How To Replace The Chain Tensioner?
Any Instructions On How To Replace The Tensioner?
MERCEDES BENZ ML350
Will Not Start, Gear Will Not Lock In Park?
Car Won't Start Gear Won't Lock In Park Without A Jiggle.
Patricia361
GEO PRIZM
Turn Signal
Right Rear Flashes Fast But No Power To The Right Front Turn Signal. Bulbs Are New X3. All Fuses Test Good. Am I Missing Something?
Dale Newsome
Heating And Cooling Fan Not Working?
The Blower Was Only Working On High, Picked Up Used Motor, Relay, And Resistor. Swapped Out Relay, Not Fixed. Swapped Out Resistor, Not...
lkeeslick
CHEVROLET HHR
No Start?
I Recently Drove My Car From Oshkosh, Wi To Winona, Mn, Which Is About A 3.5-hour Drive. Stopped To Get Fuel And Potty Stop. Came Back...
Craig Lockwood
BUICK LESABRE
Cooling Fan Only Operates On Low Speed?
The Cooling Fan Turns On And Off With A/c Compressor But Only At Low Speed. Checked Tested Relay, Fuses. Tested Cooling Fan, Highspeed...
Voodooskyline
TOYOTA HIGHLANDER
Codes P0068 And P0101, And Reduce Engine Power Message...
I Am Getting The Following Codes: P0068 And P0101. I Am Also Getting A Reduce Engine Power Display. I Have Replaced The Maf And Map Sensor...
Ronald DeVold
Idler Pulley Bearing Question
The Pulley Has Been Removed. So The Question Is When I Purchased The New Idler Pulley The Inside Bearing Is Sealed. And The Hole Is Without...
JC-842
Idler Pulley Bearing Question?
The Pulley Has Been Removed. So, The Question Is When I Purchased The New Idler Pulley The Inside Bearing Is Sealed. And The Hole Is...
JC-842
Air Conditioning/Replacing Blend Door Actuator
My Air Conditioner Worked Great And Then Out Of Nowhere, One Day A Couple Weeks Ago All The Sudden It Started Blowing Only Hot Air. No...
Karma Berg
BUICK RENDEZVOUS
Codes PO 191 And PO 191, Crank But No Start?
Car Sits More Than It’s Driven. Replaced Fuel Filter, Fuel Pump Driver Module, Has Plenty Of Fuel In Tank. Runs When Starting Fluid Is...
StrictlyDimes
LINCOLN TOWN CAR
Air Conditioning/Replacing Blend Door Actuator?
My Air Conditioner Worked Great And Then Out Of Nowhere, One Day A Couple Weeks Ago All Of A Sudden It Started Blowing Only Hot Air. No...
Karma Berg
BUICK RENDEZVOUS
Stuck In 2 Or 3 Rd Gear
It Will Shift And Park Reverse Neutral Drive But It's Stuck In The Second Or Third Gear And It Won't Move Any Idea What This May Be...
Vipers1
CHRYSLER SEBRING
I Would Like To Know Where The Fuel Filter Is. Regards, Oleg
Oleg Panciuc
VOLVO V50
No Power And The Engine Is Rattling?
My Serpentine Belt Broke So I Replaced It The Belt Tensioner Now My Engine Is Making A Rattling Sound.
Derekr1988
Knowing What Type Of Refrigerant Is In My Car?
I’m Having Issues Knowing What Type Of Refrigerant Is In My Car. The Hood Doesn’t Have The Type And I Don’t Know If Both R134a And...
Nxra
Will Not Start?
3 Weeks Ago, The Car Would Not Start. Turned Over Yet Sounded Like No Fuel. Prepped Car To Do Fuel Pump. Disconnected The Negative Cable On...
Myrrddyn333
SUBARU OUTBACK
I Need To Rewire A Crankshaft Position Sensor?
I Need To Rewire A Crankshaft Position Sensor All The Way Back To The Ecu, Assuming That Is Where The Sensor Is Connecting To. The...
brianjh
Replacing The Clutch Plate And Pressure Plate?
Trying To Change The Clutch Plate And Pressure Plate Period The System On It Is A Dual Clutch Plate System, But The Auto Parts Stores Only...
Tankk2014
Dash Lights All Came On At The Same Time ESP, The ABS...
The Dash Lights All Came On At The Same Time. They Are The Esp, The Abs, The Esp/bas And The Service 4wd. Other Than That, The Cars Runs...
Rockyxx
JEEP LIBERTY
How To Replace The Alternator?
Any Diagrams On How To Remove And Replace An Alternator For The Vehicle Listed Above?
lionell8732
MERCURY MILAN
Door Adjustment
How Do You Adjust The Striker Plate On The Door
tomjjonas
CHEVROLET 2500
RPMs Shoot Up?
Truck Is Manual, When I Was Driving And Came To A Stop The Rpm Would Stay Up When I Took It Out Of Whatever Gear It Was In And If I Put It...
Santiago Ramirez
No Crank, No Start
When I Turn The Key Fob The Instrument Cluster Comes On But Won’t Crank Or Anything. Just Acts As If The Battery Is Dead. Check Battery...
Jere Lebowsky
CHRYSLER TOWN AND COUNTRY
When Pushed, The Air Button On The Control Will Not...
The Fuses Under The Hood And Compartment On The Passenger Side Near The Blower Motor Have Been Checked. Also, The Panel Was Taken Off To...
infinitelove
579
580
581
