94 Lumina APV TBI Problems
I Have A 94 Lumina Apv With A 3.1 Engine. I Parked It And Went To Start It 1 Hr. Later And It Would Not Start. After Checking It Over I...
ronnied2000
Clanging Noise From The Front Left.
After Removeing The Driveline It Stopped. What Could It Be?
Ron
1997 Chevy S10, Problem Starting And Staying Running.
1197 Chevy S10 4.3 Won't Start And On The Rare Occasion It Does, It Missfires Badly And Dies. Checked Fuel Pressure, 62#. Static...
phtm409
Problems Car Starts Then Shuts Off Why??
Replaced The Dash And Column And All Wiring Except The Wire Inside That Heads Toward The Rear Ac. So Its All 98, The Front End And Computer...
untamedatom
My Tail Lights Quit Working?
My Tail Lights Quit Working, And Also The Dashboard Light Is Out As Well, Have Checked Fuses And Bulbs, And Also Looked At The...
slydogg007
1995 Pontiac Transport Wiper Motor
I Am Wondering Where The Wiper Motor And Module Are Located
Laura
PONTIAC TRANSPORT
2002 Gmc Envoy Problems
I Have A Couple Of Problems 1. The Keyless Entry System Has Quit Working, I Have Bought A New Key Fob And Programmed It With No Luck. I...
glennrainwater
GMC ENVOY
Won't Start?
Won't Start The Security Light Is Flashing I Had The Dealer Make A New Key But Still Nothing Is There A Way To Reset Or Bypass.
bnf1968
Engine Noise (popping)?
There Is Loud Popping Noise Near The Front Of The Engine. Performance Does Not Seem To Suffer. No "check Engine" Light. The...
kiernanf
Locking Differential
I Have A 2000 Silverado Z71, And I Want To Remove The Axles For Some Routine Maintenance. I Am Somewhat Familiar With The Procedure Of...
JGates
Tailgate Stuck
Hello - The Tailgate On My 2000 Silverado Z-71 Flareside Is Stuck Shut. I Have A Spray In Bedliner And Cannot See If There Are Any Screws...
Brik
Brake Lights Aren't Working At All?
The Brake Lights On My 99 Explorer Aren't Working At All. Mechanic Said It Was The Brake Switch So I Replaced It. The Lights Still Don...
yahdman
1999 Gmc Sierra 1500 C/k Two Questions I Have
Every Once In Awhile (ussually When I Drive Long Distances, And Sometimes When It Is Cold) My Truck Makes A Loud Ticking Noise. It Doesnt...
jsando18
Oil Pressure Drop
I Have A 92 Ford Ranger With 172,000 Miles On A 2.3l Engine. Last Week I Changed The Oil And The Following Day After About A Half Our Drive...
pikap417
Oil, Battery And Brake Lights Stay On?
After Starting Vehicle (runs Fine), Oil, Battery And Brake Lights Stay On. Radio Previously Did Not Work And Now Works. Occurred After...
mimoore5
1985
My '96 F150
A Tube Dealing With The Egr Is Disconnected And I Have Been Unable To Locate Where It Attaches. I Think It Is Robbing Me Of Gas Mileage And...
eldudoreeno
Ford Taurus
1998 Taurus With130000 Miles Idles Rough Code P0171 And P0174. I Replaced The Maf Sensor And It Still Idles Rough. What Is Next Step?
fdmcdonald
99 Blazer Oil Cooler Lines
I Have A Leak In The Oil Cooler Lines, Dealer Wants $450 To Repair, Sounds Like A Lot To Me, Parts They Said Were $150, Is This A Hard Job...
shuggy329
Both Taillights Are Out, However The Brake Lights Work...
Both Taillights Are Out, However The Brake Lights Work. So I Do Not Suspect It Is The Fuse. I Replaced The Tail Lights, And Still No...
mightymouse
My Kia Sedona Hesitates When I Hit Gas
Hi, I Have A Problem, I Got Gas Friday And I Noticed Sat Afternoon That My Van Was Running Funny. When I Start Out It Wants To Hesitate...
pnkraff
Tie-Rod End 1996 Dodge Caravan
I Had A Tie-rod End Break This Morning On A 1996 Caravan, Left Front Wheel Lower Back, Looking At It, It Looks Like I Could Loosen Nut And...
rickaylward
Brake Lights Don't Function?
All Of The Rear Lights Work, No Bulb Problem, But The Brake Lights Won't Work, Including The One In The Rear Window. Is This A Fuse...
ecephas
Oil In Washer Fluid Reservoir
Ok, I Know This May Sound Stupid; But My 16 Year Old Daughter Put Used Motor Oil In The Windshield Washer Fluid Reservoir. Does Anyone...
kneag
90 GMC Sierra Doesn't Start
My 90 Gmc Sierra (7.4l) Does Nothing When The Key Is Turned In The Ignition. I've Eliminated The Battery As A Culprit (replaced With A New...
nvr2nd
Trouble Removing A Bad Wheel Hub
I'm Having An Extremely Hard Time Removing The Wheel Hub From The Drivers Side Front Of My 1989 Ford Tempo? Ive Tried Everything Short Of A...
dljohnson
20243
20244
20245
