I Need To Pressure Wash Belt Side Of My Engine
My Impala Blew Front Main Gasket And Sprayed Oil Everywhere. I've Fixed The Gasket, Changed Belt, Cleaned All The Pulleys But The...
Davenoob
Driving Home The Temp Gage Shot Up To H?
The Car Was Running And Driving Fine, Minus Sometimes The Heat Was Blowing Cold Air. The Car Died While Parking, But Was Able To Start...
agalindo25
BCM Body Control Module Location And Replacement?
I Can’t Find Any Good Videos For How To Find The Bcm In A 2008 Toyota Avalon. I Was Going To Pull The Part From A Junk Yard.
JAZ.caz
TOYOTA AVALON
Clicking From Back Wheel?
This Only Happens Occasionally. When I Accelerate There Is A Clicking Noise What I Can Only Describe Sounds Like A Hammer Hitting Something...
JThornburgh
BUICK ENCLAVE
Warning Chime When Moving?
As Soon As The Vehicle Is Put In D Or R The Warning Chime Starts. All Doors, And Rear Gate Are Closed. Nothing Weighting Down Any Seat...
Freerider78
Dash Cluster Illumination Do Not Work?
Dash Cluster Illumination Do Not Work. Nor Do The Climate Control Lights, Steering Wheel Lights, Or Taillights Work. One Day They All Just...
Jarodlong02
BUICK LESABRE LIMITED
Lights Camera Action No Wait No Lights
Literally Everything Was Fine Everything Was Working Great Then All Of A Sudden I Learned That I Didn't Have A Blinker On The Passenger...
Piztol78 l
NISSAN TRUCK
Passenger Seat Fuse Keeps Blowing?
I Replaced It And I Moved The Front And Back Portion And All Was Good. Next Day I Came To Checkout And It Stopped Working. I Need To Know If...
divides
BMW X1
Replace Engine From Another Company?
Hello Mechanics, I Would Like To Ask If It Is Possible To Change The Engine Of A Mazda 323 Four-wheel Drive And Install An Engine From...
abdoammar
MAZDA 323
No Fuel Pump Power?
Car Would Not Start, Turn Over But No Start. Had It Towed Home. When Try To Start Seemed Ign. Switch Would Stick In Start Position. Replaced...
Buick06
BUICK RENDEZVOUS
Fuel System Begins Pulsing?
I Have A 1995 Ford F150 4.9l Engine. It Will Start And Run For 30 Seconds To 1 Minute Then Shut Off Like It Loses Power To Engine. When It...
revkev316
Engine Vacuum Diagram 2.0 Turbo
Need A Full Vacuum Diagram For A 2009 Chevy Cobalt Ss 2.0 Turbo
Cashmoney8912
Vacuum Diagram
Cashmoney8912
Loose Strut/shaking?
So I'm Following Up To This Old Question Linked Below: Https://www.2carpros.com/questions/strut-safety. I Had The Strut And Axle...
TheMailMan
CHEVROLET PRIZM
POOR MPG Even On The Highway?
My 2014 Camry Xle With 51k Miles Only Gets Around 20 Mpg Even On The Highway! Its 4 Cylinder. I Bought It In 2021 With 23k Miles. I Love The...
judymuratore
Transmission Will Not Engage In Reverse?
Will Not Engage In Reverse. It Goes In Every Other Gear And Shifts Through All Gears Just Fine. But, When I Put It In Reverse. Nothing!...
S.Blanton
CV Axle Hearing A Popping Noise?
I Changed The Cv Axle A Little Over A Week Ago. However About 3 Days Ago I Started Hearing A Popping Noise And A Scrubbing Noise While...
johnnydjames349
Brake Light Issues/Wiring Harness Issues?
I Recently Bought This 98 C1500 4.3 5 Speed Manual. My Main Brake Lights Do Not Work, But The Third Brake Light Does. I Have Changed The...
cavedude17
CHEVROLET 1500
Overheating When In Town With Ac On?
Cooling Fan Works With Direct Power But Will Not Otherwise. Fuses & Relays Are Good. Maf Has Been Replaced. Based On Research I Am Trying...
dcromeans
CADILLAC ATS
Locating The Knock Sensor?
Locating The Knock Sensor? Step By Step?
Kimberbaby
NISSAN FRONTIER
Spinning Starter Doesn’t Engage?
The Starter Spins But Doesn’t Engage. Found A Small Tag Wire That’s Attached To The Side Of The Negative Post That Was Unattached To Any...
Bwsmith73
How Much Is This 3000gt Worth?
It Has A Dent In The Driver Side Door But Has Never Been In Any Accidents, I Need To Replace The Steering Column, The Ignition Switch Is...
JamesTS
MITSUBISHI 3000GT
Connecting Front And Rear Shifter Cables
I'm Trying To Connect The Front Shifter Cable To The Rear Shifter Cable. The Connector Clip Won't Stay Put And The Service Manual...
Pitbullygirl
Hard To Start Press Gas Pedal Way Down?
It Is Hard To Start, Have To Press Gas Pedal Way Down. When It Does Start It Runs Great.I Have Replaced The Gas Filter And The Cannister...
KaraokeCowboy411
Ignition Switch Lock Position?
Switch Will Not Go Into Lock Position Even With Transmission In Park.
Eugene Linderman
8
9
10
20252
