Engine From Automatic Car To Manual Car?
I Have Found An Engine From A Automatic Transmission Car, And Want To Know If It Can Be Directly Fitted To My Manual Transmission? Current...
Jpage73
VOLKSWAGEN GTI
Wiring Issue
I Accidentally Drilled Into The Wire Harness On The Driver Side Floor Board. The Following Do Not Work After This. Odometer Is Blank Dome...
spenxcheryan
Head Lamp Wiring Short?
Replaced My Headlamps With 6000k - Lightning Blue. Galaxy Series: 55w Ac Canbus Ballast Hid In 2016 In 2021 My Alternator Went Out. ...
dhschoonover
CHRYSLER SEBRING
I Accidentally Drilled Into The Wire Loom On The...
The Truck Starts And Moves But The Following Don’t Work: Interior Dome Lights. Lights On The Doors. Odometer Is Blank. Door Locks...
spenxcheryan
Inlet Cooler Line Comes Out?
Changing Out Inlet Cooler Line, Old One Was Leaking From Front. Front Goes In Fine. When Putting The Back In, The Click From The Pin Is...
Soso100
HUMMER H3
HVAC Blower Motor Will Not Shut Off Unless I Remove...
Both The Radio And Climate Control Panel Are Not Lit Up And Do Not Work. At First The Car Was Blowing Hot Air All The Time, Now It’s...
Ferrell Paige Reid
BMW X5
PCM Pinout Needed?
In Need Of Pinouts For: 80-pin Pcm Connector C1blue 80-pin Pcm Connector C2 Black
Random User
General Help?
My Best Friend Just Inherited Her Dad's 1995 Nissan Pickup. There Is No Significant Damage To The Truck, So She Is Working On General...
kris10nl
NISSAN HARDBODY
Can A Bad Steering Rack And Pinyon Be Diagnosed Before...
Think I Was Wronged By Mechanic.
aubrie77
Code B1317, High Voltage?
Yes, I Been Having My Battery Light Comes And I Parked My Car And Checked The Voltage On The Battery And It Was 17 V And I Haven't...
BEASTY83
Color Coded Stereo Wiring Diagram Needed?
So, I Can Wire My Stereo Up. And Those Wires Are Not Cut. Someone Just Added Wires To Them. I Don't Have Money For An Adapter So If...
Mouse357
A/C Light Not Working
Hey There, I Have A 99 4 Runner. My A/c Button Broke Off Over The Winter, I Just Replaced It With A New One And The Light Is Not...
99runer316
A/C Does Not Light Up, Hot Air?
My A/c Button Came Off Over The Winter. I Just Replaced The Whole Part With A New Button And No Light Came On, And Only Hot Air. Seems...
99runer316
2011 Chevy Avalanche Po521
I Get A Po521 And Oil Pressure Guage Says Stuck On 80 Psi When Started Up. My Automatic Start Also Just Stop Working Too. As Of Now Truck...
roycar71
CHEVROLET AVALANCHE
Code Po521?
I Get A Po521 And Oil Pressure Guage Says Stuck On 80 Psi When Started Up. My Automatic Start Also Just Stops Working Too. As Of Now The...
roycar71
CHEVROLET AVALANCHE
Will Not Start, Driver Safety System Fault Warning?
There's A Driver Safety System Fault Warning And The Car Will Not Start.
Esweets1203
AUDI A3
Suspension Of Steering Issues, Front End Has A Very...
My Car's Front End Has A Very Loose Feeling When Accelerating Or Hitting The Brakes Very Hard. It Feels Like There’s A Lot Of Play In...
Satcom909
Brake Bleeding On And Off?
I've Rebuilt All The Brake Lines. Installed New Rotors And Pads And Rebuilt The Front Calipers. When I Bleed The Brakes, The Pedal...
ehfowler
No Power To A/C Clutch?
I Am Not Getting Power To The Ac Clutch. I Can't Find A Wiring Schematic To Figure Out If It's The Temperature Control Module Or...
bbhepp
22 IMAGES
Crank No Start?
I Acquired The Car Listed Above, That Had The Engine Torn Down For A Blown Head Gasket. Before The Tear Down The Car Ran. I Have Rebuilt...
Rick_V
VOLKSWAGEN JETTA
Transmission
Jerking
5407650046
OLDSMOBILE ALERO
Jerking When Shifting Gears?
Transmission Issue, It’s Jerking While I Shift Gears.
5407650046
OLDSMOBILE ALERO
Clutch Pedal Not Returning When Pressed?
Clutch Pedal Not Returning To Top. While On A Hill In First Gear It Wouldn't Move Forward. Smelled Burning While In Traffic Going Up A...
Gill54
VAUXHALL CORSA
Where Is The Fuel Pump Located?
I Suspect A Failed Fuel Pump Is The Problem, I Need To Locate The Pump And Filter On This Make And Model.
DOUG Gilstrap
ROLLS ROYCE SILVER SPUR
Mid-level (dash) Vents Not Working?
When Placed In Defrost Mode Or Foot Vent Mode Air Blows Fine. When In Mid-level Mode The Fan Runs But No Air Comes Out Of The Mid-level...
Jonathan Cardoni
702
703
704
