Hard Braking Engine Stall Shutdown
2000 Camaro 3.8l Automatic, Hard Braking At Stop Sign Causes Engine To Stall And Shutdown, Restarts And Runs Fine.
beesuegoo
2004 Hyundai Santa Fe Left Front Steering Knuckle...
I Have An 04 Santa Fe With A Bad Wheel Bearing. I Don't Have A Hydraulic Press, So I Just Bought The Entire Knuckle With The Bearing...
klonkey
HYUNDAI SANTA FE
Left Front Knuckle Replacement?
I Have A Bad Wheel Bearing For My Vehicle. Instead Of Dealing With The Need For A Press (which I Don't Have), I Bought The Entire...
klonkey
HYUNDAI SANTA FE
Engine Will Not Turnover?
I Just Had Put The Car Back Together From Fixing A Transmission Fluid Leak. Two Days Later Since I Driven The Car, I Get A Message Across...
azdanno04
Starts And Runs Cold And Shuts Off When At Operating...
The Truck Starts And Idles Fine And Drives For A Few Miles, But When It Gets Up To Temperature, It Starts Misfiring, Idling Bad And Shuts...
G7Customer
CHEVROLET 1500
Alternator Not Charging?
Hello, The Vehicle Engine Was Repaired, In The Process The Alternator Connector Was Damaged. The Connector Has Four Pins Space, Only...
Blessing Ewobor
LEXUS RX 350
The Coolant In The Reservoir Is Leaking And Engine...
Can't Keep Coolant In Reservoir It Is Leaking And Overheating My Questions Is, It's A Week Until Payday And I Need To Go Get My...
Rachel Gibson
CHEVROLET TRAX
Code P0500, Where Is The VSS Located?
The Code Popped Up P0500 Is The Vss, And I Would Like To Know Where It's Located. Can I Fix It Myself?
keishak056
Where Is The Camshaft Position Sensor Located And How...
My Truck Has A Check Engine Light, And The Error Code Has Come Up With A Camshaft Position Sensor (circuit Bank 1). I Have Recently Been...
Kerri Anne Hoyte
Wheel Bearing
Hi I Have Had 4 Wheel Bearings Installed In The Last 6 Week And Tge 4th One Has Just Gone Again I Have Also Had Driveshaft Replaced And...
Shelbob85
PEUGEOT 207
Error Codes U016400 And P068A00?
I Stack On Parking Position This Fault Code U016400 And P068a00.
Abie
VOLKSWAGEN GOLF
Brakes Locking Up/holding When Driving?
The Vehicle Had A Spongy Brake Symptom So Diagnosed A Bad Master Cylinder. Did 4 Wheel Bleed Twice To Make Sure Good Fluid And No...
Justin0604
Does My Truck Have A "win" Module?
I Can't Turn Over The Truck. It Cranks Alright And I Hear The Fuel Pump, Checked Fuses, Relays, Etc. By Luck I Saw A Set Of Wires...
Stephencmassey
DODGE SRT-8
Codes P001685 And P001785?
I Was Told By A Mechanic The Car Had The Check Engine Light For Something Simple, That I Could Drive The Car And It Will Remove Itself. I...
gabcruz
MERCEDES BENZ 300
What Is The Fuel Tank Capacity?
The Car Listed Above Is The Signature Series. Specs Say Fuel Tank Capacity Is 19 Gals. But When I Fill The Tank From Empty, It Only Takes...
Don Bee
LINCOLN TOWN CAR
Crank But No Start, OBD Does Not Work?
Good Morning, Firstly, I Would Like To Thank You For Your Time, And Say That I Came Across Your Site Via This Video: Https://www....
C_word
Battery Light On?
Last Week The Alternator Went Bad. Monday It Was Replaced And Ended Up Needing A New Battery As Well. Got It All Put On And By Tuesday It...
Christina Dressell
HONDA ODYSSEY
Battery Light On
Last Week Alternator Went Bad. Monday It Was Replaced And Ending Up Needing A New Battery As Well. Got It All Put On And By Tuesday It Was...
Christina Dressell
HONDA ODYSSEY
A/C Only Works While Driving?
Compressor Clutch Disengages After Car Is Idle For Couple Minutes And Blows Hot Air. Clutch Reengages After Giving It Gas. A/c Works Great...
jcestra
NISSAN ROGUE
The Engine Is Running On Between Two And Three...
This Occurred After Replace The Cylinder Head. The Head Replacement Is Not The Issue. The Compression Is Reading Between 145-155 On...
Conecaster
KIA SPORTAGE
No Electrical Power?
The Car Listed Above Is A Daytona Charger. I Went To Start It And My Screen Started Flashing Different Messages Ranging From Put My Security...
Howie Y
Coolant Gives Three Different Temperatures, And The...
I Just Put My Car Back Together And I Was Able To Start It, And Everything Was Fine. I Just Moved The Vehicle Out Of The Garage And Parked...
azdanno04
While Driving The Fuel Light Turns On, And Fuel Gauge...
When Driving My Vehicle, The Fuel Light Turns On, And Gas Gage Goes Down To Empty Then When The Light Turns Off The Gas Gage Goes Back To...
MARTINBIRD
CHRYSLER PACIFICA
Codes 40, 21, 34, And 13?
Code 40, 21, 34, 13
Victoria Brown-McClure
OLDSMOBILE CIERA
Engine Does Not Crank When The Weather Is Too Cold...
When It Gets Too Cold Outside My Vehicle Won’t Crank Over Until You Heat Up Under Dash For A Few Minutes. Soon As Do It Starts Fine?
Drewzer
640
641
642
