Suddenly the engine it will crank but not start up?
BYSTANDER
  • 1994 FORD RANGER
  • 4.0L
  • V6
  • 15,000 MILES
The engine has never failed to start. After attempting to activate fuel pump to drain tank for evap system repair, suddenly with no warning, it refused to start. Checked secondary system with spark tester, there was no spark.
Wednesday, October 2nd, 2019 AT 10:47 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,302 POSTS
Lets check fuses #34 and 19 with the PCM power relay. Here are guides to help you with the engine wiring diagrams below so you can see how the system works as well as the fuse and relay locations:
and
This can help as well:
Check out the diagrams (below). Please run some tests and get back to us. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Friday, October 4th, 2019 AT 1:57 PM
BYSTANDER
  • 5 POSTS
Wow! I'm impressed with the response--thank you. The information was excellent, but it applies to an OBD2 system. This, of course, is a 1994 truck; OBD1 --quite a bit different. Might you be able to send the same set for the 1994? Even the fuse box layouts are very different. It would be most appreciated since I don't even have an owner's manual. As soon as I can complete the Evap system repairs, I'll be ready to work on the no start problem.
Again---thank you so much for your willingness to help.
Thursday, October 10th, 2019 AT 8:56 PM
MASTERWRENCH
  • 258 POSTS
Just thought I'd jump in here. I know you said you currently have no spark, however I'm curious about the other evap system repairs you mentioned. In your initial post, you indicated the engine started and ran fine prior to activating the fuel pump to drain the system for an evap repair. Can you elaborate?
Monday, October 14th, 2019 AT 3:54 PM
BYSTANDER
  • 5 POSTS
Masterwrench:
I should have said that a little differently: This situation began when I discovered there was a failure to hold pressure somewhere in the EVAP system---( It turned out to be a failed filler neck hose thanks to California continually reformulating the gas, disregarding rubber compatibility of fuel system parts.) Thanks EPA, thanks carburetor!
Draining the fuel tank was done in case it needed to come out for cleaning.
Up to that point, anytime the engine needed to be running for any reason it never failed to start the entire time it has lived here. When the no start happened, relays checked okay, but spark was a no show. That triggered my mayday.
There may be a clue, the jumper technique used to pump out the fuel didn't work as advertised with key on, fuel pump relay jumpered it would pump for 2-4 seconds then stop instead of continuing to run. Didn't seem right, so turned to good ole' siphon hose which did the job, but still no spark. So, that job's done. Everything seems okay. So, did I miss something? Did I burn something out? I have a feeling it'll be something really embarrassing! Hope not.
Sunday, October 20th, 2019 AT 5:49 PM
MASTERWRENCH
  • 258 POSTS
Bystander,
Okay, that makes sense. From the sounds of it, since your jumper didn't give you the desired results (running the fuel pump), my guess is whatever you jumped somehow caused the current condition. I would start by checking the power supply to the ignition control module and the coil (see attached diagrams). On the ignition control module, check pin 8 (red wire) with the key in Run or Start. You should see battery voltage here. Also, check the red/light green wire at the ignition coil. This circuit should also have battery voltage with the key in Run or Start.
Monday, October 21st, 2019 AT 7:16 PM
BEN ZINTEL
  • 1993 FORD RANGER
  • 4 CYL
  • MANUAL
  • 150,000 MILES
The Ranger will turn over and will start with starting fluid. But will only run with the starting fluid. There is fuel pressure at the test port. I have not gotten a fuel pressure gauge yet to see how much pressure.
Tuesday, March 2nd, 2021 AT 6:58 PM (Merged)
KEN L
  • 43,302 POSTS
Yes you will need one an auto parts store will rent it to you, but check the fuel pump safety switch by the passengers foot well kick panel to see if it has been tripped. Here is a guide to test the fuel pressure.
Please let us know what you find so it will help others.
Best, Ken
BEN ZINTEL
Hello the fuel pump is working and the pressure is 40 psi. When I try to start the truck it almost gives you hope that it will start. But of course it does not unless I spray starting fluid in the throttle body. And it will only stay running as long as I keep spraying starting fluid. I looked at the fuel pressure regulator and pulled off the vacuumed line I did not see or smell any gas. I bought a new regulator anyway I think I am going to try that next. I will keep you posted.
Thank you, Ben
KEN L
  • 43,302 POSTS
Does the injector have pulse? here is a guide that can help you.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
JACOB ALEXANDER
  • 1993 FORD RANGER
  • 4.0L
  • V6
  • 140,000 MILES
I just put all new gaskets on my motor and once back together. I am having crank no start. It was throwing trouble codes 114 and 116 so I replaced both the coolant temperature sensor and intake air temperature sensor after which it still shows those codes and also 513 now. I checked the wires to these sensors and I was showing over 6.3 volts. I also believe it is getting flooded when I attempt to start because I can smell gas pretty strongly and spark plugs are wet. I am not sure if I need a new PCM, ignition module, or if it’s a wiring problem. I got an engine wiring harness off another truck same model and year in hopes it is a wiring issue. But need some direction as it is my daily and got to get going. Thanks
Tuesday, March 2nd, 2021 AT 6:59 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
This sounds to me like you have an ignition issue going on. I have included a link that will help you figure out what is going on below:
I have also included a rundown on how your ignition system specifically works in your truck in the diagrams below. Check it out and let us know what you find.
Thanks,
Alrx,
2CarPros
KEN L
  • 43,302 POSTS
If I can jump in here, please check the engine grounds it sounds like one is disconnected. This guide can help as well:
DIANNA ALLEN
  • 1993 FORD RANGER
  • 4.0L
  • V6
  • 4WD
  • 60,000 MILES
Used it and parked in my driveway unloaded it and went to park in side drive and it didn't start. Just cranks over but no start. When to check on the spark but have tried so much the battery now is on the charger. So right now I can't check to see if it is getting spark, the plug looks good. I need help, can't get it to shop to get it fixed. It is on me to get it fixed.
  • 52,797 POSTS
Good afternoon,
Can you hear the fuel pump run when you turn on the key? Can you check the pressure?
When the battery gets charges, test again for spark.
It could be the fuel pump.
CLIFFCARLA
  • 6 POSTS
  • 1993 FORD RANGER
  • 3.0L
  • 6 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
Every now and then I can go to start it and it won’t start, just cranks and cranks, won’t start until I pop the hood and shake the fuse box and it starts. Could someone please help?
More then likely this is a relay issue. I would think the fuel pump relay is the issue so next time this happens, let's not shake the fuse box, let's open the hood and wiggle each relay one at a time and then try and start the engine. We want to try and narrow this down to one relay so that we can address either the relay or the wiring issue for that relay.
Below is the fuse box for your review. Let us know what happens. Thanks
BROWNBOYZ77
  • 1993 FORD RANGER
  • 4.0L
  • 6 CYL
  • MANUAL
  • 46,000 MILES
I have the truck listed above XLT model. I bought it a couple days ago and the guy said it would run sometimes and sometimes it does not want to start. I got it to start after a couple tries of cranking. Ran fine but had an idle that seemed to have a misfire but ran great driving. I let it sit overnight and it did the same thing. I hooked a battery charger to it cause battery was getting low. After a little while it fired up and idled but still had that misfire like idle. The rpm's bounce from 900 to 1,000. Engine light is on so I attempted to read the codes with a $6,800.00 Snap On scanner and got a communication error. The plugs and coil are new. I also checked the ECC fuses and they are all good. Anyone have any idea?
Tuesday, March 2nd, 2021 AT 7:00 PM (Merged)
  • 52,797 POSTS
Good morning.
You need to do some basic checks to see what condition the engine is in.Start with a compression test to verify it can produce power.Then check the fuel pressure to be sure the fuel pump is providing the required pressure to the fuel system.
As far as the scan tool,is there power to the connector?
let me know
CPT_HOSER
  • 1993 FORD RANGER
This is a 1993 ford ranger. 180,000 miles. It normally starts ok. Occasionally it will turn over but won't start. If you keep turning it ever min or so for a few seconds, it will start after about 20 min.? I have had the starter replaced. No error codes show on the computer. Happens occasionally when engine is cold or warm. What do I look at next?
LOSONE
  • 1,616 POSTS
Back to basics! Check for spark and fuel. No spark probably the ignition modiule. No fuel; fuse, relay, fuel filter or the fuel pump.
Here are a few guides to read, they will help you figure this one out
