Alternator Swap?
I Have The Truck Listed Above 1500 Sle And I Have To Replace The Alternator And I Am Going To Get A Used One What Years Are The Same To Swap...
Shawna bailey
Alternator Swap?
My Alternator Is Weak And Going Bad When I Had It Teated At The Parts Store, I Am Getting A Used One And Want To Know What Years Of Trucks...
Shawna bailey
Air Conditioning Not Working Properly?
Air Conditioning Blows Well And Will Switch To All Settings Such As Upper, Lower, Defrost. However, When It's Cold Outside The Air Is...
Christiankornegay99
OLDSMOBILE 88
The RPM Goes Down When Changing To Drive Mode Or...
Hello, I Have A 2017 Renault Duster And The Rpm Goes Down And The Car Start Shaking And Sometimes It Shuts Down, There Is No Faults...
Elias Sabbagh
RENAULT DUSTER
What Is This Little Hose?
Hello, I Have The Car Listed Above Sl Model. As I’m Changing The Spark Plugs, I Noticed A Little Hose/tube Broke Off And I’m Wondering...
SophiaJ26
How To Properly Remove Engine Step By Step..
Hello I Have A 1996 Toyota Tacoma 2.7l 4cyl. 3rz-fe It Has A 5speed Manual Transmission, Extended Cab, 4x4. I Recently Purchased A Good...
1996Taco
TOYOTA TACOMA
Rear Vents Blowing Hot Air?
I Have Searched And Cannot Find A Solution. I Have Dual Climate Control And The Front Climate Works Great With No Issues. I Will Have The...
khammondtx
How Many Screws Are On The Driver's Actuator Motor...
I Have Only Seen One And The Top Ones Do Not Feel Like They Are Screws. What Trim Panels Are Required To Be Removed? My Sle Trim Has Knee...
lhawba01
FORD EDGE
Rough Idle And Loss Of Power?
Greetings. Difficult To Start In The Morning. Normal Idle With Engine Still Cold; But When It Reaches Its Normal Operating Temperature The...
marioc68
#13 Fuse Inside The Junction Box Keeps Blowing?
I Moved My Exterior Side Mirrors, Then All Of A Sudden, I Didn't Have My Vanity Lights, Dome Light, Cargo Light, Nor My Radio. Also...
Robin Johnson
Rear Bed Gate Panel?
These Early El Caminos Had A Very Flimsy Rear Panel, Unreinforced. The Inner Panel Is ~ 4-6" Inside Of The Outer Panel. In The Process...
Addison Maddison
1964
CHEVROLET EL CAMINO
Starting Issue After Spark Plug Porcelain Broke Off...
I Changed Out 2 Spark Plugs And On One The Porcelain Broke Off Inside The Spark Plug Hole, But I Tried To Start It Anyway. It Wouldn't...
Heidi Agenter
Oldsmobile 1998 Ls
My 1998 Olds Lss With A 3.8l V6. Sometimes It Dies While Driving Or Will Not Start When I Tries To Start It. The Car Loses All Electrical...
Yvette Medina
OLDSMOBILE 88
Transmission Seal Leaking?
My Seal Is Leaking. Started At The Beginning Of The Week. I Got Under To Check. Something Told Me To Check The Bolts. A Couple Of Bolts Were...
steelestorm
JEEP LIBERTY
Seat Will Not Recline?
My Wife's Friend's Kid Pushed The Seat Recline All The Way Up. Now Seat Won't Recline Back. Seat Has Power And Moves Back And...
Chris Moody
Where Is The Keyless Go Antenna Located?
Hi Folks. I Am Looking For Keyless Go Antenna's Location For W212 Wagon. I Know About Rear Doors Where They Are. Cannot Find Where...
dobrzan
MERCEDES BENZ E350
Diagnostic Trouble Code C0110, ABS Light Turned On?
My Abs Light Came On. And I Ran Scan Tool But There Is No Current Code. In Code History C0110 Was Present. The Brakes Seem To Work Just As...
Michael Powell
Error Code P0171?
Hi, I Have Engine Code P0171. Could You Please Help Me See What The Issue Is From These Readings?
nguyenmike
NISSAN VERSA
Am I Being Duped By The Dealer Service Department?
I Recently Went To The Dealer For Service And Had The Following Work Done: Spark Plug Replacement, Induct Induction Service, Drain And...
eimacale
SUBARU FORESTER
A/C Is Activated, There Is A Ticking/fluttering Noise?
When The Car Is Turned On With A/c Off, There Is No Noise Coming From The Engine Bay, Until A/c Is Activated, And A Ticking/fluttering...
Sj5410
PONTIAC G8
Cleared Codes And Only Have P1345 Code Now?
Car Was Running Fine All Day, Started It And It Made A Knocking Sound. Checked Oil And There Was No Oil In It, Oil And Filter Had Been...
lil.lynn
16 IMAGES
No Fuel From Lines?
I Disconnected Both Lines From Hpfp And Turned The Ignition On, But Nothing Came Out. Is There A Fuse Or Relay For The Pump?
MINI COUNTRYMAN
Chirping/squeaking When I Step On The Gas Pedal?
Hello, I Bought The Vehicle Listed Above In Late March That Chirps/squeaks When I Step On The Gas Pedal While In Drive, But Not In Neutral...
judeslexus
LEXUS RX 350
Chirping/squeaking Noise In Front (dashboard Or Engine...
Hello I Bought A 2008 Lexus Rx350 In Late March That Chirps/squeaks When I Step On The Gas Pedal While In Drive, But Not In Neutral Or...
judeslexus
LEXUS RX 350
Shut Off While Driving And Will Not Crank?
I Was Driving My Car The Other Night And It Kind Of Hesitated And Jumped A Little Bit And Then It Stopped. And I Had To Have It Took Back To...
annlane239
666
667
668
