93 F150 Ignition Switch
What Does It Entail To Replace The Switch.
ghoff
ALL OTHER MAKES
Power Door Lock Malfunction
I Have A 2001 Chevrolet Monte Carlo And Last Week The Doors Started Locking Automatically. While Driving And Even After The Car Is Turned...
shonta.1
Heater I Get A Short Blast Of Warm Air And Then It...
I Have A 1998 Ford Taurus With 135,000 Miles. It Has Been A Good Vehicle, But I Have Run Into A Problem I Can't Solve And Neither Can...
Buzz13
Radio Lights And Clock Do Not Work Anymore.
Hi, I Was Wondering If Anyone Knew About This Topic. Recently, My Radio Lights Do Not Work Anymore So I Cannot See It At Night While I Am...
saithor
98 Sunfire Electrical Problem
Brake Lights, Turn Signals, Rear Defroster Stopped Working All Of A Sudden. No Blown Fuses, Bulbs Are Good, Disconnect Battery To See...
tntobx
89 Chevy Silverado C\K 1500 Will Not Start ?
I Have An 89 Chevy Silverado With A Brand New Rebuilt 350 Motor That Will Not Start. It Sounds Like It Wants Too But Will Not. It Is Getting...
tosha
1994 FORD ASPIRE WILL NOT START
Hello: I Have A 1994 Ford Aspire Auto Trans 1.3 Ltr. It Just Quit While Driving, And Will Not Start. Fuel Pressure Test Good, Spark Tests...
DARRYL
FORD ASPIRE
93 Chevy Astro Shifter
I Have 93 Chevy Astro And Was Having Problems Shifting Out Of Park, If Shut Of For Few Minutes And Try Again It Would Work, Then While...
bodhi
AC For 2000 Chevy Cavalier
I Have A 2000 Chevy Cavalier, And Needed To Know What The Proper Way Would Be To Drain The Freon From My Car, Or If You Are Supposed To.
nlw2911
Please Help, F150
My Husband Is Deployed And His 2001 Ford F150 Has Been Pretty Much Parked For The Last 6 Months. I Drive It Occasionally, And It Seems To...
sweethangs
1915
2000 Neon Idles Rough
I Just Replaced An Engine In A 96 Neon With A 2000 Engine With 33,000 Miles. (I Believe It's A 2000 Anyway), The Car Runs Beautifully...
etherealstorm
Alternator Draining Battery
Battery Goes Dead Overnight. Battery Is New. Checked Amp Draw With Everything Off And Get About 3.7 Amp Draw. Pulled Fuses One By One And...
choffman41
Chevy Truck Transmission
I Own A Chevy 1998 1500 4wd Truck. Autotransmission Is A Turbo400 I Believe. I Have An Intermittent Problem With The 2nd Gear Acting Like...
bobaloo1
I Adjusted The Timing It Has A Very Weak Spark?
Our Shop Burnt So I Don't Have A Timing Light. So I Set The Timing To Start Then Made Series Of Stops And Gos To Try To Get Timing Close...
sc1 racing
1992 Mx3 1.6l Idle Problem
I Have A 92 Mx3 With 120k Miles. After The Car Has Warmed Up The Idle Will Start To Flux From 1000and Down It Almost Gets To The Point Where...
ttara
1992 Cutlass Fuel Problem
I'm Not Getting Any Fuel To The Fuel Injection System On My 1992 Cutlass Cierra. I Replaced The Fuel Filter Near The Fuel Tank, And It Was...
makophin
Options For Blown Head Gaskets
I Have A 97 Outback With A Manual Transmission. I Bought It In July05 With 115,000 Miles For $6k. The Head Gasket Is Blown And I Am...
tishalini
Will Start Run Few Seconds And Then Shut Off
I Drove It Home One Night Stopped In Front Of My Place And It Just Shut Off. I Started It Rigth Back Up And It Ran For About 5 Seconds And...
kijaro
98 Cavalier Antifreeze Leak
My Car Is Leaking Antifreeze. I Tried To Find Where It Is Leaking And It Looks Like It Is Coming From The Weep Hole On The Waterpump. Can...
jamespf
350 Turbo Passing Gear Problem
Hi Guys, Working On An 84 Monte Ss With A 350 Turbo Tranny. When You Kick It At 25 - 55mph It Feels Like It Kicks Down To The Passing Gear...
unclegeorge
1935
Help,help,help For My Dodge Truck
Hello Everyone, I Have A 1997 Dodge Ram 1500. The Truck Sat For About Three Months. Now That I Have Started Using It. I Am Having...
sharee123
THM-350; Will Not Upshift
I Have A Thm 350. It Will Upshift From 1-2 But Not From 2-3.I Put The Car In Drive And It Seems To Be In 2nd, I Can Shift Down And No...
cmcl
1935
96 Astro Van Replace Rear End ??model Yrs Compatible
I Have 1996 Chev Astro Van That I Am Replacing The Differential. For Drum To Drum Replacement What Model Years Are Compatible?
nuts4soccer
Power Steering
I Have Been Having Issues With Losing Power Steering At Or Slightly Above Idle. My Pump Is Also Making A Whining Noise Like A Pump Does When...
02250FRDDSL
Interior Light 96 Olds
Greetings, Has A Slight Problem With The Interior Light. The Light Used To Come On When You 1st Lifted On The Driver Side Doorhandle. It...
onejohne
20245
20246
20247
