Transmission Not Shifting Properly?
I Replaced My Shift Solenoid B And C But I'm Still Having Problems Shifting And My Transmission Is Automatic.
lawrence16
ACURA TSX
Where Is The Fuel Filter Located, Directions And...
My Vehicle Showed Sluggish Response To Acceleration For A Quick Pass And Then A Few Moments Later, Threw A Check Engine Light With...
RoverRunner
LAND ROVER RANGE ROVER
Intermittent Issue With The Rear Liftgate Does Not...
The Rear Liftgate Does Not Go All The Way Up Sometimes. On The Door It Says Full.
Anthony Kilgore
CHEVROLET TRAVERSE
Horrible Oil Leak, Oil Level Sensor?
My Oil Was Leaking, And My Sensor Was Saying I Had No Oil Even Though It Was Full. So, I Figured The Oil Sensor Was Shot.I Attempted To...
Jerrica Groves
I Need Help Locating An Oil Leak?
Hello, My Car Is Leaking Oil. I Would Like To Know Where The Oil Leak Might Be. There Is An Oil Stain On The Right And Left Side Of The...
Avid Learner
30 IMAGES
Ignore This Post
Sorry, I'm Trying To Delete The Video And Images I Added But It Won't Let Me And Every Time I Try To Ask A New Question, The...
Avid Learner
CHEVROLET CAPRICE
Rear Main Leak?
Found It Hard To Believe At These Miles Its Leaking But Maybe True, Maybe Shrinkage Or Being Old, But As Soon As You Start The Car, It...
JAGUAR XK8
Vibration Around 53 Mph?
A Bit Of A Dilemma. Car Has Only 85,000 And Is Clean, New Tires, No Play In The Wheels, Vibrates Around 52-65k. Checked Balance They...
MERCEDES BENZ C250
Can I Switch To Synthetic Blend Oil?
I Use Conventional Oil In My Car And Do Oil Changes Every 3,000 Miles. My Car Does Not Burn Oil. However, Conventional Oil Is Starting To...
Yazidan
Vehicle Will Not Accelerate?
The Engine Idles Fine And Will Rev While Neutral. When Shifted Into Drive The Vehicle Will Increase Speed To About 25 Mph And Then Won't...
SCXJ
The Speedometer Will Roll Up To 40 Mph Faster Than The...
No Other Check Engine Lights, All Other Gauges Seem To Be Working Normally. Just The Issue With The Speedometer Indication. I Replaced The...
WingNut74
NISSAN FRONTIER
Gasoline In Engine Oil?
1. I Can Smell Gasoline In Engine Oil And Around Throttle Body As Well. 2. When I Rev The Car On Idle To 3,000 Rpms And Let Go, It Goes...
Skajlet
NISSAN PRIMERA
Are Two Of The A/C Relay Terminals Supposed To Be Hot...
I've Attached The Wiring Diagram For Review. (F27) 31 Is Hot When The Car Is Off, 28 Is Cold (but 28 Gets Voltage When The Car Is In On...
njmclain
25 IMAGES
SUBARU OUTBACK
Will Not Start After Sitting For A Year With The...
We Have Replaced The Fuel Sending Unit And The Alternator, But It Still Won't Start. The Car Has Been Sitting For Over A Year Without...
Althea Mayberry
ACURA LEGEND
No Ignition Car Will Not Start?
Drove The Car To Work About 7:00am Drove Home Again About 1:00pm Went To The Shop About 2:00pm Everything Fine No Issues Come Out Of The...
Deedeew1985
CITROEN C4
Speedometer And Tachometer Flicker Off, Then No Crank...
This Truck Is My Daily Driver. No Modifications, Completely Stock. The Issue First Happened A Few Months Ago. I Was At A Red Light When...
schollingsworth
Can You Help Me Realize Do I Have Problem With The Car...
Hello There, For Some Reason I'm Hearing On My Vehicle Some Kind Of Air Coming From My Car Near The Tires. It's Not Tires Because...
nemanjamis
SEAT LEON
Where Is The Defrost Actuator Located?
A/c And Heat Only Blows Out Of The Defrost Vent. I Need To Know Where This Actuator Is Located And How To Replace It.
fix a mea
Loud Thump Noise When Transmission Is Shifted Into...
When I Shift The Transmission Into Reverse, I Hear A Loud Thump From The Transmission. I Recently Replaced Both Axles And Some Transmission...
lionell8732
19 IMAGES
MERCURY MILAN
Weird Smell From HVAC?
There's A Weird That Comes From My Car Whenever I Gave Max A/c On Or. The Windshield Front Defogger My A/c Has No Freon, So...
Fabian Charlton
17 IMAGES
High Idle After Cylinder Head Replacement?
High Idle After Cylinder Head Replacement At Nom Op Temperature Coolant At 192°f No Mil Maf Reading 9g/s At 1,800 Rpms Spec Is 4 To 7...
Joe Freeman
TOYOTA TACOMA
Jerking Sometimes?
Starts Drives But Will Start Idle High Jerking Then Check Engine Light Comes On Then Jerks And Stops And Light Goes Off. When On Freeway 60...
Dangell
HYUNDAI SANTA FE
The 4lo Blinking And Does Not Switch To 4H? P0766...
The Car Rpms Not Firing Fine, And The Car Was Scanned, I Will Attach The Printout Results. Heater Sensor 1, Transmissions Gearshift Valve...
Trainz martinz
LEXUS GX 460
Air Only Comes Out Front Vents, Mode Will Not Switch...
Okay. So, I Have Both Hot And Cold Air Blowing But It Will Only Come Out The Vents In Dash, I Switch To Defrost And Nothing Not Even The...
J-DAWG73
DODGE DURANGO
Sludge Inside The Engine?
Had My Oil Changed Recently And Was Told I Had Sludge In My Engine And That I Needed To Add An Oil Additive In My Car Before The Next Oil...
Nancy Rogers Sanders
669
670
671
