Electrical Issues After Changing The Battery?
Hi I Have A 2014 Hyundai Veloster Base Model (non-turbo), Last Week I Started To Feel That The Battery Are Dying Till 2 Days Ago The...
tiesto870
HYUNDAI VELOSTER
Transmission Shifting Issues Jumping Out Of Gear While...
I Recently Started Having Shifting Issues With My Van With Jumping Out Of Gear While Driving And Not Wanting To Go After Stopping. It Would...
mgoblue78
Cruise Control Inoperative?
Cruise Control Will Not Work At All, Not Even The Indicator Light. When I Pulled The Connector On The Cruise Control Module And Checked For...
RCH
P0562 System Voltage Low Code
Okay I Got This Code To P0652 System Voltage Load Code On The Chrysler 300 A Month Before It Actually Stopped Turning On And The Windows Don...
Jaimejcr
Heater Only Stay On Vent Won’t Transfer Vents?
My Heat And Air Works Good But They Only Stay On Vent Won’t Transfer To Defroster
Kb1012021
F150 2.7 Ecoboost Crankshaft Position Sensor Location?
I Can't Seem To Locate The Crankshaft Position Sensor On My 2016 F150 2.7l Ecoboost Engine. There's Tons Of Literature And Videos...
Oboy2010
None Of My Windows Work?
I’ve Changed The Main Switch And Still Have Nothing They Light Up But Don’t Roll Down
Bigtwan82
CHEVROLET HHR
Transmission Fault
If I Start The Vehicle It Will Run And Accelerate Normally But When I Engage The Gear The Engine Will Shut Down Automatically.
Adewole
Power Steering Pump/Belt?
I Had Been Hearing A Lot Of Whining From The Power Steering Pump For A While Previously. My Power Steering Seemed To Be Fine And I Checked...
Packers27
Serpentine Belt Bypass Ac Compressor?
How Do I Bypass The Ac Compressor To Put On A New Serpentine Belt
rebecca99
Overheating With No Coolant Leak?
I Have A 2017 Volvo S90 T6 Inscription. 177k Miles. Car Overheating. No Coolant Leak. I Need To Change The Thermostat & Intake Manifold...
Mrs. Frasier
VOLVO S90
Engine Water And Oil Mixing?
Water And Oil Mixing I Was Told To Change The Head And Intake Gasket It Will Fix The Issue Or Would Be Better To Get A New Motor
Willie_6
CHEVROLET 1500
Low Heat - Heater Blows Cool?
The Heater Blows Cool Air Unless The Temp Is Set To Maximum. I Intended To Perform A Heater Core Flush At Home, But I'm Having Trouble...
jkerley14
2022
Pressed Hazard Button And Stereo Died?
Was Dropping Off A Friend Today And Because There Wasn’t An Actual Spot To Park I Just Pulled Over And Pressed My Hazard Button And...
CrazyColletti
KIA RIO
AC WARM ON PASSENGER SIDE?
I Checked With The Gauge And It Showed Full. Added Some And Then Both Sides Started To Go Warm, Released The Extra And The Driver Went...
divides
LEXUS IS 250
Programming LED Daylight?
I Saw That One Of The Halo Lights On Passenger Side Was Weak Compared To The Second Halo Light In The Same Headlight On Same Side, While...
divides
BMW X1
Headlights Flash About Once An Hour?
I Have Installed Plug And Play Led Lights On My Ford. I'm Pretty Sure This Started Before I Changed The Headlights. About Every Hour...
Davenoob
FORD FIVE HUNDRED
Toyota Corolla E180 Smart Junction Box Pinout Diagram?
Hi! I Am Looking For A Pinout Diagram For A 2014 Toyota Corolla Zre181. This Is The European Version Of The E180. Their Pinouts Are Likely...
tomcatmwi
Engine Swap 5.4L Triton?
Hi, I Have A 2001 F250 That Need The Engine Replaced. I Was Given A 5.4l Triton And Its From A 2004, Can I Transfer The 2001 Intake...
Wyo_307
Pressure Power Steering Line?
I Am Newer To Repairing My Own Vehicle. I Know I Need To Replace The Power Steering Line As It Is Leaking. Is There A Diagram For How It Is...
b74629242
Where Is The Camshaft Position Sensor Intake Side...
I Cannot Find The Camshaft Position Sensor On The 5.0 V8 Flexfuel F150
Bam84
Torque Specs
I Am Helping Senior Women To Fix Her Car For Free. Her Rear Knuckle Bushings Are Bad. So, I Would Like The Know The Torque Specs Of 1....
Yazidan
Engine Question
Replaced Alternator Now Car Won't Start, Mechanic Says The Engine Is Carbon Locked. During The Process Of Disconnecting The Alternator...
dchavez217
NISSAN MURANO
Engine Question
I Had An Oil Change Done Last Monday And There Was A Knocking/grinding Sound By My Front Passenger Side, My Husband Was Told That It Was A...
dchavez217
NISSAN MURANO
I Need To Pressure Wash Belt Side Of My Engine
My Impala Blew Front Main Gasket And Sprayed Oil Everywhere. I've Fixed The Gasket, Changed Belt, Cleaned All The Pulleys But The...
Davenoob
7
8
9
20251
