Moving Wires Or Shielding Wires?
Hello, In Newer Modern Cars In The Column Overhead Leading To The Roof There Are Wires That Emit A Large Electromagnetic Field Right Next...
jegeta003
Still Alive, If I Can Maneuver Through The Ads!!
Been Likely Over A Year Since I Said "hi", And Wow. What Changes! Cannot Even Get Into The "expert Forum" Without Dealing With Numerous...
I-Smogem
A/C Only Works When Jumping Relay?
The Ax Compressor Clutch Only Works When Jumping Pin 30 And 87. It’s Charged With The Correct Amount Of Freon. I Have Tested About As Much...
Sidewinder313
Engine Revs Up To 2,500-3,000 RPMs?
Changed The Idle Air Control Valve With A New One, Still On Start Up The Car Will Rev Up Out Of Nowhere To Like 2,500-3,000 And It Revs Up...
Rob1986
Training From My Pals At Opus IVS
More Free Training Https://www.youtube.com/playlist?list=plyidgcwwhu8xwmpc0ew-mcawish0t8h1z
Steve W.
Dash Lights Than Car Won't Start
So I Was Driving Down The Road And All Of A Sudden Car Was Acting Like I Was Lightly Pushing On The Breaks So I Look Down And The Traction...
arneyladonna
KIA SORENTO
Started With The Traction Control Light, Will Not...
So, I Was Driving Down The Road And All Of A Sudden, The Car Was Acting Like I Was Lightly Pushing On The Brakes. So, I Looked Down And...
arneyladonna
KIA SORENTO
Code P0302, Misfire I Only Get A Misfire And EPC If I...
I Only Get A Misfire And Epc If I Accelerate Hard And Go Past Half Throttle. If I Say Below Half Throttle The Engine Will Continue To Rev...
Roachinator
VOLKSWAGEN GTI
Dash Cluster Will Not Light Up In Daytime, But Works...
My Dash Cluster Will Not Light Up During The Daytime, But At Nighttime When The Headlights Are On It Works Fine. The Dimmer Switch Works...
Golfbassin
Interior Lights Not Working At All?
Map And Dome Lights Don't Work At All. Checked Fuse Under The Hood And Inside On The Passenger Side. Both Were Good. Just For Good...
Andy2541
Fuel Gauge Not Working After Pump Replacement?
So, I Changed The Fuel Pump In My Car, It Runs Great, But The Gas Gauge Is Not Working Now. And I Tried To Do That Reset That They Show...
careytouraille
Codes P0300, P0175, And P0172, 17 Seconds After...
Hi, I Am Completely Stumped I Can't Find It What Am I Missing. I Pretty Much Rebuilt The Hemi From Ground Up This Summer The Winter...
Shipp2mylulu
RAM 2500
Codes P0170 And P0173, Fuel Pump Control Module Part...
Diagnostic Testing On The Vehicle Listed Above Sport Xls Came Up With Two Codes: P0170 (fuel System Too Rich Bank 1) And P0173 (fuel...
Eva Jean
MITSUBISHI MONTERO
While Driving There Is A Vibration In The Accelerator...
I'm Getting A Vibration In My Car's Accelerator, Center Console, Floor On Both Driver And Passenger, And Dash When Accelerating...
Jake Gossett
HYUNDAI TUCSON
Check Engine Light Turned On After Hitting A Deer?
So, I Hit A Deer This Morning. The Only Body Damage Was The Plastic Spoiler, But Yet My Check Engine Light Came On. What Might Cause...
MSinor
2023
GMC TERRAIN
Where Is The ABS Fuse Located?
My Car Sometimes Won’t Drive At All And Other Just Hear A Noise Took It To A Shop They Didn’t Do Abs Work But Said That’s The Problem...
Ejamal95
A/C Temperature Fluctuating?
Just Purchased The Vehicle Listed Above And As Soon As I Drove It Off The Lot The A/c Temperature Started Fluctuating From Ice Cold To Kind...
Minday79
HYUNDAI TUCSON
Accelerate But Then It Jerks Hard And Sometimes Stalls...
So, I Just Bought The Vehicle Listed Above Q7 Quattro. There Are No Service Lights On But When I Start To Drive It Goes Then Drops In...
daddiebabes
AUDI QUATTRO
Fuel Not Reaching Injectors?
Fuel Going To Fuel Pump But It's Not Going Through The Injectors.
seanaa
HONDA CRV
How To Evaluate If The Rust Is Going To Cause Problems...
I'm Shopping For Used Cars In Pa Around $3000. Feels Like Every Car Has Rust, But Idk How To Evaluate If The Rust Is Going To Cause...
Dedoria
A/C ECU, Where To Purchase?
Where Did You Buy The Ecu Unit At?
Eze005
MITSUBISHI LANCER
How To Replace The Serpentine Belt Tensioner?
Car Was Running Hot Notice Tensioner Is Bad, Needs To Be Replaced, Needing Instructions.
Tony Sage
OLDSMOBILE ACHIEVA
Fuse Keeps Blowing
When I Turn Headlights On The Fuse, Blows, Dash Lights Go Out Running Lights Don’t Work And Brake Lights Don’t Work But Headlights Do...
Ross Williams
GMC VAN
Fuse Keeps Blowing
When I Turn Headlights On The Fuse Blows, I Have No Dash Light And No Running Lights And No Brake Lights But Headlights Work. It Blew Four...
Ross Williams
GMC VAN
Instrument Cluster Wiring Diagram Needed?
All Of The Wires Are Out Of My Instrument Cluster Wiring Harness, And I Can't Seem To Find An Accurate Pinout To Put Them Back.
BeccaH98740
611
612
613
