After Replacing The Original Drained Battery, The...
The Only Way To Stop It Is To Disconnect The Battery. The Vehicle Will Start And Run But The Engine Light Is Now On. It’s My Understanding...
CatCam
RPMS Erratic And On/off, Stalling?
I Don’t Even Know Where To Start, This Last Week Has Been So Stressful. So, I Started Having Issues With My Car After Brakes Were...
Sjbausley
Ignition Relay Harness Wiring Diagram Needed?
I Recently Purchased This Car, And Someone Cut The Ignition Relay Harness And All Out And Bypassed It. I Have A New Harness And Relay, 5...
Fta826
MERCURY GRAND MARQUIS
Car Will Not Run, Cylinders One And Two Have Zero...
I Had An Oil Leak From The Engine Valve Cover Gasket That Took Me Months To Identify. I Replaced The Engine Valve Cover, Gasket, All 4...
jessirby1
CHEVROLET CRUZE
Door Lock Actuator Passenger Side Replacement...
Please Give Detailed Steps And Pictures On How To Replace A Door Lock Actuator For The Passenger Door Listed Above. Thank You
Talonluvswifi
Dorr Lock Issue?
1997 Chevrolet Silverado Ext Cab 3 Door 350 Engine Sn 2gcec19r0v1119067 Vortec 5700 V8 Sfi Engine Remote Keyless Entry, Power Locks...
lars42
CHEVROLET 1500
P1870 Code Stored, Intermittent. Transmission...
I See This 2000 Chevy Blazer 2 Door 4x4. I'm A Bit Of A Sucker For Blazers. 124k On It. Has A P1870 Code Stored, Intermittent....
Harry P
Looking At An Online Auction
Harry P
Passenger Doors Will Not Open?
The Back Passenger Doors Will Not Open And Both Door Handles Are Not In Great Condition. I Managed To Open The Driver's Side Passenger...
Kletis
CHRYSLER PT CRUISER
Can I Program A Key Fob To This Car?
When I Purchased My Car, It Didn’t Come With A Key Fob, But I Didn’t Think Anything Of It Because It’s An Older Car. But While I Was...
Jas0822
KIA SPECTRA
Air Conditioner Not Able To Take Refrigerant?
A/c Worked Just Fine Until O Rings Failed Where Lines Connect Together. I Replaced O Rings. Pulled A Vacuum On System, No Leaks....
mc63gp
PONTIAC G6
Starting Issue?
Battery Charged Will Not Turn Over. My Vehicle Listed Above Has A Good Battery, And I Need To Trouble Shoot From There. Can You Help With...
turbotail
EGR Connector Wiring Pinout Needed?
Need Connector Pinout For Egr. Replaced Egr Valve But Still Getting Issues With Map Sensor Circuit.
Patrick1o1
FORD CROWN VICTORIA
4x4 Switch On Dash Has 2.4 Volts Negative Feeding Out...
4x4 Switch On Dash Has 2.4 Volts Negative Feeding Out On Hi Lo And Neutral, What's The Problem?
Connellym
CHEVROLET 2500
What Does It Mean When The Wheel Bearings Need To Be...
My Son Changed My Wheel Bearing On Front Driver's Side Do They Need To Be Pressed? What Exactly Does That Mean? It's Making Kind Of...
susanreneea
KIA RIO
Instrument Panel Light Will Not Turn Off?
The Lights For The Odometer, Time And Date Remain On After Car Is Turned Off.
Elishabb
VOLKSWAGEN PASSAT
Transmission Interchange/swap?
Is A 2001 Ford Explorer Xlt Transmission Interchangeable With Any Other Vehicle?
Melanie Moment
Will Not Start, I Replaced Fuel Pump And The Fuel...
I Replaced The Fuel Pump And The Fuel Injectors.
frankee3
HYUNDAI ELANTRA
Not Getting Fuel After Engine Swap?
I Changed My Engine In This Vehicle Listed Above And I'm Not Getting Fuel Now Worked Fine Before I Change The Motor, I Have Replaced...
Scrappy65
CHEVROLET BLAZER
Where Is The Fuse That Controls The Windows, Doors And...
I Am Trying To Locate The Fuse That Controls The Windows, Doors And Interior Lights.
hdnichols46
Headlights Not Turning On?
When I Pull Out The Knob The Twilight Sentinel Works And The Yellow Lights On The Front Of The Car Turn On, But Not The Headlights. Funny...
Ahhem
PONTIAC BONNEVILLE
Where Is The Temperature Control Blend Door Located...
I Would Like To Know The Location Of The Temperature Blend Door And How To Go About Getting It Out.
Will3131
CHRYSLER CONCORDE
The Key Is Stuck In The Ignition, And It Will Not...
Truck Started Running Like It Was About To Run Out Of Gas And Had Plenty Of Gas. Wants To Cough And Sputter, No Power, Barely Moves, Push...
bfbracy
Is The IAT Sensor Supposed To Have Oil Inside Of It?
Is The Iat Sensor Supposed To Have Oil Inside Of It? I Unplugged It Because It Looked Nasty And Inside Was Dark Liquid. I'm Guessing It...
00hndaccrd6thgenulev
Shift Stuck At Neutral, Wont Budge.
Just Asked A Question But Put The Wrong Email. Mt4god@gmil. Com Should Be Mt4god@gmail. Com Sorry. Can You Fix?
mt4god
HYUNDAI ELANTRA
670
671
672
