Code P0992?
Car Wouldn't Switch Gears; It's Stay In 1 Gear It Doesn't Change And The Rpm Doesn't Work. It Caused The Car To Run Hot.
senicaholt
DODGE MAGNUM
Where Is The Blend Door Actuator Located?
What Blend Door Actuator Do I Need To Change If The Cold Air Is Only Blowing Out From The Defrost And The Floor? And Where Is It Located?
owen.callahan84
CHEVROLET 3500
Oil Leak Coming From The Oil Pan?
I Have A Major Oil Leak Coming From Oil Pan Can I Replace Gasket Without Letting Engine And A Water Leak Coming From The Underneath The...
Back seat
16 IMAGES
CHRYSLER SEBRING
Not Starting
2007 Suburban I’ve Had To Jumpstart It For The Past Six Months Anytime That I’ve Gotten Into It And Now It Won’t Start At All After...
Piper Janne
Battery Keeps Draining?
Replaced Alternator And New Battery But New Battery Still Going Dead Not Getting Charge.
susanestes423
FORD FIVE HUNDRED
Disconnected Electrical Cable?
Just Bought The Vehicle Listed Above And, In The Hood, There Is Something Electrical Disconnected. It Seems It Is A Rigid Line That Comes...
PorkChopExpess
CHEVROLET TRACKER
After Replacing The Left Side Cooling Fan, It Runs For...
I Replaced Left Side Cooling Fan It Runs About 10 Mins Then Stops?
azredneck
CADILLAC DEVILLE CONCOURS
Radiator Fan
I Replaced Left Side Fan And It Works Fine For About 10 Mins. Then Stops.
azredneck
How Many O2 Sensors Does My Car Have?
Teia Weaver
23 IMAGES
Battery Light Stays On?
I Was Told My Alternator Was Failing So I Had It Replaced. However, My Battery Light Is Still Illuminated While The Engine Is Running.
elewis84
Passenger Seat Lever Cable Replacement Part Question?
Passenger Lever Cable Broke Including Bottom And Top, Is There Any Way To Get Those Parts Or Do I Have To Find A Used Seat? I Took It Apart...
Back seat
CHRYSLER SEBRING
Replaced Engine With Another Same, Vacuum Diagram...
I Have Been Putting Everything Back Together From Engine Swap And Can't Figure Out The Hoses From The Brake Booster And Where Each One...
Jay Zee
PCM Replacement?
I Replaced The Battery, Starter And Bought A Programmed Pcm And Had Alternator Checked, It's Good, New Fuel Pump Too. My Problem Is...
sheriennis4
19 IMAGES
CHRYSLER PT CRUISER
After Replacing The Water Pump, I Now Have A Crank No...
I Changed The Water Pump, Now The Car Won't Start. I Can Connect To Bcm With Scanner But Can't Connect To The Engine Or Pcm. The...
Brokenhalo92
LINCOLN MKX
Battery And Starter Wiring Diagram Needed?
I Was Changing My Battery One Day And Just Lost The Part That Goes For The Wiring On My Battery Terminals, So I Don't Know Which Wires...
Hoganbet
FORD CONTOUR
High Temperature Reading, Warm A/C Output?
Vehicle Has New Water Pump, Thermostat Housing, Thermostat, Aluminum Radiator And Cap. When Idling, Temperature Rises Well Over...
Gabriel Abreu
TOYOTA SIENNA
Push On Gas Pedal Car Goes Nowhere, Then Have To Turn...
Car Drives Fine Then Out Of Nowhere It's Like All The Power Is Lost Except Power Is Still On, Then When Trying To Accelerate No Rpms...
Askani22
TOYOTA YARIS
Accessories Not Working?
My Serpentine Belt Broke Last Week And I Replaced It Two (2) Additional Times After The Additional Replacement, All To No Avail. So, After...
Tahari2018
MERCEDES BENZ GL450
Car Switches Into A Kind Of Over Revving And Hardly...
On Drive The Car Switches Into A Kind Of Over Drive Thereby Revving The Car Hardly And Then Driving Becomes Nearly Impossible. The Problem...
Ibro
20 IMAGES
TOYOTA CARINA
White Smoke And Oil Leak After Changing The Air Intake...
Had Changed The Air Intake To Turbo Pipe Part Number A6395282082 As It Had Melted Where It Goes Into Turbo. Once That Was Done, I Took...
m_c_84
MERCEDES BENZ VITO
Smoking Under The Hood Not Running Hot
As Soon As I Start The Vehicle It Almost Imediate That White Smog Starts Coming From The Passenger Side Under The Hood. Drives Fine And Not...
Tawnya Renee Caesar
NISSAN QUEST
Cranks Over But Does Not Start?
So, I Have An Issue Where My Suv Will Crank But Won't Start. My Fuel Pressure Seems To Be Running A Little Low At Around 50 Psi But...
Kendrick Noetzelman
P0773 Code
Check Engine Light Came On. P0773 Code. Vehicle Shifts Perfectly Fine. Light Comes I Disconnect The Battery For 5 Minutes And Put It Back...
Alexa Stevens
KIA FORTE
Clutch Line Bellhousing Retainer?
I Replaced My Clutch Back In April. I Accidentally Broke The Retainer Holding The Clutch Line Through The Bellhousing, Ever Since Then It...
Axelponce
Clutch Line Bellhousing Clip
I Replaced My Clutch Back In April. I Accidently Broke The Retainer Holding The Clutch Line Through The Bellhousing. Ever Since Then Its...
Axelponce
571
572
573
