Cool Fans Not Working
Hi, I Have A Problem With Cool Fans, Not Working. I Tested Booth Fans Directly And Works Well. I Tested Relays And All Work Good. I...
JorgeL2025
TOYOTA RAV4
Fuel System
We’re Is The Fuel Filter Located?
erikbean313
Low Beam Headlamp Inoperable Troubleshooting?
Hello, We Have The Car Listed Above Se. Just Noticed Copilot Low Beam Headlight Is Out. We Replaced The Whiter And Brighter Bulb We Just...
C h o r d d
FORD FUSION HYBRID
HVAC Control Panel Intermittently Has No Power?
I Bought The Truck New And Since I Got It The Control Panel For The Ac Has Intermittently Had No Power, Usually When The Interior Of The...
Machinist1
Engine Intermittently Runs Rough?
My Car's Engine Started Running Rough While At A Stop Light. After I Parked For An Hour And Restarted The Car, It Ran Fine Going Home....
Rod300zx
NISSAN 300ZX
Brakes Not Working Propperly?
Pedal Went Almost To The Floor But Stopped The Truck. Hissing Sound In The Cab So We Changed The Booster. Pedal Is Now Hard To Push With...
hayes5
GMC JIMMY
Headlights Keep Flashing While The Ignition Is Off?
My Main Beam Headlights Keep Flashing While The Ignition Is Off And I'm Hearing A Clicking Sound Coming From The Fuse Box In The Engine...
Martin cowell
CITROEN C4
Code P07A3, Transmission Issues?
I Just Purchased The Car Listed Above With The P07a3 Code. It’s A 2.0l Auto With The Dps6 Transmission. For Whatever Reason, The Car Will...
Tmreger2022
66 IMAGES
What Would Cause My Car To Have No Power At All With A...
Car Was Driving Perfectly Fine. I Went To Eat And When I Came Out There Was No Power At All. Used A Jump Box, And Another Car To Try To...
Alexkent851
KIA FORTE
Heater Core Hose Replacement?
I Am Just Wondering The Following Two Things: 1. Do I Need To Replace The Heater Core Or Is It Fine To Just Replace The Hoses Only Since...
Pendaless Udena Regan
CHEVROLET TRACKER
Vacuum Line Routing Diagram Needed?
I Need Help Figuring Out How To Run The Vacuum Lines In My Vehicle Listed Above. When I Bought It, The Previous Lines Were Not In The Truck...
Kris Grant
1982
OBD Port?
I Was Looking At My Engine Trying To Test A Sensor, When I Realized That I Have An Obd Port In My Engine Bay. Does Anyone Know If That...
Jas0822
KIA SPECTRA
Coolant Problem, And Erratic Temperature Gauge?
When The Engine Is Cold The Coolant Level Goes Down To Well Below Minimum. Drove It Like That For 20 Minutes To Halfords To Buy Some Coolant...
Jonnno73
Codes B150013 And P046014?
The Car Has A Check Engine, With Codes Above, The Sensor Inside The Fuel Tank With The Fuel Pump That Has The Floaty To Detect How Much...
paulryansantos
23 IMAGES
Transmission Swap?
I Have A Possible Transmission Leak And Was Wondering If A 6-cylinder Outback Transmission Be Compatible With A 4-cylinder Forester?
lizzy89
SUBARU FORESTER
302 Stock Motor With Forged Trick Flow Pistons?
I Am Currently Building My 302 Engine. If I Am Going With A B303 Cam, Am I Able To Use Stock Length Lifters And Stock Length Pushrods? ...
Foxbody.302k
Fuel Delivery To The Engine Issue?
I Wasn't Getting Fuel On My Truck Listed Above. I Bought A New Fuel Pump Installed It, And It's Still Not Getting Fuel. I Checked...
Cutie4444
TOYOTA PICKUP
Car Making Annoying Noise
Https://youtu.be/rmmedluogee Sounds Like It’s Coming From Drivers Side. Drivers Side Tire Previously Changed Following Accident (car...
mons444
Radiator Cooling Fans Are Not Working?
Neither Fan Works, Not Even The Passenger Side With A/c On. The Dash Temperature Gauge Works And Shows The Engine Getting Hotter In Stop-n-...
mbuch425
CHEVROLET LUMINA
Funny Noise Coming From The Driver's Side Tire?
Not Sure What Is Going On, Sounds Like It’s Coming From Driver's Side Tire? Car Previously Repaired On That Side (side Swiped On...
mons444
Crank No Start Issue?
I Need Some Help Because My C4 Will Continuously Crank But Won’t Start. This Was A Project Car And I Had Never Got It To Run Before. I Had...
R6vette
CHEVROLET CORVETTE
B Pillar Leak?
I Can’t Figure Out Where This Leak Is Coming From. When It Rains Heavy Water Comes In Through The B Pillar Which I Did Not Know Until I...
Hunkat
Where Is The Blend Door Actuator Located And How To...
The Rear Of The Suv Only Blows Hot Air, A/c Does Not Blow Cold Air In The Back Seats. I Would Like To Know The Location Of The Rear Blend...
KCMcado
CADILLAC ESCALADE
Potholes Mama Check Engine Light Come On
I Recently Bought My Truck And When Ever I Go Over A Pothole It Would Turn On Theft Light And Check Engine And It Would Go Away Within 1...
davidsmith728
Where Is The Knock Sensor Located?
I Am Trying To Locate The Knock Sensor For My Car Listed Above. The Code Said Bank 1 And Bank 2.
jdingleinlv
JAGUAR XJ8
695
696
697
