start?
My Son's Base Model Car Listed Above Has An Intermittent (1x Every 2 Weeks) Crank No-start Problem. Brand New Battery, Alternator Good...
dbogarde
VOLKSWAGEN JETTA
Driver's Side Brake Light Not Working?
I Have Checked Fuses, Relays, Bulbs, Changed Multiple Bulbs, And My Bulb Will Work When The Taillights Are On But Then Again When I Hit...
Carp1187
CHRYSLER CONCORDE
BCM Location And Wire Diagram Needed?
When Trying To Start It Will Only Crank For A Moment. Then Kick Out. It Makes Maybe One Revolution And Won't Continue To Crank Kicks Out...
KodiakFabMan
Where Are The Lifts And How Do You Remove Or Clean? <...
Hydraulic Lifters.
Geoff T
DAEWOO LANOS
My Truck Is Idling Really High?
When I Crank It Up It Idles Very High. It Will Go Down A Little Bit When I First Crank It Up But When I'm Driving It And Go To Stop And...
Brianna Aleta
Where Are The Camshaft Sensors Located?
Needing To Replace Both Bank 1 And, Bank 2 Camshaft Sensors. So Far, After Hours Of Searching Google And, The Tube, I Have Yet To Find...
sabrtyca
SUBARU LEGACY
Camshaft Position Sensor Wiring?
3 Wires To The Sensor. I'm Getting 5.1 Volts On One Pin And 6 On Another. Aren't I Supposed To Get 12 Volts Here Instead Of 6?
mart443
MERCEDES BENZ SLK350
Removing Front Console Trim?
There Is No Problem. I Need To Remove The Top Of The Front Console To Install Some Wiring For Ham Radio Equipment.
mzambory
18 IMAGES
LINCOLN NAVIGATOR
Truck No Start. No Fire To Coil
I'm Putting A New Pigtail On The Ignition Coil. I Need To Know Exactly What Wires Go Were. Someone Else Had Taken The Old One Off. The...
Jonathan Moses
A Step-by-step Guide On Replacing Timing Chain Cover...
Timing Chain Cover Leak.
nate.nichols5640
Where Is The Signal Flasher Located?
Where Is It Located?
Jesse Martin
MERCURY MONTEGO
Electronic Throttle Body Feedback?
I Was Doing Some Fuse Testing With Key On / Engine Off And Noticed Both My Throttle Bodies Making A Loud Electric Feedback Sound. When The...
Bill Marshall
INFINITI G37
Air Bag
My Air Bag Is Sticking Out Of The Holding Compartment, Is This A Problem?
Schmeebee
Airbag Is Showing Outside Compartment After Being In...
The Vehicle Was In An Accident Two Months Ago And The Air Bag Is Showing Outside Compartment, Is This Dangerous?
Schmee
Front Brake Sticking And Smokes Lost?
Lost Brakes So Replaced Master Cylinder Bleed Them And After 10 Minutes Of Driving Front Passenger Side Locked Up. Replaced Brake Shoes...
Mary Bruce
DODGE DURANGO
Engine Making New Noises?
Other Than The Ticking, Which Is Normal For This Engine, I've Recently Had This Engine Start Making A Noise Similar To When You Run An...
immaguy1234
My Brake Light Stays On At Certain Time?
I'm Actually Using Perodua Axia Or Similar To Toyota Agya Or Daihatsu Ayla. I Would Like To Know What The Problem With My Brake...
PG Khairil Qayyiz
24 IMAGES
TOYOTA VIOS
Car Stalls When Put In Drive, Works Perfect In Park...
My Daughter's G5 Was Having Real Problems Running. Bucking, Hesitating Intermittently. Then A No Start. Power Everywhere But Would Not...
Leigh Daniels
PONTIAC G5
Will Not Start?
Getting Gas Has Hot Spark But Will Not Start.
stevenriggle
TOYOTA TACOMA
Radiator Fan For Engine And Air Conditioning In One?
My Car Has Only One Radiator For Both Function For The Engine And Air Conditioning And I Would Like To Know In Case The Air Conditioning...
junior1964
HYUNDAI ACCENT
Will Not Start?
I Bought A New Fuse Box Because My Fuses Would Burn Out As Soon As I Turned The Ignition. I Bought New Fuses, But It Continued To Do The...
shindaboo1990
CADILLAC ESCALADE
Passenger Side Rear Light Assembly?
The Led Lights Go Off And On When I Touch The Wiring Harness For The Led Lights. There Must Be A Short. Is This Fixable Or Do I Need To...
phoneman65
TOYOTA PRIUS
698
699
700
