Starter Solenoid Smoking?
Hi, I Just Replaced The A/c Compressor And Accumulator In My Truck Listed Above. When I Started It The Starter Sounded Kind Of Loud And...
Bill texeira
Bringing Up A/C Pressure From A Vacuum To Trick It...
Hello, I Just Watched A Video From August 2020 Titled, "how To Vacuum Down And Recharge Your A/c System! - Easy". In That Video You...
ernesto36021
Electical Issues - One Thing Afer Another.
Hey, 2003 Mazda Mpv Es. 3.0l V6, 225,000km On It. I Think I Might Have Done Something Stupid And Caused A Whole Bunch Of Issues With...
Imprint4139
MAZDA MPV
Stalling And No Start Problems
My 1993 Buick Lesabre Stalls Out When I’m Driving Highway Speed Or Just Cruising Down The Street After It Stalls I Have To Let It Sit A...
trich866
BUICK LESABRE
After Replacing The Wheel Bearing, Hub And Ball Joint...
I Changed The Wheel Bearing, Hub And Ball Joint, Few Days After It Started Making Scraping Noise, Could Louder When Apply Brakes. Like A...
susanreneea
KIA RIO
Car Will Not Start?
I Have Replaced The Battery, Battery Cable From The Starter Solenoid To The Starter, Starter Solenoid On The Firewall, And The Starter...
AstraTaurim
Car Won’t Start
So The Issue I Am Running Into Is That My Car Won’t Turn Over. I Have Replaced The Battery, Starter Motor, And The Starter Solenoid On...
AstraTaurim
Is A OBD2 Power Adapter For My Dash Cam Safe To Use To...
I Was Thinking About Getting A Obd2 Power Adapter For My Dash Cam, Is It Safe To Use It This Way Just To Power Dash Cam?
Steve620
GMC ENVOY
Car Stalls Out Upon Stopping?
Hi All My Car Listed Above Seems To Jerk A Little When Slowing Down, Almost As If It’s Racing To Get Down Into 1st Before The Car...
Wagonbro33
Power Steering Message Across Instrument Panel?
So, For The Electric Power Steering There’s Two Parts Modules?
azdanno04
Passenger Side Headlight Replacement/swap?
Hi All I Have The Car Listed Above With A Broken Passenger Headlight That I Want To Replace. I’m Having A Hard Time Finding Used Ones...
Wagonbro33
Shuts Off After Running For A Few Minutes?
I Have The Car Listed Above Lx Model. I've Replaced The Battery, Had My Alternator, And Starter Checked. All Good. My Car Just Keeps...
conjon07
Clutch Pedal Goes To The Floor?
When I Push The Clutch Pedal, It Goes Straight To The Floor Easy, And I Am Unable To Put The Shifter Into Gear, It Just Has A Grinding...
Michael Ann Mahseelah
CHEVROLET 1500
Car Has No Electrical Power?
This Car Has No Security System. The Car Started As It Normally Does And I Drove About 5 Minutes. Upon Trying To Restart (engine Still Warm...
will gull
PLYMOUTH BREEZE
When Accelerating There Was A Pop, Then Car Lost Power...
I Was Driving Went To Slow Down And Then Proceeded To Speed Back Up When I Heard A Pop And Then It Wouldn't Pull. Car Listed Above Is...
Bethannwooldridge
Car Completely Dead As In No Power
Turn Key On, No Power At All. Not Even Digital Odometer. Jump Car And It Starts But Rpm Going Up And Down. Alll Electronics Haywire...
will gull
PLYMOUTH BREEZE
Charging System Light Not Working And System Not...
Charge Light Never Comes On, Not Even In Startup And System Is Not Charging, Installed New Alternator, No Change.
Fixmyproblem
Acceleration Issue?
Acceleration Problem. Etcs And Tp Error Codes.
Christneo
Alternator Discharging Warning Appears On The Dash...
Dash Says Alternator Discharging While Driving Sometimes. Had Alternator Check Off The Car And It Checked Good. Is There Anything That...
sidro7
Alternator Charging
Does Anything Control The Charging Of The Alternator Other Than The Alternator? Sometime While Driving The Battery Discharge Signal On The...
sidro7
Charcoal Canister And Steering Rack Boots
4 Days Ago The Check Engine Light Came On. I Took It To My Regular, And Trusted, Repair Shop. While Diagnosing The Code I Had Them Do A...
Philb124
Engine Will Not Crank?
I Have The Vehicle Listed Above Se Model. I Turn The Key On And Get Power To Everything. Try To Start The Car And Nothing Happens. I Have...
garymcglothlin2
DODGE AVENGER
The Check Engine Light Came On In My Camry 4 Days Ago. Not Flashing. I Had My Regular, And Trusted, Shop Do A Code Check And Thorough...
Philb124
Risk Of Filter Clogging?
Risk Of Filter Clogging Comes Up And The Engine Man Agent Light On As Well As Triangle. Also The Fan Comes On As Soon As The Ignition Is...
Lorrae Jones
PEUGEOT PARTNER
Clunking Sound Coming From Front Of My Car?
The Wheel Bearings, Rear Shocks, And The Control Arms In The Front Have Been Replaced. The Car Sways When Going At A Fast Speed And When...
Jhammond0605
638
639
640
