Where Can I Get A Vacuum Switch?
Where Can I Get A Vacuum Switch? No One Here In South Africa Has One I Am With My Hand In My Hair Here. Please Tell Me If You Can Assist Us...
MAREHET
HONDA PRELUDE
What Is The Torque Spec For These Bolts On The Lower...
Sub-frame Bushing Bolts.
ahartley
BUICK LESABRE
No Crank And Disconnected Wires?
Just Bought This Vehicle. It Has A No Crank Condition. Replaced Starter And Solenoid To No Avail. Motor Is Not Seized. New Battery. Noticed...
WesternReach
LINCOLN TOWN CAR
All Running Lights Not Working?
Turn On The Headlight Switch Either By Auto Or By Manual, Both Headlights Are Okay But All Of Running Lights Are Not Working.
DAvid Chen
Where Do The OBDII Port Wires Go To, BCM Or ECM Or...
Also, I Need Wiring Pin Outs For The Bcm, Obdii Port, And Ecm. Any Help Would Be Appreciated. Thanks Guys!
Jdalton65
21 IMAGES
CHEVROLET COLORADO
Codes P0236 And P0237?
Good Evening, Please Help! I Would Like To Know More About These Two Codes That Are Running On My Vehicle, The Codes Are P0236 And P0237...
Ericsson
Lean Fuel In Bank 1 Put A New PCV Valve On?
The Truck Listed Above Is An Xlt. Engine Light Came On Obd Code Lean Fuel In Bank 1 Put A New Pcv Valve On. The Truck Started Acting Rough...
CAM61
Car Sat For A Year No Crank No Start?
Car Sat For A Year No Crank No Start Changed The Starter Cranks No Start Code Reads U0100. Replaced Starter Grounded Wires I Used Starter...
Ivan.R
21 IMAGES
PONTIAC G6
Mystery Missing Part?
I Was Under The Rear Of My Truck This Evening And Noticed Something. On Both The Right And Left Side, There Is A Rusty Metal Piece Hanging...
Jason Fessenden
CHEVROLET 1500
Is There A Tool To Lock/align Camshaft Timing Marks...
Lock/align Camshafts Timing Marks When Replacing Timing Chain Tool.
Yazidan
How To Drain Out Old Fuel?
Trying Car Been Sitting For 6 Years Trying To Drain Out Gas.
jbanks82x
MERCURY GRAND MARQUIS
How To Set Timing?
My Timing Belt Broke While Driving. I Tried To Start The Car Not Knowing The Problem And Now The Crank And Cam Are Out Of Position. It Says...
jmusino
TOYOTA RAV4
Blend Door Actuator Not Working?
I Have The Vehicle Listed Above Rebel, That Is Giving Me Heat On The Drivers Side And Cool Air On The Passenger Side In The A/c Mode. I...
rockman71
RAM 1500
Car Will Not Reverse Or Go Over 30 MPH?
Car Shifts Into All Gears Fine When Using The Shifter, But When In Reverse There's No Power So Car Cannot Reverse. When Car Is In Drive...
Rhat
PONTIAC BONNEVILLE
A/C Not Working?
I Have Checked For Leaks Via Manifold Gauges For An Hour. No Leak. I Then Used A Vacuum Pump For 45 Minutes. I Then Added R134a Until It...
Albrand
Where Is The Fuel Pump Located?
Some In The Fuel Pump Others Say On Top Of The Fuel Tank. Can Youu Tell Me Where?
CoachReyna
The Immobilizer Will Not Communicate With ECU?
I Replaced The Immobilizer And The Ecu My Cars In The Honda Dealership When They Plug Their Scanner, And It Will Not Communicate With The...
Dennis Alford
Oil Setting On Bottom Of Engine
Looks Like A Lil Seapage Under The Engine
meow2k47
New Fuel Pump, No Fuel?
The Car Has Quit No Fuel Pressure At Fuel Rail Replaced The Fuel Pump Turned Key On And You Can Hear The Pump Run But No Fuel Thought I Had...
Retired62
4x4 Not Engaging?
I'm Having Issues Trying To Figure Out Why 4x4 Won't Engage. Have Tried All Sorts Of Things And Read Threads And Post About Issue....
Cinthia789
Will Not Start?
Vehicle Is Getting Diesel But Will Not Start.
November
SUZUKI GRAND VITARA
Engine Cranking Not Starting After Overheating?
The Other Day My Car Was Having Issues Overheating, Immediately Stopped And Waited For It To Cool Down Before Driving Home. We Thought It...
Abbigai.breanne
HYUNDAI GENESIS COUPE
Need Radio Wiring Diagram So I Can Install My Amp And...
Cant Get A Straight Answer
Bender Lydic
VOLKSWAGEN JETTA
Radio Wiring Diagram Needed?
I Need Radio Wiring Diagram So I Can Install My Amp And Sub. I Can't Get A Straight Answer.
Bender Lydic
VOLKSWAGEN JETTA
Installing Sub And Amp, Need Factory Stereo Rear Spkr...
Dont Have Wire Color To Install Properly
Bender Lydic
VOLKSWAGEN JETTA
612
613
614
