Car Can't Start
When You Turn Ignition Switch On There Are No Lights On The Dash Board And The Bell The Key Is Ringing
Siwila
MITSUBISHI PAJERO
Vibration When Accelerating?
Car Feels Like It's Hopping When Accelerating N/s And Severe Vibration. Changed Driveshaft And Stabilizer Bar As Both Had Damage Plus...
DShort
19 IMAGES
Piece Hanging From Underneath Car?
I Have A Plastic Black Corrugated Tube/pipe Hanging Down Underneath The Car, About 3 - 4 Inches From The Ground. It’s Near The Front Of...
sammiemacc
JEEP PATRIOT
Car Can't Start
I Changed The Alternator Rectifier After That The Engine Check Light Is Not Coming On And The Engine Can't Start Even The Windows Are...
Siwila
MITSUBISHI PAJERO
A/C Will Not Work Compressor Clutch Will Not Kick On?
A/c Clutch Won't Kick On Unless I Jump Relay. Has New Hi And Low Sensors, New Compressor, And New Inside Control For The Heat And A/c...
Burress 1998
Tag Light Not Working?
I Noticed That My Tag Light Was Not Working. I Got New One's And Still Don’t Work.
Mroulet1
ACURA TL
Overheating And Red Fluid?
Hello! I Have The Van Listed Above That Has Never Had Any Problems Until Today. The A/c Was On And All Of A Sudden, The Dash Thermometer...
joan1961
What Does It Mean When A Fuse Sparks When Tested With...
I Am Trying To Diagnose A No Start To Crank Issue. It Was The Fuel Pump Fuse. I Do Hear The Pump When I Try To Start It.
Denese
After Replacing The Battery, The Horn Blows Nonstop...
Horn Malfunction. After Replacing The Battery, The Horn Blows Nonstop?
Theresa Guidry Fuselier
TOYOTA AVALON
No Spark After Installing An Intel Itronix Analog...
So, I Installed An Intel Itronix Analog Digital Dash In My Truck All Wiring Going To The Dash Is Correct Everything Works As It Should. My...
87Squarebody
Code P0204?
I Have Changed The Injector And The Pig Tail Continuity Tested The Wires To The Ecm. I Am Still Getting Open Circuit P0204 Code. Clear It...
les allen
Blend Door Actuator Not Working?
I Installed Several New Blend Door Actuators. They All Do The Same Thing When I Turn The Ignition On. They Spin And Go To One Side But Don...
a.julianw
High Temperature, Low Oil Light On Dash?
I Have The Vehicle Listed Above Xlt. It Has A 5.4 Triton Engine. The Car Starts With No Problem, But The High Temperature Low Oil Light...
Browndv
New Blower Motor, /heater Still Not Coming On?
My A/c (live In The Deep Hot South) Has Been Intermittently Working. Initially I Could Hit The Passenger Side Glove Compartment Area And...
Vicky Guzman
Replaced Intake Gasket And Manifold
Had To Replace The Intake Gasket And Manifold Would Atleast Crank Before They Were Replaced Now Will Not Crank
Shaevvvv
MERCURY GRAND MARQUIS
Have A Transmission Leak?
Originally It Was Coming From The Inner Bell Housing Seal Where The Slave Cylinder Is. The Shop I Took It To Was Supposed To Fix It. When I...
azdanno04
31 IMAGES
What Would Happen If I Put E85 In The Fuel Tank?
What Would Happen If I Put E85 Inside The Car? I've Looked It Up A Lot But Never Gotten A Straight Answer.
Olson11
VOLKSWAGEN JETTA
Taillights Not Working?
Brake Lights Work, License Plate Lights Work.
Krkurtz
SUBARU OUTBACK
Gauges And Windows Stop Working When The Key Is Turned...
Everything Works When I Turn The Key, But When I Start The Vehicle The Windows And Some Of The Gauges Stop Working.
Bob
Underhood Fuse Block C1 Rodent Feast.
2006 Silverado Ss 6.0 Liter. Beginning Of Winter Had A Rodent Chew On The C1 Portion Of The Engine Fuse Block. Got The Wires Repaired. As I...
Cherie Abbott
Vacuum Booster To Manifold Hose Connector?
I Have The Car Listed Above Se With A 2.3l. I Need To Know What Connects The Hose From Vacuum/brake Booster To The Hose That Goes To The...
Lucielou62
Engine Low Idle?
I Bought The Vehicle Listed Above Last Month. When In Idle, In Park, Neutral, Reverse Or Drive, I Noticed The Rpm Dropping. Never A...
Fernando D. Raimundo
DODGE JOURNEY
The Steering Pulls Hard To The Right?
And It Is All Around Squirrelly.
chrisdfedric
The Doors, Windows, And Hazard Lights Act Erratically...
When No One Is Even In Or Near The Van, And Also When I’m In It, The Back Hatch Opens And Closes Repeatedly. The Side Sliding Doors Open...
Drea Hickman
CHRYSLER TOWN AND COUNTRY
Safe Resurface Limit Of Cylinder Block L59 5.3 Vortex?
I Just Got Back My Block From The Machine Shop. I Forgot To Ask What Was Removed, But From What Is Written On The Block It Appears.040 Was...
Toby cantrell
690
691
692
