Engine turns over but wont start?
  • 2019 NISSAN X-TRAIL
  • 1.5L
  • 4 CYL
  • MANUAL
  • 220 MILES
The engine is cranking but there is no spark on the ignition coil and fuel pump. What should I do?
Thursday, September 5th, 2019 AT 12:24 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,896 POSTS
Can you double check the year make model engine size for us? Also it the security light flashing? if so here is a guide to help rest the system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
If the security light is not flashing it sounds like the crankshaft sensor has gone out but to be sure lets check out this guide.
Saturday, September 7th, 2019 AT 1:39 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 2007 NISSAN X-TRAIL
  • 80,000 MILES
Diesel, 2007, engine turns over but wont start. OBD-II code. Only P1435 code present (relates to DPF and has been present for several months) so I do not think it is that.
Monday, October 5th, 2020 AT 11:18 AM (Merged)
KHLOW2008
  • 41,815 POSTS
Common rail engines are not that simple to diagnose and basically you need a scan tool to monitor the various conditions to find out what is missing.
You can't just loosen a fuel line to test if fuel is present because the pressure is extremely high and any drop in the pressure can cause non starting.
JACQUES ROELOFSE
  • 2.0L
  • 4 CYL
  • FWD
  • 372,000 MILES
Hi all I am new. I have a big problem my engine management light does not come on even if the accessories is turn to on it work before all of the sudden it stall. Scanner cannot connect because of this and the car does not start. Any ideas and help? Please Thanks
  • 31,938 POSTS
There should be a fuse for the DLC or the globe may have blown this will shut down the data link access in many cars. I am looking for the fuse location, but my data base is down just now, I will keep trying and advise ASAP.
KEN L
  • 42,896 POSTS
It sounds like you have one of three problems, first you have lost a fuse or relay. IF these check out okay I would suspect a burnt out ECU. Here are some guides and engine wiring diagrams (below) so we can do some testing.
and
Cheers, Ken
TJACKSON8
  • 2.5L
  • MANUAL
  • 127,000 MILES
My vehicle listed above petrol was overheating. We took it to a mechanic and he told us the water pump needs to be replaced. While doing that he told us we need a new fan which he also replaced. We got the car back and it rode perfect for the next week. Then it started overheating again and now broke down. Took it back to the mechanic and he is stumped he does not know why he cannot get it to start.
Monday, October 5th, 2020 AT 11:19 AM (Merged)
  • 108,192 POSTS
Many things can cause a crank no start condition. If that is what is happening, read through this link which discusses different causes, how to check and how to repair the condition.
Now, basically what needs done if that link isn't helpful is to check if the engine is getting spark and fuel. Here are links that show how that is done:
Those are the two most common reasons an engine won't start. Here are a couple links to help you through the process of checking:
Let me know the results of these tests. Also, here are the manufacture's fuel pressure specs.
Fuel Pressure (Key ON, Engine OFF) .................... 345-395 kPa (50-57 psi)
Let me know if this helps.
ROSIE AND SON
  • 2005 NISSAN X-TRAIL
  • 2.5L
  • 4 CYL
  • 4WD
  • 230,000 MILES
Running QR25DE engine; coolant in rad: did head gasket change, timing chain KIT change; refinished head and block at machine shop; replaced camshaft position sensor; new spark plugs. So at first, on putting the engine back together the CP sensor was not installed flush. Upon starting got 'no compression sound' and no spark. Fixed sensor and engine coughs, won't start and there are massive amounts of fuel in each chamber. Dried out chambers and plugs, no start! New plugs, no start! Lots MORE fuel in chambers! Disconnected injectors. Could fuel be entering the chamber with the vehicle off, key out? How extensive could the problem(s) be? Bad injectors or wiring? Damaged computer module? THANKS for your help!
Rosie & son
JOETECHPRO
  • 705 POSTS
Hey ROSIE AND SON,
When you say a no compression sound do you mean that the engine turns over too fast or do you mean it is cranking but not firing?
Do you have a spark now after fixing the crank shaft position sensor issue?
Can you please check for engine management fault codes and see what you have?
Guide below:
Due to having replaced the motor i would say ensuring you have rechecked all of the wiring harness connections and ground connections that you removed would be a great first step.
Also checking all of the fuses in the under hood fuse box.
Regards, Joe
MICHAELHOLLAND
  • 4WD
  • 90,000 MILES
Changed the plugs, added 20 l of fresh gas and stablizer. Battery is charged and on a trickle. Engine turns over but won't fire.
JOETECHPRO
  • 705 POSTS
Hey MICHAELHOLLAND,
Can you please confirm that the security light is out when cranking?
Example of security light in picture attached below.
When cranking this dash light should not be illuminated or the vehicle immobilizer is preventing starting.
Regards, Joe
RONDORON
  • 2.5L
  • 4WD
  • 100,000 MILES
Hi, my vehicle is petrol and starts no problem when cold but travel a little then stop it turns over but will not start. If you put your foot on accelerator and turn it over it will fire up, changed cram and crank sensors.
HMAC300
  • 48,601 POSTS
If you can next time hit bottom of tank with fist or palm of hand if it starts right away then the fuel pump is probably going bad. also, check fuel pressure with a gauge. in US auto parts rent it. See link.
RONDORON
Hi, thanks for your suggestions I will try it and let you know if it works. I am not a car person and do not know my way around an engine but I will have a go as I have spent money on it. Cheers!
RONDORON
Now vehicle not start cranks over trying but not fire up. Cheers
HMAC300
  • 48,601 POSTS
Probably sounds like your fuel pump has gone out.
RONDORON
Have you any suggestions please?
HMAC300
  • 48,601 POSTS
It sounds like a bad fuel pump unless it is a security problem if that is case see link. if still not starting check fuses under hood and fuel pressure with a gauge. also, try smacking bottom of tank with fist or palm of hand if it starts the pump is bad.
DARRENFRAN19631971
  • 2004 NISSAN X-TRAIL
  • 2.5L
  • 4 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
Car has just decided not to start. I have tried the fuse trick. I have checked the spark plugs. There is smell of fuel when trying to start so I believe fuel injectors okay. Was running okay then went to start in morning but nothing. It has ignition and sounds like it wants to start but does not. Any information I will be grateful for. Thank you in advance.
