No Spark?
I Replaced The Torque Converter. Afterwards It Started And I Drove It For Two Days. The Freeze Plug Behind The Motor Blew. I Separated The...
MamaJo4260
DODGE RAMCHARGER
Can I Get An Accelerator Position Sensor Plug Color...
My Wires Were Cut On My Accelerator Position Sensor, And I Need A Diagram So It With Color Coded So That I Can Put My Wiring Back Together...
Scotty Pinson
PONTIAC G6
Can I Use My Phone To Plug In To Scan My Throttle Info...
Installing Software In My Phone Without Obd Scanner.
Shehak Shah
A/C Charging With Small Cans?
I Recently Watched Your Video On Vacuuming And Charging The A/c. I Recently Put A New A/c System In My Vehicle Since It Never Had One. I'...
Atyrone30
JEEP WRANGLER TJ
After It Has Been Sitting All Day, It Starts, Then...
When I Go To Start The Vehicle In The Morning Or After It Has Been Sitting All Day, It Starts, Then Bogs Down And Sometimes Dies. If It...
beamz
How To Bypass The Front Heater Core?
I Would Just Like To Know What To Do To Bypass The Front Heater Core.
Josh Geldermann
LINCOLN NAVIGATOR
How Can A Burnt-out Indicator Lamp For Charging Affect...
Charging System.
Fixmyproblem
OBD Codes PO102, PO121, PO137, PO154, PO155, PO171...
Po102, Po121, Po137, Po154, Po155, Po171, Po174, Po300, Po440, Po507.
Skullboy65
No Power To Anything When I Turn The Ignition Switch...
Good Battery And New Fuse Link In Fuse Box.
Mr.Bill66$
17 IMAGES
4x4 Not Working?
I Have Electric 4x4 Push Button On The Dash. I’m Getting 12volts To My Front Differential. And Only 3volts To The Speed Sensor On My...
Brandon5.7
CHEVROLET 1500
While Driving Engine Will Not Go Above 3,000 RPMs?
My Pickup Started Not Going Above 3,000 Rpms When Driving, This Happen Shortly After I Was Driving About 200 Miles Usually I Stay In Town...
Thedoomslayer21
CHEVROLET CHEYENNE
Don't Have The Chipped Key Or Key Fob HELP
I Do Not Have The Original Chip Key For This Vehicle It Is Lost I Have The Key That Opens The Door And That Is It Please Help I Need To Get...
Jonesb5life
Lost The Key, How To Start It Without The Chipped Key?
I Lost The Key To My Truck Listed Above To Keep It The Chip In It How Do I Get This Started Without The Chipped Key? I Have The Key That Can...
Jonesb5life
Think It About The Transmission Or Shift Solenoid?
When My Car Freshly Start. It Run Only Until 40-50 Meters. And Then Its Stop It Won't Into Gear. I Tried Reverse And Drive It Doesn'...
Toklak
SATURN AURA
Instant Milage Per Gallon Stopped Working In My Dash...
Recently My Instant Milage Per Gallon Stopped Working In My Dash. (I Recently Had A Heater Core Replaced). How Would I Fix This Issue...
ken52
LINCOLN CONTINENTAL
No Charge Indicator Light
Will My Rangers Charging System Work With A Burnt Out Charge Indicator Bulb
Fixmyproblem
Preventative Turbo Repair/replacement?
I Have The Vehicle Listed Above Sport. I Had A Misfire Issue As A Result Of A Loose Timing Chain. I Had That Repaired About 6 Months Ago And...
mikejsmith1985
Transmission Not Shifting Properly After Sitting And...
Thanks For Listening Guys. I Purchased This Car About Two Years Ago. Around Six Months Afterwards, I Noticed A Hard Shift After Sitting In...
Tim Broome
SATURN ION
Code P0712, Do I Just Change The Fluid And Filter Or...
I Have A P0712 Transmission Code Along With P0300 Misfire Code. I Need Help With The P0712 Code. My Question Is, Do I Just Change The Fluid...
Ronald DeVold
Will Not Start, Where Is The Fusible Link Located?
The Car Will Not Start. Cranks But Doesn’t Start. We Replaced A New Starter And Nothing.
jeccarule10
After Replacing The Ignition Switch The Car Will Not...
I Replaced The Starter Then I Couldn't Get The Vehicle To Start At All. I Replaced The Ignition Switch And Beforehand The Car Started....
Firecracker81
NISSAN 350Z
Transmission Slipping?
Friday Evening My Car Drove Fine From The Shop, Came To A Stop Went To Go And All Of A Sudden, My Car Would Not Move Forward Had To Bring...
stonejr1
PONTIAC G6
Bypassing The A/C Compressor, What Is The Belt Size?
Hello, I Need To Know What Belt Size. To Bypass The A/c Compressor Because Compressors Are Expensive. Thanks
Odom
KIA FORTE
Does Not Start, Where Is The In-line Fusible Link...
No Start On Engine.
jeccarule10
After Replacing The CV Axle, The Lower Control Arm...
Hello All, I Just Replaced My Cv Axle On My Car Listed Above Gxe Passenger Side. I Replaced The Lower Control Arm And The Axel Along...
JC-842
18 IMAGES
636
637
638
