Interior Light 96 Olds
Greetings, Has A Slight Problem With The Interior Light. The Light Used To Come On When You 1st Lifted On The Driver Side Doorhandle. It...
onejohne
91 Corsica Fuel Injection Woes
My Corsica Used To Run Fine. Lately It Starts Up Just Fine But After A Minute Its Like Somebody Turns A Switch Off And It Immediately Dies....
sonofcorn
CHEVROLET CORSICA
1990 Mazda 626 2.2L Not Getting Fuel To The Engine!
I've Already Spent Over 200 Dollars On A Fuel Pump That I Just Found Out I Don't Need. The Old One Is Working Fine, But I Am Still Not...
mycar
MAZDA 626
Where Do I Find And How Do I Access My Codes On My 95...
Hi All, I'm In Need Of Finding And Diagnosing My 95 Chevy Pu With A 5.7 L Tbi(350) I Can't Find Thid Info In My Haynes Manual. Could...
maxbencher
Engine Shuts Off And Won't Run Or Start If Turned...
Runs Perfectly But Once It Gets Hot Will Either Die Out And Not Restart Or Will Run Fine Until I Turn It Off To Run Into A Store For 30 Mins...
atherton
Won't Go Over 40 Mph ,
Won't Go Over 40 Mph, When It Goes It The Engine Hesitates On Take Off, Then When I Punch On The Gas Pedal It Just Ruves Up Then It...
jrobin1977
Smoking Stalling Camry
It Started Stalling And Smoking White Smoke At Red Lights And Surging Down The Highway. We Took It To Toyota And They Diagnosed The #1 Fuel...
jscjordan
Help!!!!! Mazda 626 Hi Speed Vibration
Mazda 626 Lx 1999 25k I Bought It A Year Ago In Excellent Condition And I Drove It 5k Last Year, Mostly Local. I Dont Drive On Highway...
skiier
1962
MAZDA 626
Gas Gauge Problem - 1982 Monte Carlo
I Just Bought A Beautiful 82 Monte Carlo. The Only Problem I Have Thus Far Is That The Gas Gauge Doesnt Seem To Work. It Shows Only 'just...
scarlyjones
1982
CHEVROLET MONTE CARLO
06 C6 Corvette Ticking Noise
When The Engine Is Cold There Is A Ticking On The Drivers Side Of The Engine, It Sounds Like A Valve Ticking. After The Engine Warms Up It...
ntuitger
CHEVROLET CORVETTE
1994 S-10 Transmission
I Am Curious What Some Of The Tell Tale Signs Of A Worn Or Faulty Transmission Might Be. I Am Experiencing Considerable Vibrations During...
nubs
Mazda 626 Fuel Pump!!
I Have A 97 Mazda 626 With 53k Miles. My Wife Recently Purchased It From A Ford/lincoln/chrysler/ : Mazda Dealership In June 05....
ricsua99
1962
MAZDA 626
Spark Plug Wiring Help
My Sister Has A 93 Vitara 16v And She Had Some Idiot Replace The Wiring, Plugs And Rotor. Now It Doesn't Start. When I Checked The...
3hb78ftg
1986 Chevy Pick-up
Have A 1986 C-10 With A 292 Engine. Won't Start. Lined The Timeing Mark With "0" And #1 Piston Up When Checking Rotor Position At #1 Plug I...
msholl
Where Is The Camshaft Sensor 97 Ranger
Can Any Inform Me Where The Camshaft Postion Sensor Is At For A 1997 Ford Ranger W/ V6 3.0 No 4x4 Thanks
joecastillo_mi
Golf Diesel Engine In A Geo Metro
It's Hard To Find A Diesel Golf, But The Engines Are Pretty Easy To Find, Is It Possible To Modify The Engine To Fit In A Geo/chevy Metro...
TheGodfather
GMC Suburban Dome Lights Staying On
I Have A 1999 Gmc Suburban. Since Purchase, The Dome Lights Have Been Trouble. They Remain On At Random, Can Pop On In The Middle Of The...
cgibson
Fan Continues To Run
I Have A 1998 Plymouth Grand Voyager (a Very Bad Purchase), And The Radiator Fan Continues To Run After You Shut The Car Off. The Only Way...
johnrw
Wont Start
: I Have A 1992 Gmc Suburban(k1500)about A Week Ago It Started Bogging Out On The Freeway. Allmost Like An Air-gas Thing.I Got It Back Home...
archibald
Ford Taurus Brake Problem
This May Be Extremely Elementary, However, I Really Need Some Help/an Answer. I'm A Single Female Located Quite A Distance From Any...
goodwitch06
1986 XJ6 Series 3 Overheating
I Have A 86 Xj6, With About 70k Miles And Is Running At A Higher Than Normal Temp ( About Halfway Through The Green Zone Maybe Just...
mariner5564
How Can I Change The Oil Pan?
Can Someone Tell Me How Can I Change The Oil Pan On A 1990 Ford Bronco 302cid Without Raising The Engine? Can This Be Done?
the amazing raymondo
91 Explorer Transmission Woes
Neighbor Has A 91 Explorer 4x4 With An Automatic Transmission. When Shift Lever Is Put In Overdrive, The Vehicle Won't Move. If It Is Then...
Kenneth Burrough Jr.
Diesel Engine Won't Stop
Hello. I Have A 1979 300sd Turbodiesel And It Is Giving Me Some Problems. The Biggest Is My Engine. My Engine Just Keeps Going And Going...
MBnks2005VG
I Am Replacing The Timing Chain?
I Have 1991 Blazer S10 4.3l, V6, Automatic With 4-wheel Drive And A/c. I Am Replacing The Timing Chain But The Label That Have The Specs...
dlav1956
20246
20247
20248
