O2 Sensor Diagnosis?
1997 Defender Failed Ca Smog Due To Rich Mixture At Idle And Gave Code P0176. Ran Live Diagnostics On The Sensors And Have Results But...
Twozzie
LAND ROVER DEFENDER
Over Consumption Of Fuel?
The Car Burns Too Much Fuel When The Tank Is Full I Have A Digital Display Fuel Guage And Every Quarter Of A Tank Is Supposed To Drive Me...
66149
HYUNDAI ACCENT
Transmission Won't Move?
Have A Rebuilt Transmission, Changed Transfer Case, Rear End, Drive Shaft. Truck Still Won't Move. Think Transfer Case May Be Stuck...
wandaandbuddy
AI Goes Round And Round....
Https://www.youtube.com/watch?v=z7w5rlxmgie Note That The Info Isn't Correct When It Comes To The Relays/fuses And More. The Comments...
Steve W.
Something Fell Off
Hi. What Is This That Fell Out Of My Car?
Natalie Sarapovic
CADILLAC CTS-V
Something Fell Off?
Natalie Sarapovic
CADILLAC CTS-V
Front Main Bearing Seal Leak?
I’ve Discovered What I Believe To Be A Slow Leak From The Front Crankshaft Main Bearing Seal. My Belief Is Based On Seeing Oil Gunk...
tehoff1870
P1601:Electrically Erasable Programmable Read Only...
This Vehicle Was Driven On A Street And Bounce On A Bump And It Off. I Try To Start It And It Fails To Start.I Try To Diagonize It And It...
Mallyboy
Mallyboy
Instrument Cluster Not Working?
Truck Was In An Front End Accident And The Ecm Was Smashed. I Replaced It With A Used One That Came From The Same Kind Of Truck Same Year...
Hatrack73
Retrofiting Nav System In Mercedes W211?
Hello — I Want To Upgrade My W211 Mercedes From The Audio 20 (standard Radio) To An Ntg1 Satellite-navigation System. I’ve Read Forum...
Dominik1234
MERCEDES BENZ E240
Trouble Code P0521?
Hello I'm Having Issues With Trouble Code P0521 I Need Help Figuring How To Fix This Issue.
lionell8732
2 COOLANT TEMPERATURE SENSORS?
Crossover Coolant Pipe Has Two Temperature Sensors. One On The Left One On The Right. Switch One Is For Temp Gauge? The Temp Gauge Is Not...
truckwes
MERCURY MARAUDER
Brake Lights Stuck On?
Vehicle Turned To On Position, All Lights Work Fine. When I Start Vehicle, Key In Run Position, Brakes Illuminate And Stay On The Whole...
Blissfulbeauty1983
Belt Tensioner Pulley To Insert A Breaker Bar?
Am Unable To Find The Tension Pulley To Insert A Breaker Bar For Belt Removal. Have Not Able To Find A Pic On-line To Show This.
Schjoh34
Horn Isn't Working And Airbag Code?
Hello, I Just Got My Truck Running After A Few Months And My Horn Doesn't Work And I Have An Airbag Code B0022. What Can I Do To Fix...
rlpeterson
Limp Mode And Engine Didn't Sound Right?
Had Oil Pressure Low Warning Come On, Had Oil Leak, Took To Garage They Said It Was The Oil Filter, Apparently They Checked For Engine...
Trina1591
FORD CUSTOM
Transmission Stuck In Drive Now Won't Start
Car Wouldn't Shift Out Of Drive And Now Won't Start Won't Even Click Because It's Not Going Into Park.
richardwpalmeriii
Transmission Stuck In Drive Now Won't Start?
richardwpalmeriii
PCV Valve?
I Am Having Trouble Trying To Find The Pcv Valve On This Car
tylersmith3498
Oil Filter Housing Aluminum Upgraded Part?
I Replaced My Plastic Housing With An Aluminum Upgraded Part. However When I Installed It I Am Still Experiencing A Leak. I Have Cleaned Out...
Vibehigh25
CHRYSLER TOWN AND COUNTRY
Will Not Shift Into 4 Wheel Drive?
4wd Light Blinks Will Not Shift To 4hi Or 4lo Just Blinks, 2wd Light Stays Green. Replaced Encoder Motor With Brand New One, Replaced Tccm...
Derekw5820
Wiper Washer
Wiper Washer Not Working, Washer Pump Replace, Relay Not Working
LSASPEED31
CHEVROLET EXPRESS
No Communication Between Pcm And Fuel Pump Relay
Trying To Find A Pin Out Diagram Of Pcm
carguydave
CHRYSLER SEBRING
Blend Doors/ Radio Head Unit/horn/liftgate
What Is The Blend Door Locations For The Bi-control For The 13/14 Ford C Max Hybrid Se. I Need The Locations And The Directions For All 3...
Srizer
FORD C-MAX
3
4
5
20251
