Installing Sub And Amp, Need Factory Stereo Rear Spkr...
Dont Have Wire Color To Install Properly
Bender Lydic
VOLKSWAGEN JETTA
Check Transmission Light Flashing?
When I Drive Especially When It's Cold, I Can Feel It Change To 2nd Gear Then Instead Of Changing To 3rd Gear The Check Trans Display...
Lumkile123
ISUZU RODEO
Brakes Were Making A Horrible Grinding Noise Then All...
My Brakes Were Making A Horrible Grinding Noise Then All The Sudden The Brake Pedal Went Soft It Still Stopped But I Had To Push It To The...
Sabrinawilson
Code P0300?
Miss Fire At Idle Only After Warmup, Over 800 Rpm Does Not Miss Fire. Has Full Power, Visually Checked Plugs And Coils, Replaced Intake...
Rhiggi
CADILLAC DEVILLE
The Left Front Parking Light And Turn Signal Will Not...
The Left Front Parking Light And Turn Signal Will Not Turn Off. Started After Radiator Tank Blew Out And Saturated The Fuse Box. I Pulled...
JBK76
Shut Off While Driving?
Driving Home One Night On The Interstate When All Of A Sudden, My Car Quit Like It Lost Compression, Then Shut Off But At The Same Time It...
BamaAngel
My Cruise Control Doesn’t Work When The Lights Are...
My Cruise Control Doesn’t Work When The Lights Are On. Also, The Brake Lights Come On When The Lights Are On Even When The Brake Pedal Is...
Skwiebe
HONDA ODYSSEY
Motor Mounts
Will Motor Mounts From A 95 To 01 Lumina Fit A 2004 Impala
Heather dyer
Motor Mounts Swap?
I Need To Know If Motor Mounts From A 1995 To A 2001 Lumina Will Fit The Car Listed Above.
Heather dyer
Wrong Gearbox Installed?
I Sent My Vehicle Into The Garage To Get The Turbo Replaced. The Mechanic Just Told Me It Was All Finished And As He Was Resetting The...
KurtisK22
AUDI Q3
Stuck In Four-wheel Drive?
I Had A Clutch Put In My Vehicle When I Got It Back It Won't Come Out Of Four Wheel High? I've Tried Everything Is Wireless Or...
Tim O
ISUZU TROOPER
Engine Revving Too High?
Recently I Had A New Muffler Installed That Gave It A Deeper Tone But Wasn't Overly Too Loud. I've Noticed Now That If I Start The...
Rosellia
CADILLAC DEVILLE
Wobbling Front Passenger Side Front End?
When I Drive My Car, It Feels Like My Tire Is Wobbling Or Like Something Is Loose.
Candy Ballantine
Which Oil Viscosity Should I Use?
I Live In State Of Kuwait A Very Hot Country, Which Oil Viscosity Should I Use?
Safa dia
ACURA INTEGRA
Codes P0223 And C1130, Engine Knocking Noise While...
My Vehicle Listed Above Was Driving Fine, A Little Loud But Okay, Then It Started Knocking Really Bad As I Was Getting Off The Highway...
Jessicab0628
NISSAN MURANO
Code P0452, How To Remove The Fuel Tank And Access The...
Hi, My Brother Has A P0452 Code On His Car Listed Above. I'm Self-employed And Would Call Myself An Advanced Diyer. I'd Like To...
Talonluvswifi
Fuel Pump
I Got A New Fuel Pump For My 99 Gmc Yukon And The Electrical Plug Is Different. What Is The Schematic For The Four Pens In The New Plug...
Threethumbsone
Air Conditioner Only Works On Defrost?
I’m Replacing My Electrical Blend Door Actuator And Have It Taken Out. Right Now, The Only Way The A/c Will Work Is If The Switch On The...
Branstep653
Car
Went Down The Road And The Collier Pin From Clutch Pedal Came Out How To Fix It On My 2003 Honda Accord Ex
Kittykat87
Will Not Start After Running Out Of Gas?
I Was Driving While Not Paying Attention To My Gas Gauge And I Ran Out Of Gas. My Car Would Not Start After That, And I Replaced The Fuel...
44lopezm44
DODGE INTREPID
Coolant Bubbles / Boiling?
The Vehicle Listed Above Is An Stx, V6. Occasional Coolant Reservoir Overflow After Replacing Reservoir And Coolant Hose "t"...
rhartma4
DODGE JOURNEY
The Radiator Fans Stopped Working, A/C Does Not Engage...
I Have The Car Listed Above And My Radiator Fans Stopped Working. So, I Replaced Them And They Still Don’t Work. Neither When I’m...
torumalex7
PONTIAC G6
Battery Negative Or Positive Ground?
I'm Trying To Rewire The Battery On This Car And Would Like To Know Which Post Is Grounded.
Eridian
Replacing The Shocks For More Comfort?
The Truck Listed Above Is A K1500, Original Owner. This Truck Is All Original (stock). 4 Shocks In Front. Lumber Rack And Stock Heavy? Duty...
Randy Dresdner
1984
Where Is The Transmission Control Module Located?
Transmission Losing Connection To The Transmission Control Module. I Was Trying To Locate It So I Can Inspect The Connector And Wires To...
Stretchglobal
613
614
615
