Shut Off While Driving And Will Not Crank?
I Was Driving My Car The Other Night And It Kind Of Hesitated And Jumped A Little Bit And Then It Stopped. And I Had To Have It Took Back To...
annlane239
Whining Noise From Engine?
Usually On These I Replace Rocker Arms Or Lifters Due To Tapping Or Clicking Noise From A Bad Lifter, But On This One None Of That, It'...
Alternator Replacement/swap?
Will I Be Able To Use An Alternator From A Malibu Max? Their Engines Are The Same.
joe86
System Lean And Misfires?
My Vehicle Listed Above, The Airbag Light Is On, Tcs Is On. Sometimes It Comes On And Out. The Car Runs Fine Only A Problem With The...
habibpallath
25 IMAGES
VOLKSWAGEN TOUAREG
Water Pump Removal Issue?
I Am Trying To Change The Water Pump On This Truck. I Am Trying To Remove The Sand Clutch. The Tips That I Have Found Say To Add Pressure To...
T-tom
Stereo Wiring Diagram Needed?
I Want To Replace The Front Speakers And Dash Tweeters. I Know The Tweeters Are Wired In Parallel. I'm Going With A Component System...
Larryfff
2023
KIA OPTIMA K5
Instrument Cluster Swap?
The Original Instrument Cluster Comes With A 40-pin Connector. I Have Another Cluster That Fits, But Its Socket Is 32-pin Only. Is There...
Mahmoud7301
Fans And A/C Do Not Work?
Been Trying To Figure Out Why My Car Seems To Be Running A Little Bit Too Warm For Me. Just When I'm Stopped, It Creeps Past 200 To 3/4...
DtB0yZ86
Scion Issue
Go Into Drive, Delay In Accelerating And Will Start Going And Stall Out Around Curves And Elevation. Makes Clanking Noises, And Vibration...
jflowercarter23
SCION XB
Why Does The Serpentine Belt Keep Breaking?
My Serpentine Belt Keeps Breaking.
James2023
SATURN L200
Sputtering And Popping With Loss Of Power?
My Vehicle Listed Above (d20 360 V8) Ran Good One Day I Shut It Down And It Rained Over Night I Fired It Up With No Problem, But When I...
ToniDemaria1970
1980
Does The Fuel Gauge On The Dash Have A Fuse?
Fuel Gauge.
Cop818
Heater Climate Control
Heater Still On. Control Penal Could Not Operate.
311wfauna
TOYOTA AVALON
How To Fill The Clutch Slave Cylinder?
I Had To Have My Clutch Slave Cylinder Replaced. The Guy The Put The Slave Cylinder In Didn't Fill The Slave Cylinder With Fluid Before...
Rebecca Shipman
TPM Codes C1580-00, C1581-00, C151D-00, And C1501-96?
My Vehicle Is Consistently Giving Me The Following Codes Even After Clearing Them, But I Do Not Have Any Dash Lights On Related To Tire...
beamz
JEEP WRANGLER
Engine Will Not Crank?
The Fuel Pump Has Been Changed, New Battery, All Fuses Working, And It Still Won't Crank. How Do I Get It To Start Or Why Is It Not...
kiva82985
Code P141f93, Electric Drive Issue No Start?
This Is A 14 B-class Electric Drive, No Start, 12v Battery Was Close To Sead So Installed A New Ine And All Lights On Dash Okay. The Only...
MERCEDES BENZ B200
Transmission Downshifting Issue?
Truck Is Downshifting At Normal Rpms. Sometimes It's Up To 4,000 Rpms Before Downshifting Or Sometimes I Can Feather The Gas Pedal To...
Michael Powell
Not Starting Issue Wiring Diagram Needed?
I Need The Wiring To A Few Sensors Color Coded Left To Right As Follows: Crankshaft Position Sensor Throttle Position Sensor Camshaft...
Seth Mauldin
MITSUBISHI LANCER
Fuel Delivery Issue, Engine Not Starting?
This Vehicle Listed Above Is A S Model Turbo. A Friend Of Mine Had It And It Was Driving For 20 Miles Then Won't Start The If You Leave...
MINI COUNTRYMAN
Will Not Stay Running?
Have Checked A Lot Of Stuff On It, Put New Starter On It, Checked Ground Wires. It Will Start But Shuts Off.
fast58moody
GMC ENVOY
Does Not Start After Replacing The Timing Belt?
Changed Timing Belt Car Won't Start. Checked All Fuses All Wires That I Touched And It's In Time Perfectly, Checked Four Times....
Lucas s
TCM Codes, Including "implausible Data" Code?
Car Has Tcm Codes, Including "implausible Data" Code. Upon Inspection Using My Autel Scanner, The Engine Speed Reported By The Tcm...
MikeHe
DODGE CALIBER
Where Is The Fuel Pump Relay Located?
Looking For The Location Of The Fuel Pump Relay. I've Received Several Different Answers.
drinagh
HYUNDAI ELANTRA
Where Is The Vehicle Speed Sensor Connector Located?
My Husband Attempted To Switch Out The Vehicle Speed Sensor And When Looking At The Part There Is No Connector. Can Anyone Tell Me Where...
Eimunoz24
AUDI A4
667
668
669
