The Engine Is Sputtering, Could It Be My Fuel Filter?
Wanting To Know That My Cobalt Is Sputtering, And Could It Be My Fuel Filter That's Clogged. I Also Smell Gas.
Darrin Hubbell
4x4 Electric Shift Issues?
I Am Not Getting Power To The Transfer Case To Engage My 4wd. I Have Tested The Plug And I Am Getting 5v +/- On 2 Locations. 0 Volts In The...
Brett4usm
Where Is The Body Control Module Located?
I Need Location Of Bcm And If There Are Any Plug In Fuses To Check To Reset.
K1DNC
CADILLAC CTS
Parking Lights Stay On?
I Have A 2018 Thor Majestic Rv. It Is Built On A Ford E450 Chassis. Parking Lights Started Blowing Fuse 22. Had A Backyard Mechanic Look...
Joe Stall
FORD E-SERIES VAN
Fuel Pump Relay?
It Recently Shut Off While Driving And Wouldn’t Start. Got It Home And Fuel Pump Wasn’t Working, Replaced It As I Still Had Warranty...
Brian333
24 IMAGES
Throttle Body Adjustment?
Throttle Body.
mfknqueenb
Allstarted With A Freeze Plugno Fire Out Or Coil To...
No Fire Out Of New Coil To Distripotor Crank But Know Start No Fire Starting Fluid Used In No Fire None Rpm Gage Does Not Move When Trying...
Robert Watson4
CHEVROLET 1500
All Started With A Freeze Plug No Fire Out Or Coil To...
I Know You Guys Can Fix The Problem In I Have Asked Ya'll Before In You Know The Truck In Its Still Crank But No Start Truck Was Fine...
Robert Watson4
CHEVROLET 1500
Will Not Start, It Has Spark And Fuel The Fuel Pump...
I Hit A Pothole Really Hard On The Passenger Side The Truck Shut Off. I Can Crank It Over All Day Long It Has Spark And Fuel The Fuel Pump...
Unkaw3
Codes P0101 And P0102, Fuses/Relays?
For Mass Airflow Since I Have Code P0101 P0102. The Car Listed Above Is A Coupe.
azdanno04
Cooling Fan Not Kicking On?
Pulled The Engine A While Ago To Rebuild It And When We Put It Back In And Started It, We Noticed That When The Vehicle Exceeded...
Devyn Provins
Cooling Fan Fan Not Kicking On
Pulled Moter A While Back To Reseal Everything And When We Put It Back In And Started It Up We Noticed The Fan Was Not Kicking On When The...
Devyn Provins
Codes P0113 (IAT Sensor) And P0630, No Start?
So, The Other Morning I Went To The Store, No Issues. I Tried To Start It A Couple Hours Later, The Truck Would Crank But It Did Not...
MattMuff82
NISSAN TITAN
Vibration In The Steering Wheel?
I Have Heavy Vibration In My Steering Wheel When I Try To Brake While The Car Is Running Above 100 Kmph Speed. This Started Since I Left My...
yourspk
PEUGEOT 307
Engine Swap?
Motor Is Blown.
Cody8743
29 IMAGES
Replacing The Spark Plugs?
When Changing Plugs Should You Put Anything On The Threads Of The New Plugs Being Installed?
rwalbroehl
Coolant Heat Sensor Overheating But It Is An...
My Coolant Heat Sensor On My Car Listed Above (rs) Has Been Overheating Regularly For A While Now I Just Replaced The Sensor Today And It...
CJSchile
What Causes The Third Gear To Pop Back Out To Neutral?
As I Am Changing Gears When I Get To The 3rd It Jerks Back Out To Neutral And Won't Go In 3rd.
Martinez18131
SATURN ION
No Crank No Start Issue?
I Have Power, Battery Is Good, Recently Changed The Oil And Air Filter. The Radiator Needs To Be Flushed And New Plugs. But The Car Won...
Angela Lee
BUICK LESABRE
Auto Lights
Basically The High Beams With Lights It's Not Working Automatic I Have Every Time To Go Out From The Vehicle I Have To Turn It Off By...
Dovk
ACURA MDX
Burning Oil?
Just A Heads Up, The Mileage Of My Car Is In Km. This Car Burns Through Oil Like It Has Stock In Castor Oil Or Something. The Dealership...
SusanSwan
HYUNDAI ELANTRA
Truck Won’t Start
The Antitheft System Light Is On On My Dash And When I Turn The Key Over It Makes No Sound And Does Nothing
corey06jbp
16 IMAGES
Mass Air Flow Sensor Wiring Connector?
I Bought The Truck For My Dad, And It Has A Miss In It, He Let Somebody Mess With It, It Needs A New Pigtail And Wired Back Up, I Have...
horrellzayda45
What Would Cause A Slight Tremble?
I Have Replaced The Two Front Tires, Finished All Three Motor Mounts Today And The Driver Side Cv Axle And Wheel Bearing. I Notice It...
Robert Clark2
While Driving The Engine Made A Sound, Started...
I Was Driving On The Freeway When The Engine Made A Weird Sound Like It Was Struggling. I Noticed The Car Was Starting To Overheat. Then The...
msnative2
CHRYSLER IMPERIAL
691
692
693
