Is There A Separate IAC Valve On This Car?
Iac Valve.
Nancy Bruner
HONDA CRV
Where Is The Upstream O2 Sensor Located?
Looking For The Location Of The Upstream O2 Sensor On The Car Listed Above Titanium Model.
flip373
For The Cooling System, How Do I Bypass The Heating...
Heating Core Is Dumping Coolant And I Need To Know How To Bypass The Unit. I Have Replaced The Radiator, Thermostat, And Water Pump...
Kiris Gaines
DODGE DURANGO
Inner Vehicle Communication?
I Want To Be Able To Use The Microphone Of My Car To Talk To The Speakers So People In The Back Can Hear And Not Yell All The Time.
Alexandros Kastanidis
MERCEDES BENZ VITO
Rear Speakers Not Working?
So, My Rear Speakers Aren't Working, And They're Plugged, And The Speakers Are New. So, I Was Wondering If There Was Maybe A...
Dollabill25
BCM Swap?
Suspect Faulty Bcm. I Want To Swap It With A Used Bcm From A Similar Vehicle. I Want To Know If There Is Some Required Programming Necessary...
Randy Mullin
Lost The Key And A P1000 Code?
This Winter And Had A Lock Smith Come Out To Program New Keys. I Have A P1000 Code Which Is Not Allowing Us To Communicate With The Car To...
kenbulthuis
LINCOLN MARK VIII
Code P1229, Truck Running Hot?
I Had Code P1229. Replaced The Cylinder Head Temperature Sensor. Drove Fine For A Day Or 2. Now The Past 3 Days It Has Run Hot, Only In The...
ThomasSh
Power Steering Pulley?
Does It Matter If The Old Power Steering Pully Was Plastic And The New One Is Metal? Tried Moving Pully From Flush To Line Up But There Isn...
Mike Stillion
CHRYSLER PT CRUISER
Engine Cranks But Does Not Start After Replacing The...
Replaced The Fuel Pump. And Now It Won't Start? It Is Getting Fire To The Spark Plugs. But The Plugs Don't Seem Wet. Like No Fuel...
jim.ramage57
MAZDA B2600
Low Oil Pressure Light And Knocking At Idle?
Car Started Saying Low Oil Pressure When Came To A Stop, Engine Knocks Fine While Driving. In The Past Month I've Done Upper And Lower...
Khaleqsam3
Squeling Sounds Car Came To A Stop
This All Happened In 3 Minutes Time. Car Was Running Perfect. So I'm Driving Down The Road At About 30 Mohandas Carmaker Loud Squeling...
chickahd
NISSAN ROGUE
Starter Cylinder Installed Will Not Start Due To Anti-...
Had A New Starter Cylinder Installed But The Anti-theft System Won't Recognize The Part And Thus The Vehicle Will Not Start.
Iallen
BUICK RENDEZVOUS
Coolant Coming From The Radiator Reservoir?
Yesterday I Was Coming Home After An Hour Drive And The Car Started To Overheat. I Maintained A Lower Speed And It Regulated The...
Rlharris83
Starter Relay Wiring Diagram Needed?
Try To Start The Car. It Cranks Once And Shuts Off. Did All The Testing. Now I Am Searching For A Wiring Diagram That Describe And Show...
TWI5T3D
Parts Or Components Of The Brake Master Cylinder?
Hello Ladies And Gentlemen, I Was Wondering What A Brake Master Cylinder Is Made Of, In The Photo Below I Can See The Brake Fluid...
Alex stathas
NISSAN VERSA
Self-Diagnostic Codes 4 And 5?
Has Anyone Ever Dealt With Auto Trans Self-diagnostic Codes 4 And 5? The A/t Indicating Lamp After Procedure To Get It In Automatic...
TPRZ32
NISSAN 300ZX
Van Stalls In Reverse?
My Van Is Running Well But When I Put It In Reverse It Immediately Stalls, My Other Vehicle Just Quit Running Probably Beyond Reasonable...
Dolphinscott
CHEVROLET VAN
Leaking Oil, How To Fix It?
My Car Listed Above With A 3.1 Liter Is Leaking Oil Here, Any Idea What This Is Where's It's Leaking From And How To Fix It?
Cp313
BUICK CENTURY
ABS Problem?
A Little Background: I’ve Got The Vehicle Listed Above Awd And It’s Been At The Mechanics Since End Of January For An Abs Issue. My...
gmalti
TOYOTA CARIB
Catalytic Converter Glowing Red?
My Car Was Barely Having Power, So I Parked It For 3 Months So I Had It Parked In Some Grass, And I Decided I Was Going To Crank It Up. So...
Joey71936
When Cold The Engine Shuts Off When Starting It With...
So, I Have The Vehicle Listed Above That If I Start It With Heater Or Stereo On It Will Shut Off And Struggle To Turn Back On. However, If...
cyrus96hoe
Loss Of Power When Warmed Up, But Turning It Off And...
I Have A New Fuel Pump (even Though It's The Rth One In 15 Months) And It Seems Like It Is Struggling To Work When Warmed Up. If I Take...
Bravo97779
CHEVROLET BLAZER
High Idle
It Has A High Idle
Duppercue1
CHRYSLER PT CRUISER
Ticking That Sounds Like A Plug Wire Is Arcing?
I Have A Ticking That Sounds Like A Plug Wire Is Arcing On The Driver's Side Of The Motor But Can't See An Arc. Just Had All Six...
Brian K Conner
704
705
706
