How To Change The CVT Transmission Fluid?
And If You Know What Temperature To Wait Until Before Opening The Fill Plug Again While Its Running.
SUBARU OUTBACK
1998 Chevy Camaro
1998 Chevy Camaro Air Blend Door Actuator Location And The Egr Valve V6. Thanks!
MikeCash
ABS Issue?
I Know This Is A Common Issue On These Cars And I Replaced A Few Actuators Before, But I Want To Confirm. As Soon As Hit The Brake To Stop...
TOYOTA PRIUS
Transmission Issue, Vehicle Shudders At Low Speeds?
On Low Speeds, Such As On My Driveway, If Going Up It Feels Like It Shudders And The Gets A Better But I Feel Something Right At Higher...
SUBARU OUTBACK
Where Is The Air Blend Door Actuator Located?
Air Blend Door Actuator Location. Thanks!
MikeCash
Front End Noise, Popping Noise When Driving Over Bumps...
Replaced Lower Control Arm, All Engine Mounts, But Still Making Popping Noise When Hitting Bump, Accelerating, Decelerating And Putting...
hotrod53
Starter Relay Does Not Engage After A Theft Attempt?
Truck Will Start By Jumping Poles On Relay. Have Replaced Key Cylinder. Signal Is Apparently Not Coming From Ignition.
Chavor
Airbag Light Stays On?
My Airbag Light Stays On. I've Got A Mechanic To Check The Codes And Initially There Were No Codes Coming Up On The Scanner. Then...
CTAKIS
HOLDEN BARINA
Auto Shut Down Fuse Blown
Auto Shut Down Fuse Blown. Replace It Blows Again. Had To Replace The Coil. New Requires A Resister Old One Didn't Have Resistor. Could...
Marvin Martian2
After Replacing The Clock Spring The Airbag Light Is...
Replaced My Clock Spring. Now All Steering Controls Work But The Airbag Light Is Still On.
stockman28659
HYUNDAI SANTA FE
Shaking While Driving But Not When I Brake Or Turn
I Haven't Gone More Then 50kmh, But It Shakes More With How Fast I Go, It Makes A Shuddering Sound But Stops When I Brake Or Turn, I...
Josh Wolfe
HONDA CRV
Keeps Blowing Auto Shut Down Fuse
Previously Was Checking Relays And Fuses As The A/c Clutch Not Running. Truck Sat For Bit Which Was 10 Yrs. So I Topped Up The R 12 The...
Marvin Martian2
The Engine Does Not Start I Was Changing A Turbo?
I Have A Benz 642 Engine, I Was Changing A Turbo. I Disconnected The Battery When Changing The Turbo After Finishing Everything I Contacted...
Emmanuelngandu
MERCEDES BENZ ML550
Turn Signals Do Not Work?
My Turn Signals Don't Work But My Flashers Do, So The Bulbs Are Good. I've Replaced The Multi Switch On The Column, The Green...
MissEvvie
DAEWOO LEGANZA
Front A/C Not Working?
I Have Heat And A/c In The Rear Of The Van, And I Have Heat In The Front But No A/c. What Could Be The Problem? Please Help.
Jeremyshort
HONDA ODYSSEY
Removing Front Panel To The Dashboard?
The Previous Mechanic Who Worked On My Car Failed To Put The Front Panel Back In Place. There Is A 1/2" Gap Between The Panel And The...
Debra Procopio
CHRYSLER VOYAGER
Code P0390, Where Is The Camshaft Position Sensor...
The Way It Was Acting, I Thought It Was Possibly The Transmission. I Took It By An Auto Parts Store, And They Checked It Out And It Came...
mrsdebismith
Speedometer Fluctuates Between 15-25 Mph At Speeds...
1995 Honda Accord 4 Door With The 2.7 Liter V6. The Speedometer Fluctuates Between 15 And 25 At Speeds Below 20 And Sticks Around 20 At...
Nash Waldrop
There Is A Loud Slapping Noise From Bottom Half Of The...
No Vibration Like Bad Bearings, Unhooked Serpentine Belt To Eliminate Outside Possibilities.
5304072702
Will Not Crank Over I Have Power To The Signal Wire...
I Have Power To The Starter Main Trunk, I Have Power To The Signal Wire And Have Checked The Starter. Still Won't Start, What Could It...
William Burkhart
DODGE MAGNUM
After Market Radio Bluetooth Sound Not Working?
Hello, So, I Have Purchased Two Radios And Returned The First One Because I Thought It Was The Radios Problem, But It Was The Same...
dana.rosenbaum
CHEVROLET CRUZE
Drivetrain Malfunction/fuel Supply Warning And Code...
I Have A 528i And Keep Getting A Drivetrain Warning And Recently It’s Followed By A Fuel Supply Warning. I Have A Cheap Code Reader That...
Jtrace
BMW 528
White Color Exhaust
Hello I Have A Car Suzuki Euroswift Sedan Engine G13b Vin Tsmmah35s30892734 Engine Oil Level Normal (between High And Low) Engine...
Yosef Levy
SUZUKI SWIFT
Knock Sensor Code?
When Very Cold In The Winter The Engine Would Idle Rough Until Slightly Warm And Go Away, Then It Started Happening In Warmer Weather But...
DLynch10
28 IMAGES
GMC TRUCK
How To Remove And Replace The Timing Belt?
Hi Guys, Would It Be Possible To Send Me The Removal And Installation Guide For The Timing Belt, As It Is Due? Richard
imaflyingkiwi
38 IMAGES
CHEVROLET COLORADO
634
635
636
