Engine Cranks But Will Not Start, It Has Spark And...
Engine Cranks But Won't Start Has Spark And Fuel. When Key Is Seth To 2 Clicks The Fuel Pump Will Continually Cycle Fuel To The Return.
Seth Mauldin
MITSUBISHI LANCER
What Is The Bolt Size For A/C Compressor And Idler...
I Need Bolts Size For A/c Compressor And Idler Bolt Size.
Robert Woods 33
CHEVROLET CRUZE
The Serpentine Belt Tensioner A Big Pulley Is Not...
Below Serpentine Belt Tensioner A Big Pulley Isn't Turning?
Jj2sharp
Installing A Backup Camera, Wiring Diagram Needed?
I'm Trying To Install A Backup Camera; What Color Is The Trigger/reverse Wire In The Taillight?
Kim coons
HYUNDAI ELANTRA
Fuse Box Wiring?
There Are Two Rectangular Connectors That Plug Into The Front Of The Interior Fuse Box. What Are They, And What Do They Do? They Have One...
MikeHe
SUBARU OUTBACK
Engine, VSC, Trac Off Lights Are On?
The Engine Light, Vsc Light, And Trac Off Lights Keep Coming On. Sometimes It Goes Away, But Eventually It Comes Back. The Van Seems Like...
Ollenas
16 IMAGES
TOYOTA SIENNA
Crank No Start, The Green Key Light Would Come On And...
Hello. I Just Recently Purchased The Car Listed Above, Used. I Was Made Aware Of An Issue With The Security System Before I Purchased It...
BnT
Coolant Was Leaking To The Point Of Overheating?
I Have The Vehicle Listed Above With A 2.4i. Coolant Was Leaking To The Point Of Overheating. Changed Water Pump, Timing Belt, Coolant...
tjjeter87
VOLVO S40
I Need To Identify The Part That Connects The Clutch...
I Need To Identify The Part The Connects Clutch Pedal In Foot Well?
Larrycan
NISSAN NV
Constant P0420 Code?
Cat Code Keeps Popping Up, I Have Replaced The Spark Plugs, Map Sensor, Air Filter, And O2 Sensors. Codes Keep Popping Up, But I Don’...
Sich18
JEEP PATRIOT
Fuel Pump Wiring Diagram Needed?
I Have A Problem With The Fuel Pump. I Think I Have A Problem With A Ground But I Can Not Find A Wiring Diagram To Looking Which Wire Is It...
Daniel Paquette
Repair
Motor Section
gstv
NISSAN FRONTIER
Shorted Battery Or Short Elsewhere?
Hi There, The Car Listed Above Has A 3.0 Dohc, I Just Finished A Repair Replacing All Of The A/c Lines. Which Means I Had To Remove The...
cannon1349
Piston With The Exact Design Of One Of The Valves...
In The Middle Of Replacing Lifters Due To A Tapping Sound In The Driver Rear Of The Engine I Came Across A Piston With The Exact Design Of...
Ajae
Misfires And Battery Light?
Good Morning! I Currently Have An Issue With My Vehicle Listed Above. I Will Explain Everything In Detail About What I’ve Done. ...
Tlchambers15
VOLKSWAGEN FOX
Oil Leak Not By The Valve Gasket It Was Coming From...
Just Recently Changed The Valve Cover Gasket To My Car And Just Noticed That The Oil Was Still Leaking But It Was Not By The Valve Gasket It...
Rr23Angel
Upgrade To EVIC?
I Am The Owner Of The Vehicle Listed Above Arctic Usa. I Am Forced To Replace The Faulty Instrument Cluster With Another One. I Managed To...
felicjan-f1
JEEP LIBERTY
The Right Front Turn Signal Light Does Not Work?
The Bulb Is Okay And Right Signal Indicate Arrow Do Not Light Up, The Rear Signal Light Is On But Blinking Fast Once The Front Bulb Was...
DAvid Chen
MAF And Blinkers
Not Working
brown141522
ISUZU RODEO
Is There A Wiring Diagram For A 2020 Headlight?
Bought Replacement Plugs For The Low Beam Headlight And It Was With Red And Black Wire. I Can't Tell What Color The Old Wires Are To...
Lance214
Truck Stalled, Engine Cranks But Does Not Start?
Truck Stalled, Will Turn Over But Won’t Fire, Fuel Seems Okay, Checked For Spark, No Spark. Replaced Coil Still No Fire. Possible Bad...
Miles812
BCM, ECM?
All Of A Sudden It Started Running Rough. It Kind Of Came Out Of It, Then Back And Forth. Lacking Power Too. Shut Off On Me And Realized...
Jeff1234
CHEVROLET COLORADO
MAF Sensor And Blinker/hazard Lights Not Working
No Lights As Far As Turn Signals And Hazard Light The Fuse Is Good And It’s Getting Power As Well As New Bulb And Still Nothing. Maf...
brown141522
ISUZU RODEO
Can I Get The Valve Cover Torque Sequence And Spec?
I'm Replacing The Valve Cover Gasket; I Need To Know The Correct Torque Sequence And Spec For The Bolts.
ryurei4444
CHEVROLET SPARK
Transmission Not Shifting Properly?
I Replaced My Shift Solenoid B And C But I'm Still Having Problems Shifting And My Transmission Is Automatic.
lawrence16
ACURA TSX
668
669
670
