Loud Whine And Some Idling Problems?
When I Start The Truck, There Is A Very Loud Whining Or Hissing Sound Coming From The Engine Bay. After A Few Seconds Of Idling, The...
74bossk
Fuel Injector Line, Cylinder One Not Working?
Cylinder 1 Is Not Working. I Tested It With A Test Light And The Signal Light Only Blinks At Start Up. Once The Engine Is Running The Line...
frankye972
ECU Pinout Needed?
I Need The Ecu Pinout Wiring Diagram.
Sarab Sagoo
TOYOTA CROWN
Power Steering Line Diagram Needed?
I Got A Leak And After Using Leak Detector It's Coming From Above The Engine Oil Filter. Any Idea Whether It's A Hard Line, Rubber...
Robert Clark2
A/C Relay/fuse No Power?
Hello, Have The Truck Listed Above 1500 And Have No Power To A/c Fuse Or Relay Under Hood, No Power From Ignition Switch As Well To Pin...
Lap4768
Cannot Get It To Turn Over?
I Was Given A 74 Vw Auto Stick. It Ran Then Sat Up In A Field About 2 Years. We Pulled It Down To The House To Start Working On It. New...
laurat0312
1974
VOLKSWAGEN BEETLE
In Need Of A Diagram For PCM Swap?
I Am Pcm Swapping My 1996 Saturn Sl2 With A Pcm Out Of A 1994 Sc1, And I'm Having A Hard Time Finding The Right Wiring Diagrams For...
Chuckssl2
SATURN SC1
Spark Plug Diagram?
Misfire On Cylinder 8. Can I Get The Spark Plug Diagram To Find Cylinder 8 Please?
Brianna Louviere
GMC SAVANA
How To Change Ignition Housing?
Ignition Housing Replacement.
Denise B
CV Axle Replacement?
Hello, It's Been A While. But I've Got An Issue With My Car Listed Above Gxe 2.4l. I Just Replaced The Passenger Side Cv Axel. This...
JC-842
Lost Key, How To Bypass The Key Chip To Start The Car?
Lost My Key Peeled Out The Ignition And Can't Bypass The Key Chip Or Whatever It's Called, But How Can I Start My Car.
Ladyboss22
MAZDA 5
MISSFRING
When I Strt Up The Car Runs Fine And When The Fans Go On Thats When It Starts Misfing
r6061772
CADILLAC DEVILLE
Wiring Harness Diagram From The Fuse Box To The...
On The Vehicle Listed Above I Am In Need Of Where The Wires That Go From The Fuse Box To The Alternator To Battery Run To, I Am Needing To...
Charlani
JEEP LIBERTY
Nav Screen Doesn’t Turn On, AC Control Module Isn’...
This Happened In The Middle Of The Day Leaving The Gas Station. Random. It Started About 24 Hours Ago. Since Then The Screen And Ac Control...
M45mike
INFINITI M45
Nav Screen Black But Flickers, A/C Control Module Not...
This Happened In The Middle Of The Day When I Left The Gas Station. Random. It Started About 24 Hours Ago. Since Then, The Screen And A/c...
M45mike
INFINITI M45
Is There Any Way To Create A New Master 2 Button Key...
I Only Have A Blank Key With No Buttons Which Obviously Has The Immobilizer Chip As It Starts The Engine. I Have Managed To Program The...
Mikes RAV4
TOYOTA RAV4
Fender Figment For Same Body Style But Different...
Would The Passenger Side Front Fender From A 2000 4.0l V6 Ford Ranger Xl Fit On A 2000 3.0l V6 Ford Ranger Xl I’m Just Not Sure If There...
Alford B
22 IMAGES
Heavy Blue Smoke Usually Appears Under Acceleration?
Hoping It Isn’t The Rings, Is There A Vvt And If So, Where’s It Located Sir? Hard Fix? Any Other Possible Issues That Come To Mind...
Michael Holodinski
Fuel Injectors Swap?
I Have The Car Listed Above. I Need To Know If A 2004 Chevy Silverado 4.3 Fuel Injectors Are Interchangeable. I Have Those Available Already...
Tabitha Lacheney
PONTIAC FIREBIRD
A/C Not Working When Engine Is Under Load?
A/c Works Fine Until You Want To Pass Or Go Up A Mountain. In That Case The A/c Switches To Defrost.
Boyd H
FORD AEROSTAR
Electrical Not Working After Using A Screwdriver To...
I Was Pulling The Interior Door Panel To Replace A Trim Piece. I Used A Screwdriver To Pry Off A Flat Plug Off The Door Panel. Goes To...
Phil Bair
CHEVROLET CORVETTE
Thermostat Sticking
Thermostat Sticking No Moving From The Cold Position And Says Engine Hot Ac Off As Soon As I Start My Car
Stephneejibson87
PONTIAC TORRENT
Shaking/vibration, No Noise?
The Vehicle Listed Above Is An El Limited. Roughly Six Months Ago I Started Chasing An Intermittent Drivetrain Shake/vibration, But It'...
JayDub1791
Where Is The Starter Relay Located?
There May Be A Click From Under The Hood When I Turn The Key. Maybe Not. It May Start Right Up, Or It May Take Several Tries With The Key...
Gtrack
GEO TRACKER
The Charge Light Does Not Come On At All And Is Not...
Charging System Problem.
Fixmyproblem
639
640
641
