O2 Sensor [post Catylitic Converter] For A 2001 Truck
I Have A Code [po160 Post Cat.] That Comes Up. I Replaced The Sensor And The Code Came Back. I Then Replaced The Catylitic Converter And...
silverado
1999 Chevy Suburban
111k 1999 Suburban - Everything Fine Expect When I Try To Pass Or Start Out From A Stop At A Quick Pace. When I Do Either Of The Above....
HOTSHOT
Ford Contour GL...need Help ASAP!!!!!
Hi, I Am The Owner Of A 1998 Ford Contour Gl, Automatic Trasmission. I Just Had To Get A New Battery Installed The Day After...
TasharaJay
FORD CONTOUR
Replaced Starter Now Car Won't Turn Over, PLEASE...
I Just Replaced It And Now Car Wont Turn Over. Is It Possible I Messed Up The Wiring With The Starter Or Installed It Wrong. It Has Been...
steventheseeker
Stereo Keeps Blowing Fuses
I Recently Tried To Fix My Broken Cigarette Lighter In My, And Accidently Disconnected Some Wires Connecting My Fm Modulator To My Stereo...
dbbooh01
A/C Problem For 1998 Dodge Caravan
My 1998 Dodge Caravans A/c Will Sometimes Not Work And Then Will Turn On All Of Sudden After Driving Or It Will Work When I Start The Engine...
cerilu
1983 Bmw 320i
My Car Wants To Stall When Started In The Morning Unless Gas Pedal Is Applied Generously And Will Frequently Stall At Stops Until...
ultraviolet39
1983
BMW 320
300zx Squeaking Noise
When I Turn On My Engine, There Would Be A Squeaking Noise And It Squeaks When I Drive Also. After I Gain Speed Or The Engine Is Warm Then...
a3z0n0zx
1930
Ford Alternator Low Output
I Have An 85 F-350 And The Alternator Does Several Things Only Two Make Me Want To Shoot It 1 St Things Is Under A Load The Alternator Get...
woodmanscott
FORD F-350
Dodge Intripid 1993 Fuel Rail Problem
How To Fix A Leaking Fuel Rail? Thank You. Guillermo A.
Guillermo Acevedo
1989 Cutlass Supreme Stalling
I Recently Purchased A 1989 Cutlass Supreme 3.1 V6. The Car Is In Good Shape And Has 100,000 Miles, However It Has Not Been Driven For 3...
kenter
95 Bronco Front Wheels Engaged ?
I Have A 1995 Bronco Xlt Don' Know How To Check If Front Wheels Are Actually Engaging, In 4hi Or 4l. We Were Wheeling, Backs Would Slip On...
nickyd
Check Engine Light Problems...
I Have A 97 Honda Civic And My Check Engine Light Come On A Few Weeks Ago. So I Got The Codes Back From Advanced Autozone: P0420...
melody7844
Check Engine Light
My Check Engine Light Came On. When I Pulled Over I Noticed My Car Was Leaking Water. When I Tried To Start The Engine Again It Would Not...
mredford
1997 Buick Skylark Keyless Entry
My Fob Responds To The "lock" Button, But Not The "unlock" Or "trunk" Buttons. I Imagine This Is An Issue With The Remote Accessory...
Emmy
BUICK SKYLARK
Transmission Problem
Automatic Transmission Had 160,000miles. The Problem That I Have Is The Transmission Will Not Engage Into Reverse Mode When Hot. Before...
ballybunion
How Can U Tell If I Need To Change My Timing Belt?
I Have A 96 3000gt I Was Wondering If There Is A Way To Tell If I Need To Change The Timing Belt Yet Or Not.
3000GT96
Started To Cut Out When Decelerating To A Stop?
My 95 Transpor Van Has Recently Started To Cut Out When Decelerating To A Stop - The Engine Starts Hiccuping From 40km Down To About 10 Km...
neatappearances
PONTIAC TRANSPORT
Water Pump How Do I Access The Lower Three Socket...
I Have A 96 Sable (duratech Dohc). How Do I Access The Lower Three Socket Bolts On The Water Pump? Hope I Havent Bitten Off More Than I Can...
glitteringtop
MERCURY SABLE
Transmission Failure ??
Appears To Slip Out Of Drive And Into Neutral When Stopped Briefly At A Light. When I Turned The Ignition Off, And Re-started It, Put It...
windsong1
99 Ford Explorer Will Not Start
1999 Ford Explorer 75000 Miles Ran Great Until Yesterday. Drove Short Trip Ok. Returned To Vehicle. Cranked Normal. Would Not Start....
marife
Rpm's Too High
Recently I Have Noticed That It Seems To Drag When I Let Off The Accelerator And When I Took It On The Highway The Rpm's Are Rising...
trudy
1987 Oldsmobile Cutlass Ciera Shut Down While Driving
It Just Cut Out While Driving Along Just As If I Ran Out Of Gas. What Can It Be?
nashy
Volkswagen Dealer/Drive Belt
Recently I Took My 98 Volks Golf To Dealer To Have Clutch Replaced, When I Picked Up My Car Less Than 1/2 Mile Away The Car Starts To Stale...
mlbridges2024
Help. Just Inherited 1999 B3000 Truck And It Won't...
My Stepfather Died Thursday And My Mother Has Given The Truck To My Son Who Must Drive It 7 Hours To Nashville In The Morning And We Can't...
georgel
MAZDA TRUCK
20244
20245
20246
