No Crank No Start?
Prior To The Issue, I Only Had Trouble Starting One Time. Replaced Battery, Starter, Ignition Switch, And Pcm. Getting Appropriate...
ZurEnArrh
21 IMAGES
CHRYSLER PT CRUISER
No Fuel With Spark?
I Have A New Distributor And Components, New Fuel Relay; New Spark Plugs And Wires. I’m On Tdc I Have Fuel To Tbi But No Fuel In Bowl I...
David9082
Do I Have The Correct Dust Covers?
Hello, I'm Wondering If I Got The Right Covers For My Back Rear Since I Have Parking Brake Assembly In The Back. These Parts Numbers...
lavell11
Blowing Fuse
Every Time I Press Brake Pedal Even When Key Is Off It Blows #13 Fuse
The Mike
Pass Lock On My Dash And It Will Not Even Crank Over?
I Need To See A Photo Of A Fuse Box So I Can See Which Way The Relays Are Positioned In The Box, Also I Have A Pass Lock On My Dash, And...
GETCH
CHEVROLET COLORADO
Control Arm Front Lower Left/ Control Arm Front Lower...
If My Car Takes The Fe1 Type Of Control Arms, Can I Use The Fe3 Control Arms When Replacing Them?
Amypalos96
CHEVROLET HHR
Engine Does Not Crank?
The Key Turns. The Car Doesn't Start. All The Lights Come On. Recently Got The Fuel Pump Replaced.
shaunea
Injector Not Working?
Dear Pros, I Am Trying To Diagnose What Is Going On With My Mercedes Viano 2.2. L From 2008 With 160'000km. (Wdf36981313464707). ...
Zislander
MERCEDES BENZ VITO
Code P1345?
Hello, Previously I Never Had Any Engine Related Issues With My Car Listed Above 1.4vvti, But Recently My Oil Light Came Up, So I Took...
Szabó László Vencel
Water Pump Replacement Difference?
My Mom Needs Her Water Pump Replaced But When Looking At Water Pump Assembly They Have A 6 Bolt Or A 11-bolt Water Pump. What Is The...
Esmit1st
CHRYSLER PACIFICA
CAR STARTS AND STALLS
My Gdi 3.5l Pajero With 6g74 Engine Takes Long To Start. The Car Starts And Stalls Several Times And Takes About 4 To 6 Times Before It...
GUY CHANGOLE
MITSUBISHI PAJERO
Has Power To Radio, Headlights, And Dome Lights, Are...
I Recovered A Stolen Van, Had To Tow. Some Fuses Had Been Removed To Disable Starting Replaced What Was Missing I Now Found Main Relay Fuse...
Erica Kitchen
MERCURY VILLAGER
HVAC System Only Blows Hot Air?
Hi There. I Have The Vehicle Listed Above Wolfsburg Edition Tsi 1.8. My Car's A/c And Heater Were Working Fine Until This Winter When I...
Vfav84
VOLKSWAGEN PASSAT
Do I Need To Support The Engine When Doing The Lower...
I Replaced The 2 Upper Motor Mounts. I Need To Replace The Bottom One Now, But I Wondered If I Have To Support The Motor Or Not.
Robert Clark2
Fuel Failing To Get To The Front
I Just Purchased A 1998s10 4wd Automatic With The Big Engine In It. It Has Been Setting Since 2013 But Ran Fine Prior To Being Parked. It...
Jamieandrews25
Plastic Ring Fell Into Engine Oil, How To Get It Out?
I Was Filling Up The Oil And The Plastic Ring Of The Oil Fell In. I Opened Up The Valve Cover And Tried To Get It Out But It's All The...
wfaguirre
VAUXHALL ASTRA
Anti-theft System And How To Reset It Without Key?
My Anti-theft System Went Off In My Vehicle. If I Take My Negative Post Off Battery And It Still Want Crank What's My Next Steps To...
tee2011
INFINITI I30
Infotainment System Not Working?
The Radio In My Vehicle Is Not Working As Well As The Display Screen, The Screen Will Cycle On And Off Every Five Seconds Only Displaying A...
Joelund729
The Car Shuts Down After Driving A Few Minutes?
The Rpms Starts To Go Down, The Car Starts To Like Choke, Then It Shuts Down. I Have To Disconnect The Battery. And After A Few Minutes It...
Darla Lamb Sledge
While Driving The Engine Sputters And Stalls?
Whenever I'm Driving My Vehicle And I Slow Down Or Stop It Sputters And Stalls.
RenwickLM
Starting Issue?
50% Of The Time It Starts On The First Try 50% Of The Time It Starts On The Second Try Fuel Pump Replaced Cam Sensor Replaced.
Gorlando
CHEVROLET EXPRESS
Electrical
Why Is My 2010 Suzuki Swift A/c Control Has No Power The Lights On The Dashboard Weren't Come On Gearshift Has No Lights As Well. The...
Fessal
SUZUKI SWIFT
A/C Control Has No Power, Dash Lights And Gear Shift...
Why The A/c Control Has No Power, The Lights On The Dashboard Were Not Turning On Gearshift Has No Lights As Well. The Light On The Clock...
Fessal
SUZUKI SWIFT
O/D Off After Jumping Another Vehicle?
So, I'm Not Sure If I Have Two Problems Or Just One. Car Ran Fine And One Day My Husband Gave Someone A Jump Start. I Would Say...
Sanford0024
Engine From Automatic Car To Manual Car?
I Have Found An Engine From A Automatic Transmission Car, And Want To Know If It Can Be Directly Fitted To My Manual Transmission? Current...
Jpage73
VOLKSWAGEN GTI
701
702
703
