Mid-level (dash) Vents Not Working?
When Placed In Defrost Mode Or Foot Vent Mode Air Blows Fine. When In Mid-level Mode The Fan Runs But No Air Comes Out Of The Mid-level...
Jonathan Cardoni
I Need A Wiring Diagram For The Engine?
When I Purchased This Car, I Noticed That Someone Had Torn Apart The Wiring Harness That Runs Along The Engine. I Mean It Looks Like A...
kbschofield7
SATURN AURA
A/C Pressure Shows Very High?
The A/c Compressor Runs With A/c On. R 134a Pressure Shows Very High. I Bled It All Out, Refilled. Shows As Being High With Only Putting...
Poleneck
A/C Will Not Switch From Defrost?
The Vent Blower Wont Switch From Defrost But I Can Still Change It From Heat To Ac. Is It Considered A Safety Risk?
ARC1
CHEVROLET EXPRESS
Valve Clearance?
I Finally Got The Correct Steps To Do My Valve Clearance. But My Problem Is That When I Accelerate It Is Quite Noisy As If The Valve...
TeamBsi
CHEVROLET SPARK
Codes P0300, P0307, P0175, And P0308, Do These Have...
Do These Have Common Engine Issues With Misfiring? Has P0300, P0307, P0175, P0308.
INFINITI QX80
Alternator And Battery Replaced Now My Lights Are...
I Just Had My Alternator Replaced And A New Battery And Now My Lights Are Flickering.
allysondempsey
Cold Cranks For 30 Seconds, Will Not Throttle Until...
Won't Start When Cold Cranks For 30 Seconds Won't Take Throttle Till Warm.
Tony Redinger
1965
PCM Swap?
Will A Pcm From A 2001 Ford Taurus Se Ohv Work If You Put It In A 2003 Ford Taurus Ses Dohc?
Foster1801
Check Vehicle Protection System Warning?
We Can’t Start The Car. The Battery In The Key Fob Was Replaced A Few Months Ago And We’ve Had No Problems. All Of A Sudden, We Can’t...
Beth Owen
FIAT 500X
Spark Plug Wiring Firing Order Needed?
So, I Recently Changed The Spark Plugs And The Spark Plug Wires, But I Believe I Connected The Spark Plug Wires Incorrectly. Can You...
Jcsolis2013
"freshly" Built Engine Backfires, Will Not Start?
I'm Working On The Car Listed Above With A "freshly" Built 302, That Has Sat For At Least 5 Years And Never Fired. After Pre...
Totalmc
1967
Calling All Cars!
We Need Some Help Fyi. The Questions Are Piling Up!
Ken L
Codes P1285 And P1299, Where Is The Cylinder Head...
Giving Codes P1285 And P1299 Need To Know Where The Cylinder Head Temperature Sensor Is.
Michelle VanHorn
If You Get In The Car Push The Brake And Hit The Start Button It Turns Over Normal, But It Won't Hit At All. If You Push The Gas Pedal...
Nuknukshpeelkum
CADILLAC STS
Tranny/engine
Okay So I Put A New Ignition In My Eddie Bauer Ford Expedition 2001 I Had It Flashed At The At The Ford Dealership Because I Had To Put A...
Chris Waller
Help In The Trenches!
The Site Is Getting Busy! Can We Get Some Help From The Troops? People Need Our Help.
Ken L
Inertia Switch Powerless?
Put In A New Fuel Pump New Relay, New Fuse, New Inertia Switch, And New Pcm Relay And Still No Fire At The Inertia Switch.
joesurita2001
PCM Pinout Needed?
In Need Of Pinouts For Pcm Connectors C1 Blue And C2 Black. Thank You
Random User
Will Not Start After Shutting Off While Driving?
My 2012 Chevrolet Orlando Shut Off On The Highway Last Week And Has Not Started Since. I Have Changed The Starter And Alternator But It...
llucero
CHEVROLET OPTRA
2012 Chev Orlando
Hi, My 2012 Chev Orlando Died On The Highway The Other Day And It Won't Start Since. My Husband Who Knows About Mechanics Has Changed...
Laura Lucero
CHEVROLET OPTRA
Will Not Start? It Cranks But Won't Run.
My Husband Is A Delivery Driver After Many Stops And Go's The Vehicle Won't Start. It Cranks But Won't Run. He Has To Wait...
lesleyb
Code P0522? Engine Oil Pressure Sensor?
Is This The One On Front Of The Head, Or The One In Back Or The One By Filter Housing? Replaced The One On Front Of Head Made No Difference...
HONDA ODYSSEY
Camshaft And Crankshaft Position Sensor Replacement?
Hello, I'm Planning To Replace The Above-mentioned Parts Due To Frequent Engine Stalling And Poor Idling (spark Plugs, Ignition...
redcru777
PLYMOUTH NEON
Speedometer Needle Bouncing Erratically Until...
Jumping Speedometer At Random Speeds. Any Decrease In Gas Or Even While In Cruise Control If There Was A Small Incline And A Slight Decrease...
Wisterdoo
CADILLAC DEVILLE
703
704
705
