When I Start The Car The Instrument Cluster Stops...
The Instrument Cluster Works With Key On Without Engine Running. As Soon As You Start The Car The Cluster Stops. The Voltage Regulator...
jasonlr06
VOLKSWAGEN RABBIT
Torque Value On The Inner Tie Rod To The Steering Rack...
Looking For The Torque Value On The Inner Tie Rod To The Steering Rack.
yellsnake
SATURN SL1
Aftermarket Radio On But No Sound?
I Bought An Aftermarket Radio, It Turns On Everything Works There Just Isn’t Any Sound At All.
Celso1211
ACURA RL
Check Engine Light On And Check Fuel Cap?
My Check Engine Light Came On I Took It To Autozone They Said It Was An Evap Leak Next The Check Fuel Cap Light Comes On I Replace The Gas...
Mchildrey
FORD EXPLORER SPORT TRAC
Hit The Throttle Pretty Hard To Get Out Of The Mud And...
I Replaced My Power Steering Pump A Couple Months Ago And The Other Night I About Got Stuck Out In A Pasture And I Had To Hit The Throttle...
gilner678
Hit Guardrail, Could Reverse, Couldn't Go Forward.
A Few Days Ago While On The Interstate Highway, My Wife And I Were I Our 2006 Chevy Cobalt And A Pickup Stopped Short, Right In Front Of...
WillyMassey05
Passenger Side Low Beam Headlight Do Not Turn On, Low...
I Have The Truck Listed Above Silverado Wt. The Passenger Side Low Beam Headlight Does Not Come On. The Other Headlights Are All Working....
Dave Tobias
CHEVROLET 1500
Vibrates Between 35 And 56 MPH?
The Vehicle Listed Above Drives Good Until It Reaches Between 35 Mph And 45 Mph Then It Starts To Vibrate Or What Some People Call A Shudder...
mattlon910
JEEP LIBERTY
Fuel Range Currently Fluctuating And Inaccurate?
What Part On The Car Listed Above Reads The Fuel Range And How Many Miles Until Empty Because Mine Is Currently Fluctuating And Inaccurate....
David Chandler Farr
Low Oil Pressure?
The Vehicle Listed Above B7, Needs Repairs. Insufficient Oil Drained (1-2l Below Recommended). Odd Since I Recently Replaced It, Used...
Chefkoch257
26 IMAGES
AUDI A4
The Truck Listed Above Has A Carburetor, Where Can I Find The Fuel Filter?
lsiedow17
MAZDA B2200
Cylinder Eight Not Getting Any Power?
Cylinder 8 Ignition Coil Isn’t Getting Any Power At All. Coil Is New. What Do I Need To Look At To Diagnose Why It Isn’t Getting Power?
terraraine
Malfunction Indicator Light Start Blinking?
Car Start Driving Badly.
pafka2
HYUNDAI ACCENT
How Do You Replace The Radiator On The 2000 Dodge...
I Hit A Deer And It Busted The Radiator Now That I Have The New Radiator I Have Taken Out The Radiator Hose, Lower Fan Shroud, Coolant...
Bossman6225
Growling Noise While Driving?
Hey, I Bought The Vehicle On 3/23 And Noticed A Low Hum During The Test Drive And Didn't Think Anything Of It. When I Drove It Home On...
bayka
Rear Axle Nut Torque Specifications Needed?
I Have The Bearing Assembly And Replacement Axle Hub Niy, But Can't Find The Torque Specifications For The Rear Assembly.
dcreed
Stall When It Is Warmed Up?
Hello, I Am Having An Issue With The Vehicle Listed Above Se Model. The Abs, Esp, Traction Etc, All On. Check Engine Light On....
Johnathan Chipman
VOLKSWAGEN ROUTAN
Metal-on-metal Grinding Sound?
I Pulled Out From My Mother's House, And It Was A Metal-on-metal Grinding Sound. It Was Extremely Loud And The Only Time It Stopped Was...
Nicholemildenberger
No Power To Convertible Top Button?
Finished Installing The Top Motor And Tried It Several Times, All Good. I Go Today And Press The Button And There Is Nothing, No Power...
BMW 330CI
Brakes Locking Up, Airbag, ABS And Traction Control...
Hi, I Have The Vehicle Listed Above Lx Model. After Driving For About 10 Minutes Or So My Brakes Lock Up And The Brake Pedal Is Hard. After...
Lisa Darnell Gallups
KIA SPORTAGE
Air Conditioner Not Working Properly?
Since The End Of Last Summer My Car’s A/c Hasn’t Been Working Right. Some Days It Might Stay On For 10 Minutes, Then Even Though...
victoriawestx
VOLKSWAGEN JETTA
Codes P1820, U1000, And P1808, Engine Cranks But Will...
Please, I Am Having This Issue With My Car, It Won’t Start But It Cranks. I Have These Fault Codes P1820 And U1000 As Well As P1808....
Andrin Atem
NISSAN XTERRA
There Is A Clicking Noise When Turning Right, Could It...
The Front Driver's Side Makes A Clicking Noise When I Turn Right. Well, Yesterday It Made It Then A Hard Clunk And Felt Like Tire Would...
Chicks78
LEXUS LX 450
TPS Has 5v In Ground Wire?
My Car Is A 2004 Kia Morning (i Live In Asia) But I Think The Car Is The Same As The Kia Picanto. My Car Has High Idle And Fluctuating....
Leslie Payne
91 IMAGES
KIA PICANTO
Loss Of Power, Fuel Pressure?
Loss Of Power.
John04
CADILLAC ESCALADE EXT
577
578
579
