Transfer Case Swap Out Issue?
I Have Taken The Transfer Case Out Of A 1999 Cadillac Escalade And Am Trying To Place It On My Truck Listed Above K1500 Single Cab 4x4. The...
Tatt2Tex11
No Start After Locked Out System Light On?
Originally Locked Out System Light Was On All The Time So Tried Several Methods Of Unlocking The System None Of Which Worked. Now The Car...
Peter Petrides
PONTIAC SOLSTICE
The Car Shows A Warning Of High Transmission...
Its Gear Shift Is Malfunctioning. As I Press The Gas Pedal, Instead Of Accelerating It Makes Sounds And Does Not Move. And When It Is...
Adil Ijaz
HONDA HRV
After Replacing The Engine, The Instrument Cluster...
Just Had The Engine Replaced. Started It Up And All The Gauges Registered But The Oil Pressure Was Reading A Little High. Then The Whole...
JET1
Few Issues.
Bought A Camry Recently Runs Great But First Problem Is My Battery Is Completely Dead In The Morning. Brand New Alt And Battery And The...
Mikethemichael
Lost Only Key?
Locksmith Having Problems Making New. If I Install A New Ignition With A New Key, Will It Work? What's My Best And Least Expensive...
Blumax
Idle Fluctuates After Engine Swap?
My Idle Fluctuates. We Just Got Done Doing An Engine Swap.
Kellie Bennitt2
Crankshaft Position Sensor?
Replaced My Crankshaft Position Sensor 1 Day Ago And Now It's Worse. What Else Could It Be?
Rockhillmitch
HYUNDAI ACCENT
Code P0333, Knock Sensor 2 Circuit High Voltage?
I Changed The Starter In My Car. I Had To Remove The Knock Sensor To Get The Starter Out After Reassembling Everything I’m Getting Engine...
JCWright4
CADILLAC CTS
Lighting
Recently Replaced The Bed On My Truck Then. No Running Lights, Overhead Lights Or Cluster Lights. I Do Have Break Lights And Headlights....
Benny2535
Running Lights, Cluster Lights, And Overhead Lights...
Recently Replaced The Bed On My Truck Then. No Running Lights, Overhead Lights Or Cluster Lights. I Do Have Brake Lights And Headlights....
Benny2535
Will Not Recognize My Key Or Let My Scanner...
Bought New Computer, Resolved Nothing. Replaced Crankshaft Sensor And Camshaft Sensor, Resolved Nothing. The Vehicle Listed Above Is A...
hatcherguy
Alignment After Rack And Pinion Replacement?
Was I Cheated? I Was Told That After A Rack And Pinion Replacement, That A "specialty" Alignment Was Required. I Was Charged $179...
kw46647073
Alternator Replacement?
My Car Was Making Some Weird Noises Upon Starting And Fuses Were Going Out Rapidly Along With A Headlight I Had Just Replaced Going Out, So...
Bethanybrooks
VOLVO XC60
Rebuilt 4L60e Installed, Does Not Shift Properly?
2003 S10 Zr2 4.3 Auto 4l60e. Transmission Has Been Replaced With A Remanufactured Unit From Powertrain Products. It Does Not Shift Properly...
TwoZR2
Codes U1000 And P1612, Immobilizer?
Went Into Shop Came Out Inserted My Key Car Would Not Start Plugged In My Reader Says Mobiliser Malfunction Codep1610. Traction Control...
getsabout
I Seem To Still Have Multiple Misfires?
I Have Replaced The Spider Injectors, Distributor Cap, Wires, Sparkplugs, Fuel Pump, Fuel Filter, O2 Sensors Plus Much More And I Seem...
Silas South
Is It Normal For The Lower Radiator Hose To Always Be...
The Car Is Not Overheating, And I Have Interior Heat. The Thermostat Is A New (oem). Please Advise, It Is A "new" Used Car For Me.
Instlouis
ACURA TSX
Replaced Starter, Had To Remove Knock Sensor To Do That. Reinstalled And Plugged Back In, Now Getting Check Engine, With Above Code. ...
Joe Wright2
CADILLAC CTS
Excessive Oil Use And Gas Pedal Issue?
Seem To Be Always Adding Oil. Things I've Done:changed Out Int/exh Oil Vari Control Valve. Then Last Weekend I Changed Oil, Filter And...
bostonboatswain
19 IMAGES
KIA SOUL
Overheating?
Engine Light, Battery Light, Overheating Max.
Hal Manta
TOYOTA TERCEL
Drivetrain Malfunction?
I Have Experienced This Problem For 2 Weeks. It’s Showing Up When Accelerating And Disappear After One Day, And Return Again When Push Up...
Rateb Al-Fakhoury
BMW 750LI
Hello I Have Experience Drivetrain Malfunction When Accelerating And I Scan The Car And Codes In The Pictures
Rateb Al-Fakhoury
BMW 750LI
Feels Like It Is Slipping Gears While Driving The...
It Will Reach High Or Very Low Rpms Before It Shifts. I Don't Know If This Matters, But My Vehicle Listed Above Is A Trail Rat...
Ruthann Fontaine
No Start,nospark,yes Gas
Engine Turns Over, No Fire, Spark. Asd Fuse Keeps Blowing Out Instantly, No Other Signs
Only mopar
CHRYSLER TOWN AND COUNTRY
684
685
686
