Had Low Pressure On The Oil Pressure Cluster I Added 2...
And I Get A P1482 Code Then The Truck Sputters And Shuts Down After I Added Oil To Stop The Oil Cluster From Dropping
September2025
All Gauges Will Stopping Working?
While Driving The Vehicle The Following Will Intermittently Occur: All Lights On The Instrument Panel Will Illuminate, All Gauges Will...
BLAZ85
Upper Ball Joint Swings Inboard And Outboard?
Recently, I Changed The Upper And Lower Ball Joints, The Upper Ball Joint Swings Inboard And Outboard, And It Has A Mat Mark. So The...
Akord
Starting Issues For The Last Two Weeks?
I Have A Mechanic Question. I Have A 2002 Chevy Malibu My Car Has Been In A No Start Condition For The Last Two Weeks. When I Hit The Gas...
Meloman7
1993 Towncar ABS Light On Constantly?
Abs Light On Constantly. There Is Suppose To Be A Way To Jumper Pins On The Passenger Side Connector. Mine Has The Triangle Connector With A...
GSith
LINCOLN TOWN CAR
Fuel Pump Control Module?
I’m Having The Hardest Time Finding The Fuel Pump Control Module On This Year. It’s Not Under The Spare Tire Nor Near The Abs Module
Devinbrinegar98
Rack And Pinion Wires?
I Cut The Rack And Pinion Harness Wires By Accident. I Have The Engine Wire Harness Diagram, But The Diagram Doesnt Show The Rack And...
jakniyah
Esp And 4wd Not Functioning Properly?
Esp Won't Work For 4wd Won't Work Checked Fuses. Any Wiring Diagrams On This Thinking It A Wiring Issue.
Len32
JEEP COMPASS
Tail Light
I Changed The Tail Light Wiring Harnesses And Now I Only Have One Tail Light To Work But Both The Brake Lights Are Working
SarahCurrey
Car Lost All Power Crank And Nothing?
I Had Some Repairs Done On My Vehicle And Ran Perfectly Fine. I Was On My Way To A Store Went In Came Out Car Is Completely Dead I Go To...
WillM22
HYUNDAI ELANTRA
Modules Has PASM Alarm?
Hi So I Replaced The Ecu And Fbcm As They Were Bad. The Car Works Now But It Has Pasm Alarm. My Ca R Never Had This Feature Or Module. It...
drluisreymm
PORSCHE CAYENNE HYBRID
Help Identify What These Connectors Go?
Witch Plug Goes Into? Color Blind And I Cannot Tell The Difference. Please Help
Rebirth98gh
BUICK REGAL
Rebirth98gh
BUICK REGAL
Airbag Code B0022?
I Just Got Got My Car Started After Replacing Everything On My Steering Wheel. When I Starter The Truck I Got An Air Bag Code Of B0022...
rlpeterson
Right Yellow Parking Lights Off On A 2017 Dodge Grand...
My 2017 Dodge Grand Caravan Recently Failed The State Inspection Because Its Yellow Parking Lights On The Front Right (passenger) Side Went...
grandcaravaner
Transmission Refused To Go Forward?
I Was Driving And The Transmission Refused To Go Forward. I Was Able To Drive In Reverse All The Way Home. Now It Won't Go Forward Or...
TreverWhiting 16
Can Someone Help Tell Me Witch Throttle Body Wire Gets...
3 Connectors Got Disconnected On Accident. Trying To Make Sure I Plug Them In The Proper One. Please And Thank You For The Help.
Rebirth98gh
BUICK REGAL
2017 Dodge Durango Vehicle Wont Go To Park Or Shift?
Durango Check Engine Light Came On, Wouldnt Recognize Vehicle Park, Engine Would Shut Off, But Car Remained In Acc And Wouldnt Switch To...
Xtrsc
DODGE DURANGO
No Signal From Crankshaft Position Sensor?
The Crankshaft Position Sensor Is Not Sending A Signal To The Computer. I Replaced A New Sensor What Could Be The Cause?
joe1953
17 IMAGES
P0198 Oil Temperature Sensor?
Having Trouble Locating The Oil Temperature Sensor
C_ruiz613
NISSAN JUKE
Wheel Bearing Replaced Brakes Went Out
I Took My Car To Midas Got 2 Tires And The Wheel Bearings Replaced. The Next Day My Son Took It To Work Coming Home It Was Making A Horrible...
kwojton
Dies At Idle, Engine Cuts Out
Similar To Vacuum Leak. Replaced Throttle Body And Maf Sensor, No Improvement
mechguy
CHEVROLET UPLANDER
Ignition Shut It Off, It Will Not Start Again?
Car Starts In One Shot, Stays On As Long As I Like. If I Shut It Off, It Will Not Start Again
bobbys
Defroster And Heat Controls Do Not Work?
To Fix The Defrost And Heat Control Issues, I Replaced The Blend Door Actuator. I Started The Engine And Cycled Thru The Temperature...
rejordan79
JEEP COMPASS
P0171 Lean Code?
Vehicle Starts And Then Seems To Run Out Of Gas. But Will Start Right Back Up
spgalaxye84
CHRYSLER TOWN AND COUNTRY
2
3
4
20251
