Overheating
Okay I've Replaced The Coolant Temperature Sensor I've Done A Coolant Flush On It And Still It Doesn't Want To Kick The Fan On...
Travis Butler2
CHEVROLET CLASSIC
Overheating
Travis Butler2
CHEVROLET CLASSIC
Overheating
Travis Butler2
CHEVROLET CLASSIC
Overheating
Travis Butler2
CHEVROLET CLASSIC
Overheating
Travis Butler2
CHEVROLET CLASSIC
It Still Wants To Overheat?
Travis Butler2
48 IMAGES
CHEVROLET CLASSIC
Transmission Swap
Swapped Transmission From Auto To Manual Now Won't Start. Used Manual Harness And Think I Need To Bridge A Wire From The Gear Selector...
Bradley 80
HOLDEN RODEO
Will Not Start After Transmission Swap?
Swapped Auto Transmission To Manual. It Had 2 Cars, 1 Manual And 1 Auto. Needed To Fit Manual Transmission Into Auto So Exchanged Gearbox...
Bradley 80
HOLDEN RODEO
Interior And Trunk Lights Are Not Working?
So, I Have The Car Listed Above Ex Model. I Was Installing Led Dome Lights Yesterday, Led Lights Worked For Front And Back. As Soon As I...
Mxz_03
Transmission Control Unit, How To Change It Out?
Clunking Sound Going Into Reverse, Initially. Mechanic Test Drove And Said Either Tranny Or Engine Bolts. Now, It Jerks Going Into...
Miriam Brown
HYUNDAI SANTA FE
New Alternator Not Charging New Battery?
The Battery Keeps Draining Every Few Days. I Have Replaced Both The Alternator And A New Battery The New Alternator Is Still Not Charging...
RyanH89
VOLKSWAGEN ATLAS
Starting Fluid
Can Starting Fluid Damage My Car
Marta13
After Using A Lot Of Starting Fluid My Car Began To...
After Using A Lot Of Starting Fluid My Car Began To Sputter. And Loses Power While Driving.
Marta13
Running Lights Not Working?
No Running Lights.
adanorozco1
CHEVROLET 1500
Engine Will Not Crank, No Spark Or Fuel Pump After...
Just Removed Blown Up 6.0l Ls And Replaced With A 5.3l Ls From A 2007 Chevrolet Tahoe Now Engine Wont Crank, No Spark Or Fuel Pump. Used...
John's headache
I Am Having An Issue With My A/C System Control Relay?
So, This Is What I Have On The Relay. Pin 30 Is Always Hot Pin 86 Is Switched Hot Pin 87 Goes To The Ac Compressor Pin 85 Comes From...
ONEDSOB
57 IMAGES
Is It Okay To Hear The Fuel Pump Prime At Ignition But...
You Can Hear It Running The Entire Time Truck Is Running, Shuts Off When Turned Key Off, If Not What Can I Do? Worried About Burning Up...
Ghost77
Alternator Removal Issue?
We Have To Replace The Alternator And While We Have Detached It, We Can't Get It Out Of The Engine Bay. It Has Been Suggested To Remove...
Kerry a
HOLDEN ASTRA
Tail Lights
Driver Side Running Light On Driver Side Back And Marker Light On Driver Side Front Won’t Light Up But The Passenger Side Is Fine And I...
claflinshane
Running Lights Driver Side Not Working?
My Running Light And Front Marker Light On The Driver’s Side Won’t Work But The Other Side Is Fine. I'm Trying To Figure Out Where...
claflinshane
Battery Hooked Up Wrong, A/C Fuse Blows Instantly And...
My Son Had A Drained Battery, So I Went And Bought Him A New One. I Didn't Pay Attention To When He Put The New Battery In, And He Did...
stl1
Clanking While Light Braking?
Hello, Over The Last Week My Car Has Been Making A Clanking Noise From The Front Passenger Side Only When Under Light Braking Between 20...
JeffreyTyer
HONDA S2000
How Do I Get It Out Of Limp Mode?
I Was Driving On The Freeway When It Sounded Like Rubber Flapping From The Tire And The Engine Shut Off. As Soon As I Realized I Lost Power...
Jnnfrosal82
A/C Not Blowing After An Hour?
For The Last Several Years, When Taking An Extended Car Trip After Some Time The Air Stops Coming Through The Vents. You Can Clearly Hear...
Colleen H
FORD FIESTA
Transmission Problems
justintoledo
MAZDA B2300
675
676
677
