Flashing Check Engine Light?
So Recently My Wife's Car Listed Above Check Engine Light Started Flashing And It's Been Flashing For The Last 2 Weeks. I Have Been...
dwpjr2021
BUICK LESABRE
EVIC
When I Turn On Wipers My Evic Goes Blank, Otherwise It Works Perfectly.
mack470
Dead Car
No Electrical Response When You Turn The Key. No Damaged Wires From The Wiring Harness. No Nothing. Just Dead, Dead, Dead.
marvinwoodyard
CHEVROLET CAPRICE
Replaced Stepper Motor-Now Won't Shift
Two Codes Came Up P1777 And P0603. It Was Stuck In Limp Mode And Would Not Crank Unless Being Jumped Off. Dropped Down The Valve Body And...
beverlydelong
Car Will Not Start?
I Had Trouble Starting The Vehicle, Replaced The Starter And Then After Some Research I Replaced The Abs Control Module. Now The Traction...
AChrisco91
GMC ACADIA
Fuel Injectors Wont Fire
I Have Replaced The Ign Module Cam And Crank Sensors And Spider Injector But Still No Fuel From Injectors It Has Good Fuel Pressure Up To...
Rick Murray2
Push Brake To Put Car In Gear DTR Light Signal Flashes...
I Have No Headlights, Brake Lights Or Turning Signals?
Angie Dillon
Sputtering And Shutting Off After Someone Put Flex...
I Used To Intuitively Have The Know-how For Any Problem I Experienced In A Vehicle And Nowadays, I Can’t Diagnose A Thing For All The “...
Just J
Where Is The Fuel Pump Relay Located?
So, I'm Looking For The Wire That Connects The Fuel Pump Relay To My Car's Computer (ecm). I Referred To The Service Manual And...
Jala
HYUNDAI ELANTRA
Temperature Sensor?
My Temperature Gauge Stopped Working And Read 0 And The Radiator Fans Ran Continuously Even After The Engine Was Shut Off. Fans Would Stop 3...
Kevingibbens1985
Coolant Leak?
My Coolant Is Leaking Out When I Turn The Car Off.
shantera88
SATURN AURA
Truck Does Not Stay Running After Starting It?
My Truck Doesn't Stay Running After Starting It. Maybe 2 Minutes Max Then The Engine Shuts Off. No Electronics Are Affected Lights Etc....
Chrisondeck2
Car Stalls And Bucks Sometimes While Driving?
The Car Didn't Start Right Away With My Foot On The Gas, I Tried Again With My Foot Off Gas, And It Started. But Then Turning The...
Drena
Car Not Staying Running
My Truck Runs For A Few Mins Then Shuts Off. No Electronics Are Affected Only The Engine. Lights Aren’t Dim Or Anything. I Can Provide A...
Chrisondeck2
No Air From Center Console/dash Vents?
Heat And A/c Work Fine, But No Matter The Settings, There Is Never Any Air Coming From The Two Dash Center Vents.
rloehr8173
Fuel System?
Recently Replaced The Fuel Pump And Filter On The Truck Listed Above D150 Because No Fuel Was Being Pulled From The Fuel Tank, Even After...
GCrow
1985
DODGE TRUCK
Front Passenger Door Stuck After Replacing The Window...
Hi. I Replaced The Window Regulator For The Front Passenger Side. When I Reassembled The Door Panel, I Thought I Reconnected The Two Door...
Andre26
AC Will Not Work Compressor Clutch Will Not Kick On
Have Replaced The Compressor, , The Relay, And All Switches. The Pressure Is Right All Was Charged When I Replaced Compressor. I Can Jump...
Burress 1998
Burress 1998
A/C Will Not Work Compressor Clutch Will Not Kick On?
Have Replaced The Compressor, The Relay, And All Switches. The Pressure Is Right All Was Charged When I Replaced Compressor. I Can Jump...
Burress 1998
The Scanner Will Not Read OBD Port But Has Power?
I Have The Car Listed Above Convertible, The Obd Port Is Getting Power, However It Will Not Link, Or Read Scanner. Any Ideas, Any Help...
00Mustangguy
Weak Crank No Start?
I Bought A New Battery, Changed The Starter, And Still Has A Weak Crank. Checked All Grounds They're Nice And Tight. Could The Voltage...
Christopher Gause
Starts But Does Not Stay Running?
Okay, My Van Listed Above Is A Sport 3.3 L Flex Fuel. I Had A Fuel Leak From The Dampener On The Fuel Rail, So I Purchased A Fuel Rail And...
Aris Lynn Hicks
Cool Fans Not Working
Hi, I Have A Problem With Cool Fans, Not Working. I Tested Booth Fans Directly And Works Well. I Tested Relays And All Work Good. I...
JorgeL2025
TOYOTA RAV4
Fuel System
We’re Is The Fuel Filter Located?
erikbean313
694
695
696
