Drivetrain Noise Coming From Underneath While Driving?
Feel It Under The Gas Pedal Similar To Grinding. Is This Move By The Shaft Normal? I Just Noticed That The Rotor Is Also Scuffed Up On One...
Where Is The PNP Sw Located?
Trying To Find The Location Of The Pnp Sw. The Code "850" Will Pop Up. It Will Crank But Will Not Start. It Has Started A Few...
RaySims
NISSAN TITAN
Where Is The Crankshaft Positioner Sensor Located?
I Need A Diagram Of Where The Crankshaft Sensor Is Located. What Parts Will I Have To Remove?
Lee Perry
KIA SORENTO
Vibration?
Hi Joe, It's Been A While. Hope You Are Well. I'm Starting To Feel A Vibration In My Car Listed Above Between 1,500-1,800 Rpms...
Rich MKX
LINCOLN MKX
Valve Cover/valve Cover Gasket Torque Sequence Needed?
Need A Diagram Of The Torque Sequence For The Valve Cover/valve Cover Gasket.
Janessa Ruth
BUICK ENCORE
Noise/vibration While Driving?
The Truck Runs Well And Clean, Has Aftermarket Wide Wheels. When You Drive There Is A Vibration/noise From Under The Seat, Not Familiar...
Stalls Out When Transmission Is Shifted Into Drive?
Shortly After The Radiator Was Replaced My Car Stalled Out. It Then Had Rough Start And Then Stalled Out Again As Soon As It Was Put Into...
Zippy11983
Tag Lights, Rear Running Lights Not Working?
In My Car Listed Above I Recently Got Pulled Over At Night Because None Of My Lights Were On When He Was Following Behind Me (my Tag Lights...
Duwhop31
No Spark After Replacing The Timing Belt?
Changed Timing Belt Now Won't Start Sprayed Either In Throttle Body Still Nothing No Spark.
Reneesoup
A/C Clutch Not Engaging
Checked Everything Under The Hood. Thinking It’s Hvac Panel How Would I Test It?
Acrone
Alternator Replacement Instructions Needed?
Hi, The Vehicle Listed Above Se Model. It's My Coworkers. She Said Her Car Was Having Trouble Starting. I Tested Her Battery. It Was At...
Talonluvswifi
TOYOTA YARIS
Turn Signal And Hazard Lights Are Not Working?
My Hazards Work Not Blinkers.
Karenski916
GMC VANDURA
Power Steering Is A Little Stiff?
The Car Is Still Drivable. Power Steering Fluid Was Clear, Now It's Black. What Seems To Be The Problem? Open The Fluid Canister And...
Drefergs
INFINITI G37
Idle Issue?
So, I Have The Car Listed Above And I Recently Bought A New Carburetor For It. I Put It On And Started The Car, But I Would Start Idling...
Bigblackboi9
Output Speed Sensor
I Need To Know Where The Output Speed Sensor Is Licated
Rosa13
13V At Coil?
Due To Some Cut Outs And Slight Backfires On The Road I Am Looking To Replace My Coil (vehicle Idles And Revs Fine At Standstill). It Is...
scharpwillys
1976
JEEP CJ7
5.7 Engine Swap?
I Have Access To A Strong Running 2006 Chrysler 300 V8 Hemi And Can't Find Any Information If This Engine Is Compatible With The Car...
Nursejr
Stalls When Transmission Is Shifted Into Gear?
This Car When You Put It In Gear, It's Having Trouble Starting But Once It Does Start It Rides Rough For A Second And Then Purrs Like A...
Mike Buccilli
BUICK SKYLARK
Cooling System?
I Have A Discovery 4 Land Rover, How Many Liters Of Coolant Does It Take Dry Fill. Thank You.
Emmanuelngandu
LAND ROVER DISCOVERY
REMOVING THE TOP TRIM OF THE FRONT CONSOLE
There Is Not A Problem, I Did Receive Some Excellent Information From A Ken L But It Did Not Include Removing The Top Trim Buy The...
mzambory
LINCOLN NAVIGATOR
Where Is The Output Speed Sensor Located?
I Have Searched All Over And I Cannot Find It. Do I Have To Take The Transmission Pan Off To Find The Output Speed Sensor?
TjCash0069
MAZDA 6
When Starting The Car There Is A Shake/vibrate, What...
When Starting The Car Up, Cold Or From Warm, The Car Seems To Shake/vibrate, Not Violently But Enough, You Can Feel It Chunderring...
Jj1998
VOLKSWAGEN GOLF
No Crank No Start Issue?
Has Light And Everything But Won't Crank /start.
Michelle Phillips2
1970
OLDSMOBILE DELTA 88
My Transmission Will Not Drive But It Will Reverse?
What Can Be Wrong With It I Got To A Store I Went Into The Store. Then When I Came Out, I Tried To Leave, And My Car Reversed But It Won...
Patrick Atkins
Fuel Pump Changed Twice Still Not Starting?
I Had Somebody Change The Fuel Pump Because I Was Told It Was The Fuel Pump That Was Going Bad. What Happened Was When I Drove To The Store...
Grandmaof8
696
697
698
