Warning On Dash Says Right Directional Not Responding?
This Vehicle Is A Denali, So It Has All Digital Lighting. Right Directional Start Off Normal Then Speeds Up.
jauto1
Brake Problem
Hello! I’ve Got An Issue With The Front Driver Side Braking System. I Thought It Was The Brake Caliper But I Got A New One And It’s...
beetlepunk21
Fuel Gauge Wiring?
Good Afternoon, I'm Looking For Some Information On How The Wiring For The Fuel Level Sending Unit. Specifically, I'm Hooking Up...
Jerebax
Codes P0101 And P0102, Jerking When Accelerating?
When Taking Off At A Light And When Shifting From First To Second, Even To Third The Vehicle Jerks Or Acts Like It Does Not Have Enough...
azdanno04
Do You Need To Remove The Transmission To Remove The...
Do You Need To Remove The Transmission To Remove The Engine?
CyrillaFuller
ISUZU RODEO
Puddle On The Floorboard The Next Day After Adding...
No A/c Compressor Works Both Engine Fan And A/c Fan Don’t Work But Found A Puddle In Floorboard Next Day After Putting Freon In It. I...
Cory2427
19 IMAGES
TOYOTA CAMRY SOLARA
Heating And Air Conditioning Blower Fan Will Not Come...
Heating And A/c Fan Not Blowing Any Air Out Of It. It Worked Just Fine This Morning And Now It Won’t Turn On At All. What Could Be Wrong...
Heather Streator
Acceleration Noise?
The Car Sat For A Little Over A Year. No Clue If It Was Making This Noise Before That. I Was Doing Some Wot Pulls To Clear Out Cobwebs...
highmileageg35sedan
INFINITI G35
Will Not Stay Running?
Recently Replaced The Battery And Now The Vehicle Will Turn Over At Start But Won’t Stay Running. Any Thoughts? Thank You!
Selina Coburn
3 Out Of 4 Doors Quit Working On The Same Day?
One Day Out Of Blue 3 Of My 4 Doors On My Car Listed Above Wouldn’t Open From Inside And Passenger Rear Won’t Open From The Inside Or...
MansonMauler
BUICK PARK AVENUE
Crank, Start, No Communication?
Okay, So My Husband Changed The Transmission. The Next Day We Got To Drive It. It Went In Reverse And Everything. Well, That Night The...
Morris8786
HVAC Started Intermittently Swapping From A/C To Heat...
I Feel Like A Complete Idiot For This And Me And My Dad Are Very Mechanically Inclined And Have Been Working On Vehicles For Years. Years...
tbradbowen121820
Battery Light On And Code B1676?
The Alternator Is Charging At 14.39 With Nothing On, And 14.43 With The Lights On. I Ran Obd2 Check On The Battery And The Alternator. The...
rbray61967
LINCOLN NAVIGATOR
Camshaft Position Sensor Pigtail, Wiring Diagram...
I Had To Change The Pigtail To The Camshaft Position Sensor, And I Do Not Know What The New Colors Go, Or How To Hook Up The 3 Wires?
Cnicholls21
PLYMOUTH BREEZE
M28 Fuse In TIPM Always Shorts When Power Is Applied?
I Don't Know If I Have Short In The Tipm Or On Somewhere Along The Wire. I Disconnected The Connector To The Ecm And It Still Short. So...
rudylauretta
JEEP WRANGLER
Security System Engaged And Not Resetting?
The Alarm Started Going Off When We Unlocked The Driver Door With The Key And Would Not Reset. Tried Disconnecting Battery, Which Did Not...
Fireman70
Power Steering Noise When Turning?
The Car Listed Above Is A 328i. Power Steering Sound, Squeaky, Whining Noise When Turning. The Reservoir And Hoses Have Been Replaced...
Bubbatl19
BMW 328
Overheating Engine?
It Wasn't Overheating Before, But My Heating Valve Broke And Was Spitting Coolant Out. I Changed The Piece And Added More Coolant Now...
Darkrise92
Upper Oil Pan Removal
Can't Get Pan Off Silicone Used Previous Owner
davidpjones
Previous Owner Siliconed It No Gasket Or Rtv Sealer Lower Pan Removed All Bolts Are Out But Just Stuck On With Silicone How To Get It Off
davidpjones
Code P2096, Post Catalyst Fuel Trim System Too Lean...
I Have The Vehicle Listed Above 3.0si And Received The Code P2096. I Have Changed The Downstream Injector. However, There Does Not Seem To...
marian1561
BMW X5
Wiring Diagrams For The Turn Signal Switch, BCM, And...
I Need Wiring Diagrams For The Turn Signal Switch, Bcm, And Fuse Boxes Etc, On The Vehicle Listed Above Lt Model.
Mkluera86
Turn Signal/headlight/brake Light Issues
I Am Trying To Figure Out Some Electrical Issues For A 2016 Chevrolet Equinox Lt. I Was Hoping You Could Provide Wiring Diagrams For The...
Mkluera86
Ground Issues?
Need Help With Figuring Out My Trucks Issues After Engine Swap
Russelltreeworks
Crank Position Sensor Wiring Identify?
I Was Replacement The Crank Position Sensor With A New On But When I Pulled The 3-wire Connector The 3 Wires Pulled Out From The Connector...
Raul1945
TOYOTA TACOMA
700
701
702
