Oil Sensor Dinging But No Light?
The Sensor For The Oil Is Dinging Without A Light Coming On. It Does It Around Curves And When You Stop At A Stop Sign Or When You Take Off...
Greg Mayes2
Poor Acceleration?
The Vehicle Starts Up Fine And Will Accelerate When I Shift Into D Or R Just Fine. However, Sometimes When I'm Driving, And I Come To...
sparedes0515
Slow Start And Check Engine Turns On?
My Car Has Never Started As Quickly As I Would Like But It Has Gotten Worse Lately. The 'check Engine Light" Has Started To Go On (...
jerryinnb
FORD PROBE
After Replacing The Head Gaskets, The Engine Will Not...
I Replaced The Head Gaskets And The Day I Got It Going It Was Running Fine. A Little Hesitation But Not Much. It Shut Off Right Before I...
bgoode051791
JEEP LIBERTY RENEGADE
More Classics Spotted Around The Routes
From Time To Time I Post Pics Of Decently Cool Cars I've Seen. Here Are The Latest. Including A Friend's Cadillac Grand Marquis...
Harry P
Starting A Car That Hasn't Moved In 4 Years
Hello, Everyone, I Have A 20-year-old Corvette In A Garage Since The Pandemic. It Initially Didn't Move Due To A Lack Of Need/the...
AVetteInTheGame
CHEVROLET CORVETTE
Metal Spinning Contact Noise Coming Through The...
Can Hear A Metal Spinning Contact Noise Coming Into Vehicle Through The Dashboard Like A Steady Whining Noise When Traveling Around Town...
nunofubiz9
What Special Tools Do I Need To Buy To Rebuild My...
My Transmission Is Out In All Gears.
Chadburris
CHEVROLET AVALANCHE
Tachometer Stopped Working While Driving?
Hello, Last Night While Driving On The Freeway With Cruise Control On I Experienced My Car "lurching" Briefly Then The...
Scotty G 1962
HYUNDAI ACCENT
White Fumes From Exhaust?
Hello, My Car's Engine Oil Is Totally Full And Also My Coolant In Radiator. Yesterday At Night I Switched On My Phone Flash To Look...
Shehak Shah
Engine Cam Code P0021?
I Thought The Problem I Had With The Mess While Driving Was Solved By Replacing The Plugs, But It Came Back. So, It Seems To Only Happen...
SUBARU OUTBACK
Anyone Ever See A Bcm Do This?
Hey Guys. 99 Century 3.1l That I Just Bought. Air Bag Light Is On. I Kinda Like Safety Features So I Figured I'd At Least Look Into It....
Harry P
Where Is The Crankshaft Position Sensor Located?
I Can't Find The Location Of The Crankshaft Position Sensor. The Vehicle Listed Above Is A Petrol Vehicle (the Lf4 Engine I Believe)....
Sjoerd
CHEVROLET EPICA
Can't Seem To Locate The Sensor. Only Find Diagrams For 2.7
ThatOneFishGuy66
HYUNDAI SANTA FE
I'm Having Trouble Locating The Position Of The Sensor. I Only Find Answers For The 2.7l Not The 3.3.
ThatOneFishGuy66
HYUNDAI SANTA FE
Where Is The OBD Port Fuse Located?
Good Morning, I’m Writing To Find Out Where Exactly The Obd Fuse Is Located On My Vehicle Listed Above? When I Plug In The Obd Tool...
Sean86
MITSUBISHI CHALLENGER
What Causes MAP Sensor Failure?
I Have Recently Purchased A New Vehicle. I Had The Car Just Under 24 Hours When The Tire Pressure Light Came On. I Filled The Tires Up And...
Johead
KIA PICANTO
Ignition Timing Issue?
I Changed The Plugs Yesterday And The Van Seems To Run Better, But It Seems To Be Using More Fuel. I Also Was Running The A/c As It Was Hot...
JeffreyDJudson
How To Replace The Headlights?
Hello, I Have The Car Listed Above 328i And Have Been Experiencing Headlight Problems. I Don’t Know How To Change Them Or How To Even...
mhill9204
BMW 328
The Engine Will Not Crank Just Click?
Charged The Battery With A Battery Charger It Shows It Has Full Charge But, Still It Won't Crank Just Clicks?
Amy Kramarsic
GMC SUBURBAN
Power Steering Not Working?
Power Steering Went Out On The Vehicle Listed Above. I Had Replaced The Rack And Pinion, And The Pump And The Steering Is Still Really Hard...
Ash Simmons
TOYOTA HIGHLANDER
Low Oil Pressure?
Low Oil Pressure, Occasionally Ticking, Stuttering Upon Acceleration And Or When Taking Off From A Stop.
Tank60
Loud Thud/clunk Even Shifting Between Into Reverse Or...
Is This A Symptom Of Bad Mount, Or Transmission Going Bad It Something Else? I've Noticed "hard Shifting" For A While, But...
Metapink
Adding A Manual Switch For Coolant Fan, Is There A Way...
My Coolant Fan Will Only Come On When It Gets Hot, Like Normal. But I Wish To Add A Manual Switch That I Could Turn On When I Turn On The A...
jlberel3
FIAT 500
Changed Ignition Switch
Changed The Ignition Switch In My Malibu Classic But It Is Not Registering My New Keys. The Theft Light Is Blinking. Can Someone Tell Me...
Dorsey43
CHEVROLET CLASSIC
573
574
575
