Battery Drains Fast?
My Battery Drains Fast, It's Not The Alternator. I Have Switched And Bought Around 5 Battery's.
Carmen Medina
Radiator Cooling Fan Does Not Work On Low Or When The...
Fan Works On Low When A/c Is On. Only Works When Engine Temperature Passes The Center Or High Temperature Reading On Gauge. Also, The A/c...
Rbaldemar
Code P0342?
Okay, I Have The Truck Listed Above 1500. I Am Having Problems Diagnosing This Truck. I Think I Need A Pcm, But I'm Not Sure. My...
Eluper123
Bad Truck
Okay, I Have A 2003 Silverado W A 4.8l 1500. I Am Having Problems Diagnosing This Truck. I Think I Need A Pcm, But Not Sure. My Problem...
Eluper123
Passenger Side Airbag Light Is On After Hitting A Curb...
I Hit A Curb Yesterday Backing Out Of A Driveway Now The Light Is On For The Passenger Side Airbag.
Katwolf79
Dead Beat Truck
Eluper123
My Vehicle Will Start To Overheat After Driving For A...
My Vehicle Will Start To Overheat After Driving For A Long Time. I Was Stuck In Traffic On The Freeway For About An Hour And It’s About...
torumalex7
PONTIAC G6
Turn Signal Hyper Flashing?
A Few Weeks Ago, Before I Installed New Front Headlight Assemblies, The Front Passenger Turn Signal Began To Hyper Flash, Indicating A...
Ellenham
Quick Access Rear Freeze Plug Replacement?
Hi, My Name Is Chad, I Have A Rear Freeze Plug That Needs To Be Replaced On My 1998 F150 And I Wanted To Use Your Quick Method Of Cutting...
mayhaim
Trouble Starting Then Shutting Off?
My Car Has Been Having Issues Starting For A Few Months. Yesterday I Tried About 30 Times To Crank It, And It Finally Started. Then, About...
Kimberly Mariee
GMC ACADIA
Where Is The Oil Pressure Sensor Located?
Trying To Locate The Oil Pressure Sensor On The Car Listed Above Turbo 2.0 Base Model. Thanks In Advance!
axle928
BUICK REGAL
Oil Pressure Sensor Location
I'm Trying To Locate The Oil Pressure Sensor On A 2015 Buick Regal Turbo 2.0 Base Model.
Alexandre Chavez
BUICK REGAL
Oil Pressure Sensor
I'm Trying To Locate The Oil Pressure Sensor On A 2015 Buick Regal 2.0 Turbo Base Model.
Alexandre Chavez
BUICK REGAL
How To Remove And Replace The Radiator Fan?
Can You Provide A Set Of Instructions For Removing The Radiator Fan Of The Car Listed Above? Thanks For Any Help.
zeevon
SATURN ASTRA
Got In To Drive My Car And Clutch Pedal Went To The...
I Don't See Any Leaks On Master Cylinder, And I Can't Locate The Clutch Slave. Any Ideas Or Help Would Be Appreciated.
Jr Payne
VOLKSWAGEN GTI
Rough Idle And Shuts Off At Low RPMs?
Car Starts Up No Problem. Seems Like When The Engine Gets Good And Warmed Up It Wants To Idle Rough At Low Rpms And Sometimes Shuts Off. It...
Cmanoverfield
DODGE STRATUS
ECU And PCM Pinout And Wiring Diagram Needed?
Hey, I'm Remodeling My Old Ford For Offroad And I Would Like Complete Pinout And Wiring Diagram Of It. Thank You.
Hans Lescher
Water Pump And Timing?
What Happened After Water Pump Change? If Belts Aren’t Tight What Happens? Will The Car Start?
Moses Griffith
DODGE STEALTH
Check Engine Light Turned On With Codes P1166 And...
The Car Was Running Normally And Continues To Run Normally. I Was About 60 Miles From Home, And It Drove Home Continuing To Run Great With...
benlee1199
A/C Freon Level?
So, I Plugged In To The Low Pressure And It Says It's At 40 Psi, But I Live Here In Texas. If The Sun Is Facing Towards Me Directly In...
Roberto Duran
RAM 1500
Engine Starts And Warms Up Then Shuts Off?
Will Restart And Run For A Short Time Then Shuts Off. At First This Only Happened In Air Temperatures Below 65 Degrees. Ran Fine In...
Tandy L Armstrong
Car Starts Will Not Drive After Having The Brakes Lock...
The Car Had Brakes Locked Up. Replaced All Brakes Pads Car Starts Now But Won't Drive. It Goes Into Gear. Brake Pedal Functions Normally...
Jen1478
Car Over Heated Due To Lack Of Antifreeze?
So, It's A Used Car From Byrider And It Decided To Tell Me Engine Overheated Idle And It's On The Car Off. Now My Uncle Decided To...
Mesasfinnest13
Accelerating On The Highway Occasionally The Diesel...
After Accelerating On The Highway Occasionally The Diesel Engine Pre-flow Light Was Flashing, Then After A Few Km The Engine Light Came On...
Gentrit Berisha
VOLKSWAGEN GOLF
I'm Getting The P0731 Code For Incorrect 1 Gear...
This Freaking Wagon Man! Ken, Now I'm Getting The P0731 Code For Incorrect 1 Gear Ratio! Before It Was P0730. I Changed The Fluid And...
Willie Hurlocker
DODGE MAGNUM
572
573
574
