Does This Vehicle Have Manual Choke?
Hello! I Recently Purchased The Vehicle Listed Above And Was Looking Into Getting A New Carburetor Because It Didn't Really Like To Idle...
Jeremy McAfee
Ignition Wiring Diagram?
Could Someone Please Provide Me With The Ignition Wiring Diagrams And Any Other Diagram
Sanford0024
Electrical
My Speedometer And Turn Signals Stopped Working At The Same Time. No Other Electrical Problems. Car Starts Fine. All Lights And Gauges Work...
briancraft8
Duplicate Question
I Changed My Water Pump And Didn’t Know That Timing It Will Start It Up And Now I Have To Fix The Timing I’m Not Sure Where To Begin On...
Josephplacencia
Where Is The EGT Sensor 5 Located?
I Have A Bad Egt Sensor 5 On The Truck But I'm Not Sure Of The Exact Location Of This Particular Sensor. Any Help Would Be Appreciated.
Frauh3
CHEVROLET COLORADO
After Jump Starting The Speedometer, Blinkers, And...
I Jumpstart It And My Speedometer And Blinkers Not Working And Windshield Wipers Too, And My Brake Signal Came On Too.
Hardworkyah1207
DODGE MAGNUM
I'm Not Getting Power To Half Of My Fuses?
I Drove My Truck In The River And It Shut Off And Sat There For Over A Week. When I Got It Out, I Let It Dry, But Then I'm Not Getting...
Lilstud
Battery Gauge Fluctuates When Driving, Then Battery...
The Battery Gauge Fluctuates Up And Down While I Drive From Between The 1/4 Marker On The Low Side Up To The 3/4th On The High Side. When...
KiaDriverDelaware
KIA OPTIMA HYBRID
Serpentine Belt Squealing And Jumping?
I Have Already Changed The Tensioner To No Avail.
Drako2774
Light White Smoke, Misfiring Code Still On?
The Vehicle Overheated On Me The Other Day Because There Was No Water In The Radiator, And Started To Make Light White Smoke From The...
gas123
HYUNDAI GENESIS COUPE
Transmission Was Not Shifting Well From 1st To 2nd And...
For A Couple Days, My Transmission Was Not Shifting Well From 1st To 2nd And 2nd To Third. Rpms Would Jump 700 And Then It Would Shift. At...
Darin1771
Where Is The Coolant Temperature Sensor On My Vehicle?
I'm Getting An "engine Hot/ac Off" Message Immediately Upon Turning The Key, And The Coolant Temperature Is Pegged Low. ...
Mower87
BUICK VERANO
Transmission Rattles When Car Is Idling, Transmission...
I Was Thinking A Transmission Flush Would Be A Good Idea, Is This A Good Idea?
jacobpaulsen
MITSUBISHI GALANT
Key Broke Off In Ignition Cannot Get It Out?
My Key Broke Off In The Ignition, I Have Purchased A New Key And Ignition, However The Ignition Cannot Be Removed Without Inserting The...
Dolphinscott
MERCEDES BENZ 280
A/C Blows Hot Air Only?
I've Changed The A/c Fuses In The Fuse Box, Added Freon But Still No Cool Air. I Was Told There Was An In-line Fuse For The A/c That...
lakeg123
When Revving The Engine There Is A Screeching Coming...
New To Me The Vehicle Listed Above With 225 Dauntless. It Has Fender Starter Relay (three Prong) And A Piggyback Solenoid On Starter....
jahgary
1969
JEEP CJ5
Power Steering Pulley?
With Pulley Removal Tool The Pulley Came Off Of The Shaft Way Before It Lined Up With Drive Pulley. Can The Pulley Be Flipped Around With...
Mike Stillion
CHRYSLER PT CRUISER
VE Test Results
Hey Fella's, Anyone Have A Guess As To Why This Car Keeps Failing This Volumetric Efficiency Test? It Has Passed All Of Its Im...
al514
Blower Motor
I Have A 2007 Ford Edge. And The Blower Motor Isn’t Working Right. I Bought A New One And Replaced It. Still Wasn’t Working. So I Said...
cmichalak08
FORD EDGE
Blower Motor Not Working?
The Blower Motor Isn’t Working Right. I Bought A New One And Replaced It. Still Wasn’t Working. So, I Said What The Heck And Tried The...
cmichalak08
FORD EDGE
Fan Dose Not Blow Out Center Vents
Fan Ony Blows Out Of Dash And Side Vents
wiltopar
FORD EXPLORER SPORT TRAC
Where Is The Turn Signal Flasher Located?
It Sounds Like It Is In The Under-hood Fuse Panel, But Can't Find It.
greardon
CHEVROLET AVALANCHE
All Dash Lights Came On Like Normal And When I Turned...
I Went To Start The Car This Morning And Nothing. Hit The Key, All Dash Lights Came On Like Normal And When I Turned The Key Further To...
Bgross
BUICK LUCERNE
Loud Squealing Noise Coming From The Belt Area?
I Have A Very Loud Squealing Noise Coming From Around The Belt Area. I’ve Replaced The Water Pump, Power Steering Pump, Pulley Bearing...
Shfr0927
Fan Radiator Still On After 7 Seconds?
Hello, My Car The Fan Radiator Is Still Working After 7- 20 Seconds When Start The Engine And I Have No Check Engine Light On And No Code!...
Wilson
CHRYSLER PACIFICA
705
706
707
