While Driving The Engine Made A Sound, Started...
I Was Driving On The Freeway When The Engine Made A Weird Sound Like It Was Struggling. I Noticed The Car Was Starting To Overheat. Then The...
msnative2
CHRYSLER IMPERIAL
What All Do I Need To Do For This Car To Start And Run...
What Is Missing? What Is Damaged? Who Do I Need To Contact To Help Me With This? The Car Listed Above Is A Ses Dohc V6 3.0l.
Foster1801
Clicking Noise When Key Is Turned To The On Position?
I Recently Got My Oil Changed About A Month Ago, And Then About A Week After, My Check Engine Light Came On. I Thought It Was Because Of...
Aro1596
MITSUBISHI OUTLANDER
Fuel Door Won’t Open
Help/advise Needed! Hey! I Have A 2010 Beetle And A Couple Days Ago I Went To Open My Fuel Door And The Button Didn’t Work. It Made No...
Karmc20
VOLKSWAGEN BEETLE
Fuel Door Will Not Open?
Help/advise Needed! Hey! A Couple Days Ago I Went To Open My Fuel Door And The Button Didn’t Work. It Made No Sound And Gave No Prior...
Karmc20
VOLKSWAGEN BEETLE
Clicking Noise When Opening Driver Door Or Rolling...
Hello! I’m New Here But I Have The Truck Listed Above 2500 Cummings Turbo Diesel. After The Mechanic Put In Transmission Cooling Unit...
kblan010
Coolant Temperature Sensor?
When My Temperature Gauge Stays On "c" Then The A/c Will Not Work, And The Fans Will Run For Exactly 5 Minutes When The Engine Is...
Inspector58
BUICK LA CROSSE
Code P0701, Stuck In Limp Mode?
The Car Will Start And Idle And I Can Move The Shifter, But The Car Won’t Move. The Engine Light Is On And A Wrench Light. The Only Code...
Chimlin81
FORD FIVE HUNDRED
Transmission Limp Mode Or Nothing?
Transmission (allison 1000) Goes Into Limp Mode Or Nothing. I Thoroughly Cleaned The Valve Body, Load Tested The Internal Harness And...
3KR
CHEVROLET 2500
Engine Install Guide?
Hi, I Have The Truck Listed Above Z71, That I Slung A Rod In Over A Year Ago. My Boyfriend And I Split Up Not Too Long After That, And I...
Bsam0000
Qtqtqt
Qtqt
jasonton
2022
ALFA ROMEO 146
Variable Valve Timing Solenoid Replacement
Can't Seam To Find The Location Of The Variable Valve Timing Solenoid. Just Need Some Guidance.
lztrujil
DODGE DART
Where Is The Variable Valve Timing Solenoid Located...
Can't Seam Where To Find The Location Of The Variable Valve Timing Solenoid. Just Need Some Guidance.
lztrujil
DODGE DART
What Is A Fair Price To Get Front Brake Rotors And...
Brakes Replacement Cost. What Is A Fair Price To Get Front Brake Rotors And Pads Installed?
silenthilldale
ACURA MDX
No Crank, Anti-theft Light, No Obd2 Communication?
The Car Does Not Crank, The Anti-theft Light And The Parking Brake Light Stay On Solid Even When Key Is Removed, And Doors Are Shut And...
Tyctoney
Codes P0137, P0131, And P0304, Stalls, Rough Idle...
I Have Gas In My Oil My Car Stalls Has Rough Idle Misfires It Throws Codes P0137, P0131, P0304. I Have Changed O2 Sensor, Map Sensor...
riley01031980
CHRYSLER 200
Throttle Body / Computer?
I’ve Had This Vehicle In The Shop For About Two Months. It’s Been Moved Twice And I’m Getting The Run Around Because I’m A Woman....
BettyHinks
JEEP COMPASS
Some Of My Dashboard Gauges Are Not Working?
Some Of My Dashboard Gauges Not Working?
bernie garrison
Headlight Switch Went Out?
Can I Add A Toggle Switch If So What Wires Would I Use?
Roger Thady
Electrical Intermittent Start?
I Had A No Start On My Truck The Other Day. I Heard The Relay Click So I Replaced It. Upon Inspection I Noticed Pin 87 On The Old Relay Was...
Dally115
Cold Air Intake Making Noise?
While Sitting At Idle The Cold Air Intake Tube Will Start To Make A Noise, Like Blowing Into A Bottle, And Pretty Loud. If I Give It Gas...
rbray61967
LINCOLN NAVIGATOR
After Replacing The Timing Chain For The Second Time...
The Car Listed Above Is A Gt. I've Put Timing Chain In Twice. It Cranks Perfectly Idles Great, As Soon As I Hit The Gas Pedal It Jumps...
Jettlee
After Using Cat Cleaner The Engine Will Start But Does...
It Always Had A P420 Code, But The Car Ran Fine At All Speeds. Added Cat Cleaner To Try To Clear Code With No Luck, But Right After...
cybertiger99
BUICK VERANO
Battery Keeps Draining After A New ECM Was Installed?
My Car Has Been In The Shop For 2 Months Now For A Supposed Ecm Problem. Prior To That I Had A Charging System Issue, My Battery Light Kept...
JustBlessed
Stuck In Accessory Mode Shift To Park?
It Goes Into Accessory Mode When I Connect The Battery (brand New). When I Push The Start Button It Shuts Off And Goes Back Into Accessory...
Bohannon
CADILLAC STS-V
692
693
694
