Speedometer Not Working Properly?
My Speedometer Keeps Bouncing Up And Down And Stops Working Sometimes. When This Happens I Have Loss Of Power Also.
tjwilliams
ABS Module Wire Harness Pinout Needed?
Abs Has A Lost Communication With Scanning Tools. And The Abs Malfunction Light Is On Steady. And I Think This Is The Reason Why The...
Tbabst
Replacing The Carrier Bearing?
I'm Replacing The Carrier Bearing On The Car Listed Above, Rwd. I Have My Driveshaft Taken Off, I Just Can't Get The Driveshaft...
Devin_balsitis
19 IMAGES
Air Conditioning Not Working.
My Air Conditioner Stopped Blowing Cool Air. The Mechanic Put Freon In It, Said It Didn’t Show A Leak With The Dye But Could Smell The...
Vgbsn425
MERCEDES BENZ 300
Overheating?
In The Morning I Checked My Coolant Level And Everything Was Just So Fine. In The Evening I Went For A Drive And Was Returning Home Suddenly...
Shehak Shah
Wiring Diagram Needed From The Ignition To Fuse Box To...
Need To Locate A Wire Short From Ignition To Fuse Box To Computer.
Kingeric
Struggles To Idle Upon Initial Startup Briefly
So As I Start It For The First Time, It Briefly Struggles To Idle And Stutters For A Few Seconds And Then Smooths Out
kraysmith
Do You Have To Pull Vacuum On A/C System?
A/c System.
barnes136
BUICK TERRAZA
Camshaft Replacement?
My Car Wouldn’t Start After Going To Two Places Not Far. Check Engine Light Was On Scanned It And Stated My Camshaft Sensor.
azdanno04
A/C Blowing Warm Air?
What Could Be The Issue If Whenever My Van Is Turned On The Vents Are Continuously Blowing Warm Air Even Though They Are In The Off Position...
Zaddieluv
PONTIAC MONTANA
Not Charging
Alternator Will Not Charge. I Would Like To Know Where Each Of The Wires Go That Are On The Back Of The Alternator. It's A 2g. Someone...
ProfLoveJoy
Tire Compartment Is Wet, There’s A Hole (approx 2-...
Tire Compartment Is Wet, There’s A Hole(approx 2-5cm Diameter) At Bottom Of Compartment Without Lid, Where Can I Get That Lid Or...
Topsyjoy
A/C Not Working?
Just Bought The Car, Was Told The A/c Didn’t Work When I Purchased It. Started Troubleshooting To See If I Could Diagnose The Issue And I...
Tennantnl
HONDA CRV
Sunroof Tries To Slide Using The Tilt Button And When...
I Just Replaced The Sunroof Motor For The Tilt/slide But During The Initialization I Pressed Between The Tilt And Slide Button During The...
jplatten
Car Keeps Vibrating?
I Have The Car Listed Above Ex Coupe. I Noticed The Car Would Vibrate So I Changed My Motor Mounts, Tires, Brake Pads, Ignition Coils...
Blondyhondy
What Problems Can I Expect In The Next 100000 Miles
Future Problems
Terry McGovern
SAAB 9-3 SPORTCOMBI
Transmission Whine Noise?
Noticed A Whine That Is Not Super Loud But Loud Enough To Annoy Me Happening Mostly In 1st Through 3rd Gear. The Harder I Take Off From A...
Civic12
After Replacing The A/C System The Clutch Does Not...
Had To Put A New A/c System On The Car. The Old Compressor Had Metal Shavings, So I Replaced The Compressor Expansion Valve, Pressure...
Robbins
Coil Pack Wiring Diagram Needed?
I Need A Wiring Diagram For The Front 3 Cylinders. I Had A Rat Chew The Wires.
Timothy Wayne Davis
61 IMAGES
Driver Window Wiring Diagram Needed?
Someone Stole My Front Driver Side Switch Assembly For The Mirror, Windows And Door Lock And Cut The Pigtails Off. I Was Able To Find...
tillisd
97 3.5 Swap Into 95 3.0
Trying To Determine If I Can Place A 3.5 From 97 Montero(not Sport) Into A 95 Montero (not Sport) That Had A 3.0. What Issues Besides...
warrick33
MITSUBISHI MONTERO
Which Fuses To Use For Hardwiring Dashcam?
Hi, I Was Looking At Hardwiring A Dashcam, But I Want To Make Sure I Pick The Right Fuses. I Have To First Check Which Ones Have...
mdardan
2023
Transfer Case Making Noise?
Is There A Common Issue On These? When I Put It In 4wd Mode I Hear The Transfer Case In The Middle Of The Car Making Noises. Its Louder Than...
Discharging A/C Refrigerant?
In Step 9 Of Your Article Titled "how To Vacuum And Recharge A Hvac Air Conditioner" You Say That Years Ago R12 Was Slowly Bled Out...
FTW1996
Battery Draining While Driving
Hi There, I Have A New Alternator And Battery In The Car. When The Engine Turned On The Reading Shows 14.15 Volt. And When It Is Turned Off...
Biro Zoltan
ACURA MDX
635
636
637
