Feels Like It Is Slipping Gears While Driving The...
It Will Reach High Or Very Low Rpms Before It Shifts. I Don't Know If This Matters, But My Vehicle Listed Above Is A Trail Rat...
Ruthann Fontaine
No Start,nospark,yes Gas
Engine Turns Over, No Fire, Spark. Asd Fuse Keeps Blowing Out Instantly, No Other Signs
Only mopar
CHRYSLER TOWN AND COUNTRY
Replacement Alternator Makes Loud Noise?
Had My Alternator Was Replaced In Feb 2023 And About 2 Weeks Ago Started Making This Noise! Please Help.
la.vero
JEEP PATRIOT
It Will Not Go Into Gear It Won't Get Out Of Park?
My Car Will Start No Problem. It Will Not Go Into Gear It Won't Get Out Of Park. I Can Shift Through The Gears Freely. But It Won't...
Almanzar0923
INFINITI Q50
Codes P050A, Hard Start And Will Not Stay Running?
Truck Will Barely Start, Then Stumble And Spit For A Few Seconds At Around 500 Rpms And Stall Out. It Had A P050a Pending, So I Swapped...
Totalmc
CADILLAC SRX
No Crank, No Start?
Just Replaced The Engine Block In My Car Listed Above, Gtp. It Had A Boost Issue After First Start, I Fixed That Issue And The Next Day It...
Kpeanutjr
Starter Won’t Turn Over
Just Did An Engine Swap On My 1998 Pontiac Grand Prix Gtp, Started Up First Try Had A Boost Issue I Got Those Resolved, And The Next Day...
Kpeanutjr
Brakes Are Not Responding At All?
After Pulling Out Of A Store The Other Day I Noticed My Brakes Hissing At Me. And They Were Not Doing Anything As I Applied Pressure To The...
Inimical Atchley
Fuse Diagrams Needed?
I Need Both Fuse Diagrams For The Car Listed Above, Sti. It Will Power On But Not Start And My Brakes Are Hard, And The Brake Lights Do...
Ken Stacy
VOLKSWAGEN JETTA
Fuel Injector Fuse
So My Jeep Is Now Blowing The Fuel Injector Fuse Every Time I Turn The Key Into The On Position. I Have Checked And Traced The Wires And The...
Droc223
Fuel Injector Fuse
Droc223
The Fuel Injector Fuse Blows Every Time I Turn The Key...
(not Start) I Have Checked All The Wires, Grounds, And Fuses. I Have Also Replaced The Asd Relay And Fuel Pump Relay. I Also Put New...
Droc223
Exhaust Pipes?
I Have The Stock Exhaust Pipes For My Car Listed Above. In Perfect Condition. Are They Worth Selling And What Are They Worth? Thank You
Webethree
Vehicle Leaking Antifreeze?
The Temperature Gauge Read Hot, And Indeed It Was Hot, I Got Out To Check And Steam Was Coming From The Passenger Side, I Guess Midway...
Just my luck
CHEVROLET VENTURE
Whistling Sound When Accelerating Around 60 MPH?
I Don't Have Air Conditioning Equipped In My Vehicle Listed Above. I Can't Find Any Information On Diagnosing Air Leaks And Vacuum...
kinection
JEEP PATRIOT
What Is The Name Of The Hose That Goes From The...
I Need To Change The Hose That Goes From The Reservoir To The Power Steering Pump. What Is That Hose Called? It Is Maybe 5 To 6 Inches, And...
Cat20979
FORD FIVE HUNDRED
Code P0013, VVT?
My Car Gave Me A Code P0013 To Change My Vvt. I Did Both Vvt On Passenger Side Have New Ones Put On I Also Went Ahead And Changed The...
Raul96
SUBARU WRX
Are They Culpable For Timing Chain Going Out After...
My Daughter Took Her Vehicle Listed Above To The Shop For Her Suspension And A Few Other Little Things. They Told Her That Her Engine's...
rmwitt
HYUNDAI SANTA FE
Knock Sensor 2 Circuit High Voltage
Changed Stater( Not Fun) Had To Remove Knock Sensor To Get Starter Out. Unbolted Sensor, Then Removed Connector From Sensor. Now Getting...
Joe Wright2
CADILLAC CTS
Codes P0740, P0753, P0785, P1860?
I Have The Vehicle Listed Above Z71 5.7l. Codes P0740, P0753, P0785, P1860. It Has A Transmission In It That Was Refurbished 2 Years Ago...
Earl91
25 IMAGES
I Was Wondering If You Guys Do Rebuilt If I Sent You...
I Was Wondering If You Guys Do Rebuilt If I Sent You My Engine?
Gmc10113
Lurching And Check Engine Light?
Hi, Today I Backed My Car Out From My Parking Spot And Put It Drive. The Engine Started Lurching When I Went Forward Like It Was...
Stephbuel
Right Front Turn Signal Light Not Flashing?
Right Front Signal Lights Will Not Flash, Bulbs Are Good.
NaelcaMreteP
Where Is The Temperature Blend Door Actuator Located?
Air Conditioning. The Location Of The Temperature Actuator.
Will3131
CHRYSLER CONCORDE
Can I Get The TIPM Wiring Pinout For C6 Connector?
Some Wires Corroded And Fell Off. The Vehicle Listed Above Is An Stx Model.
alexduke
DODGE JOURNEY
685
686
687
