Wiring Diagram To The Crankshaft Sensor And Camshaft...
Please, I Need The Correct Wiring To My Crankshaft Sensor And Camshaft Sensor. The Socket Is Broken, And The Technician Is Unable To...
Omohimi
Oil Leaking Bad?
The Car Just Stopped Yesterday And Had Oil In It A Couple Of Days Ago, Looked Under Car And A Massive Puddle Of Oil, But Not By Engine In...
Clara cloggs
VAUXHALL CORSA
Engine Rotor Without Ignition Switch
When I Put The Battery Rods, The Engine Starts Turning Without Turning The Start Switch Note. Engine Reassembled
Ahmed. Gedrabo
O2 Sensor
How Many O2 Sensors Do I Have And Where Are They Located. I Have A Code Trading O2 Sensor Bank 2 Bad
beccaorefice
GMC ENVOY
Valve Cost Replacement And Other Issues Besides The...
I Have A Potential Vehicle Listed Above Impreza; The Mileage Seems Relatively Low. The Problem Stated Is That The Valves Are Bent Because...
milk73838
SUBARU WRX
Replacing The Front Lower Ball Joints, Detailed...
Hi, I Just Found Out From Les Schwab After Trying An Alignment That I Need Both Front Lower Ball Joints Replaced. Please Keep In Mind That...
Talonluvswifi
A/C Front Vents Not Blowing Any Air?
The Front Vents At Times Were Not Blowing Any Air, Cold Or Hot, And Seemed To Be Going Towards The Defrost Vents. The Rear Vents Worked...
dmen05
Socket Size For The T Bolts That Mount The Lower...
What Socket Size Are The T Bolts That Mount The Lower Intake Manifold Down?
Shane Gaspard
MERCURY SABLE
A/C Blower Stopped Working?
I Have The Auto Temp Control Panel. Pulled The Plug On The Motor, Hooked Up 12v And It Spins Great. Removed The Regulator And Checked The 3...
rhensonsr
LINCOLN NAVIGATOR
Leaking Oil
Is The 2005 Worth Keeping?
Mark Inzeo
MAZDA TRIBUTE
The Alternator Does Not Charge The Battery?
The Alternator Does Not Charge The Battery Unless I Unplug The Connector That Runs To The Pcm.
wishfb
Where Is The Camshaft Position Sensor B Located?
I Have Codes For Camshaft Position Sensor Bank 2 Sensor B Circuit Malfunction And Intermittent. I Can Only Find 2 Sensors On The Front Of...
jasonlr06
Shocks Replacement?
Hi, Could You Tell By Looking At The Pictures If A Standard Shock Works For My Truck Or If It Is A 1" Lift Or 2" Lift. ...
pprince72
Shocks
Hi, Could You Tell By Looking At The Picture's If A Standard Shock Would Work For My Truck Or If Is A 1" Lift Or 2" Lift. Thanks...
pprince72
Making A Hissing Noise, Like A Flat Tire?
It's Not Overheating, And I Don't See Any Fluids On The Ground. Any Thoughts?
djdeshhay80
LINCOLN MKX
After Installing A New Rack, As I Turned The Wheel...
I Put A New Rack In And Got It Aligned Again. Then I Heard A Pop Sound As I Turned My Wheel And My Steering Started Turning Loosely. Then I...
Derekrehn95
GMC ENVOY
Truck Will Not Start After Replacing The Alternator/...
My Truck Was Making A Bad Squealing Noise When Accelerating Into 1st And 2nd, So I Replaced All 3 Belts: Alternator/fan, Power Steering...
Jacob.burdett
TOYOTA PICKUP
Car Will Not Start After Replacing Belts
Truck Has Been Squeeling And So I Replaced All 3 Belts, Alternator/fan, Power Steering, Ac. After Replacing The Car Will Not Start It...
Jacob.burdett
TOYOTA PICKUP
Seat Flip Lever Does Not Work?
The Car Has Power Driver Seat, The Flip And Slide Lever On The Driver Seat Doesn't Function. Is This Because Of The Power Seat? Or...
citygr
CHRYSLER SEBRING
Voltage Issues On Compressor?
I Have Replaced The Compressor; The Car Is Throwing No Codes For The "f" Codes So No Problem There. I Also Checked All Of The...
Eggbeeter
CADILLAC SEVILLE
Is The Stock Horn A High Or Low Note Horn?
Essentially, The Title Is The Entirety Of My Question. I Just Want To Know If The Stock Horn In The Vehicle Listed Above Wagon Is A High Or...
Wagonbro33
After Shutting Off While Driving The Engine Cranks But...
I Was Driving And The Car Just Shut Off And Tried Turning On Cranks But Won’t Start.
Edwinq
HONDA CRV
After Vehicle Sits For A Little While The Transmission...
Transmission When You Start The Car It Goes In Drive Good Goes In Reverse Good Sets And Runs For A Little But Get Back In It And Put It In...
ts4092214
BUICK VERANO
Camshaft Phasers?
So Recently I Have Had A Rather Large Repair Done On My Car. They Replaced The Timing Chain, The Head Cover Gasket And One Of The Cylinders...
ImmortalRon
HYUNDAI GENESIS COUPE
Code P0244?
This Is Actually For A 2014 Maserati S Q4, I Could Not Find An Option For It. It Feels Like A Limp Mode Where Revving The Motor The Pedal...
MERKUR SCORPIO
578
579
580
