The Engine Will Not Rev Past 3,000 RPMs?
Well, This Truck Has Sat For A Couple Years, I Have Been Fixing It Up. I Got It Running But Idle Comes And Goes And It Will Not Rev Past 3...
Colefincher
No Ground Signal At Pin 85 On Air Conditioning...
The Air Conditioning In This Truck Stopped Working At The End Of Last Summer. When I Switch On The Ac On The Truck It Only Blows Hot Air...
2500HD-Bman
Burping The System
The Temperature Gauge Was Jumping Back And Forth. The Check Engine Light, Water Temp Light, And Traction Control Light Came On. I Changed...
Brooklyn Hunt
Will Not Start, Oil Drip On Crankshaft?
Hello, I Will Explain As Best As I Can. Thank You In Advance For Your Time. Engine Light Came On, Showing Camshaft Code. The Guy At The...
Pauciello1031
While Driving There Was A Pop Noise, Smoke Was Coming...
Yesterday My Car Was Making A Grinding Noise And Slowed Down As If The Brake Was Being Applied Every Time I Drove. Today I Decided To Try To...
Ashton Oper
Code P0443, After Replacing Purge Valve Twice With New...
Hi, Code P0443. I've Replaced The Purge Valve Twice And I Still Get This Code. The Purge Valve Also Makes A Clicking Noise When It'...
Suspecctt27
Engine Codes 52 And 71?
I’ve Recently Purchased A 1995 Sc300 And Was Retrieving The Codes 52 And 71 From The Ecu. I’m Not Very Familiar With This Car Yet So I...
LR_sc300
21 IMAGES
LEXUS SC 300
Code 67, Check Engine Light On?
Scanner Code 67. Neutral/drive Switch Circuit Open. What Does This Mean And How Do We Correct So It Will Pass Smog?
Nathanb40
Suspension
When Driving At Lower Speeds I Hear Clanging Noises Like Metal To Metal When I Hit Bumps In The Road I Have Already Done Replaced My Sway...
Tom Jr Pettry
SCION XB
Car Starts At 2,000 RPMs And Then Drops With Warm Up...
After Cleaning The Throttle Body At Start It Has 2000-2200 Rpm, Which Decreases 3 Seconds To 1,500 And Then Gradually Decreases To The...
MaxVas
Head Gasket Replacement
I Was Just Wondering The Torque Specs When Replacing Head Gasket, And What All Components Should Be Replaced
Jessica Tanner
DODGE JOURNEY
HVAC Stuck On Defrost/floor, Where Is The Heater...
Looking For Heater Vacuum Control Manifold. (Under Glove Box?)
Scott McLouth
CHEVROLET LUMINA
Where Is The EGR Pressure Sensor Located?
I’ve Been Trying To Locate The Egr Pressure Sensor On My Truck Listed Above Sd. I Already Have The New Part But Can’t Seem To Find Where...
GhostCookies
Engine Running Rough And Shutting Off?
Car Shuts Off After Running For A Few Minutes And Right Before The Car Shuts Off It Starts Running Rough Then Shuts Down.
armcastro72
LINCOLN LS
Rear Passengers Turn Signal Not Working?
I Have Replaced The Taillight Assembly, Replaced The Plastic Connectors Because They Were Rusted The Connect From The Wiring Harness To The...
Dustin78
OBD Port No Communication, Then Not Starting Truck?
Plugged In A Brand-new Scanner Which Wouldn't Communicate And The Truck Won't Start And Electrics Acting Funny.
johnreck
Traction Control Light And Tire Pressure Lights Turned...
The Traction Control Light Has Come On And The Tire Pressure Light. Had It On A Diagnostic Machine And It Won't Clear Either Of Them Off...
Iwillbeforeveryoung
MAZDA CX-5
No Lights At HVAC Control Module?
I Have The Truck Listed Above Diesel. I've Replaced Compressor, Accumulator As Well As A H/p Line. Old Components Worked But Compressor...
Joe Scheele
Put The Key In The Ignition, And Turned The Key, No...
Joe, Last Time I Faced A Non-start Situation Was September 14, 2021. Here Is The Link-- Https://www.2carpros.com/questions/flashing-...
alphaa10
35 IMAGES
BUICK LESABRE
The Power Seats, Power Door Locks, Windows, Heated...
Hello Guys, The Problem I'm Having Is With My Interior Accessories Are Not Functioning. My Power Seats, Power Door Locks, Windows (i...
Merkum901
CADILLAC ESCALADE
What Can I Use To Help Me Stop This Coolant Leak?
So, I Have The Car Listed Above, Currently Not Driving It Due To This Issue. So, My Thermostat Is Leaking Coolant Right Where The Little...
Ehayes231
CHEVROLET AVEO
Intermittent Crank No Start?
When I Turn The Key Sometimes The Car Starts Up Fine. Then Sometimes I Turn The Key And It’s Continuous Cranking Even If L Let Go Of The...
Corte.ez12
My Throttle Body Light (the Red Lightning Bolt) Turns...
My Throttle Body Light (the Red Lightning Bolt) Came Up On My Dashboard. But If I Turn The Car Off And Back On It Goes Away. When This...
Corte.ez12
Overheating
Okay I've Replaced The Coolant Temperature Sensor I've Done A Coolant Flush On It And Still It Doesn't Want To Kick The Fan On...
Travis Butler2
CHEVROLET CLASSIC
Overheating
Travis Butler2
CHEVROLET CLASSIC
674
675
676
